Lg 42pc55 plasma tv,right hand corner of screen has a blue flicker which sometimes extends to bottom center and halfway up right hand side, also with a particular spectrum faces of people have blue tint, can you advise?
Careful adjustment of the y sus pcb using a scope cures it, i repair these all day for lg
Posted on May 03, 2008
My LG 42 Plasma works sometimes then half the screen goes black but the right side stays perfect???
have almost the same problem left side is black with sometime blue line red lines or a whole bunch of different lines some one help please have sound and right side of tv works fine
Sep 26, 2010 | LG 42PC3D 42 in. Plasma Television
Got a blue vertical line on me plasma
Ohh you have a problem with the PLASMA gass ( RGB balance failiure )..don't switch it on again run to service center....
causes ;- heavy nonstop use, heavy impacts , can have probs from LG factory , we have nothing to do the only advice is run to a service center...don't try to do it yourself ....
so i identified your prob...PLEASE VOTE ME AS "FIXYA" (Successfully solved) for my help
May 29, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Blue dots center and yellow stain right hand corner on 60'' sonytv
Yes, I do. It needs a new light engine. Very costly repair. However, Sony has extended the warranty on many of these LED projector sets. You need to call a local Sony authorized service center and see if your model is covered. Otherwise this repair could run over a thousand bucks.
Jun 14, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Blue flickering on plasma screen
Need to adjust some voltage on the Power Board & Y- Main Board.
Jan 25, 2009 | Samsung SPN4235 42 in. Plasma HDTV
Plasma tv screen going black
pls contact 9420806154 for solution
Dec 20, 2008 | LG 42LC2D 42 in. LCD HDTV
Red lines on right hand side of the screen now no picture on right hand side!
I'm not an expert, but I have determined that the vertical bars that are often red, sometimes blue ... and sometimes both ... are related to a bad control board. I've also read that a common fix is to buy a repair kit with includes the ysus, zsus and control boards ... all replaced together. My experience was that after a month or two with the 1.5" wide stripes, that you eventually loose the entire picture and have sound only. MIne comes back, but won't stay working for very long and the stripes are always there (buy used to fade and flicker sometimes). I'm planning on replacing the control board.
Jun 09, 2008 | LG DU-42PX12XC 42 in. Plasma HDTV
Vertical bar on Daewoo Plasma screen
YES YOU HAVE DRY JOINTS UNPLUG FROM POWER SUPPLY REMOVE THE BACK/ INSIDE YOU SHOULD SEE AT THE BOTTOM SEVERAL RIBENED CONECTORS FROM THE SCREEN ITSELF? UNDERNEATH YOU SHOULD BE ABLE TO SEE 2 OR 4 COMPONENTS CAREFULLY APPLY A HOT SOLDERING IRON AN SOLDER THE ONE THAT YOU ARE HAVEING PROBLEMS YOU SHOULD NOW HAVE FULL PICKTURE AGAINE ANY PROBS email me andymay2@msn.com
Mar 09, 2008 | LG 42PX5D 42 in. Plasma HDTV
Sony Wega 50 inch LCD
I also have a Sony Wega 50 inch LCD, once turned on the screed stays completly black however, the green light comes on. Anyone else had this problems or knows if it can be repaired or not?
Jan 20, 2008 | LG RU-60SZ30 60" Rear Projection...
I had the same problem, a vertical blue line from top to bottom on my samsung TV.
Try this download this http://www.jscreenfix.com/video.php i burned it to a dvd and it fixed it within a minute.
Nov 07, 2007 | Samsung HPN5039 50 in. Plasma HDTV
Flicker
I had the same problem with the flicker. Mine was a Flicker followed by a greenish line through the screen. It got worse then after 2 months the tv stoped working the power didnt come on at all. I Im taking it to bget fixed. The guy said it has somthing to do with a burnt out switch in the unit.
Oct 13, 2007 | Daewoo DSP4210GM 42 in. Plasma Television
Televison & Video Logo
153 people viewed this question
Top Televison & Video Experts
Electro Med Services...
