posted by Badandy101 on Apr 15, 2008
My Sony CDP-C601ES 5 disc cd changer does not recognize a cd when I load it. I have taken it apart. What I noticed was the cd does no spin up. I suspect the motor that spins the cd is bad. If I take it in to get fixed is it going to cost as much or more than buying a new comparable cd changer?
Solution #1
posted on Apr 15, 2008
The C601 will not spin up the disc unless one is detected. If the optics are bad and do not realize that the disc is there...
Try cleaning the lens using a cotton swab and alcohol. If that does not resolve the problem, the optics are bad. The optics in this unit are KSS-240 (I think). This part costs about $30-$40 depending upon where you get it. You can try to replace it or have a shop replace it for you. Add in the local labor rate for the total repair cost. This is a relatively simple repair. I have done 100s. It usually takes about 45 minutes plus the testing time.
Dan
Dan
Was this solution helpful? Show your Appreciation by rating it:
This Problem Also Relates To:
NAD C541 CD Player
NAD T512 CD Player
Panasonic SCAK410 5-Disc CD Changer
Panasonic SL-PR300 4-Disc CD Changer
Sony RCD-W500C 5-Disc CD Recorder
Sony SLV-D251P DVD/CD Player w/Built-in Hi-Fi VCR CD Player
Sony DVP-NS501P Progressive-Scan DVD/CD Player : ** Now Your Chance Brand ** CD Player
Can you Help with these CD Players problems?
Sony MegaStorage CDP-CX333ES 300-Disc CD...
Numark Axis 9: lights up but no...
Numark Axis 9. At switch on the... Answer This...
Panasonic CQ-C5110U CD Player w/ CD-R/RW...
Panasonic CQ-C5110U Playback...
HIYA..! i have a panasonic... Answer This...
Repair Service
Find CD Player Repairman Near You:
