Question about ASUS A8N-SLI Motherboard
Bad SATA data cable connector or drive?
System has been running fine for over a year, almost two now. I added another SATAII 2.0 drive and am having trouble getting winxp pro see the new drive. Any suggestions?
    President:
  • 2,351 Answers
Hi miss, is you're new SATA being seen in you're bios?
To check this. At boot up press the Delete key every two seconds until the bios main menu loads.
You should see the new SATA listed here. If you do not see you're new drive listed than shut down the PC & unplug the power cord. Remove the data cable & clean it with a cotton swab & some house hold alcohol. (no dripping). Wipe off both ends of
the data cable & the drive's connector. ( Allow time to dry).
Re-connect every thing & again check you're bios. If you're drive is listed than you can use you're current windows to format the drive. I gather you're current windows is running correctly.
If you get a error message from windows during format, do not worry, yet!
I suggest you download the drive's Mfg's software tools & use this to test & setup the SATA drive. Locate the white sticker on the new SATA drive. There you'll find the model number & serial number. Write the drives information down on paprer for later. You can register you're SATA drive later at the Mfg's site.
Most Mfg's have bootable software for a floppy disk & the same to creat a bootable CD-ROM disk so you can setup & test you're new drive which is what I am suggesting you do. You will need to disconnect you're other SATA drives while using the bootable software. (Just unplug their data cable). No need to unplug the power to the drive - (s).
I am sure you will be able to setup and test you're new drive. Once finished, reconnect everything. Double check everything before closing up the case. Boot you're system. Windows should see you're new drive.
Good Luck!
If I can be of more service, just ask.
Mike
Posted on Apr 15, 2008
Install cd drive
Dell Optiplex 740 DESKTOP?
http://support.dell.com/support/edocs/systems/op740/en/UG/dt_index.htm
Under the bold black subheading -
Removing and Replacing Parts, click on - Drives, in the list.
After details on the power cable, and data cable, the Optical Drive is the first drive listed.
Examples of a SATA data cable, and it's connector; and a SATA data cable connector on the motherboard,
http://en.wikipedia.org/wiki/File:SATA_ports.jpg
Note the L-shaped opening in the SATA data cable's connector.
Lines up with an L-shape on the motherboard connector.
ONE style of SATA motherboard connector is shown.
Your SATA motherboard connector may differ in appearance. Still has an L-shape in it, though.
(Hold the SATA cable connector in your hand, look at the connector.
If you turn a capital L to the LEFT, and turn OVER, that is the correct position to install the cable, in.
_____I, then turn over )
SOME SATA cable connectors have a Lock on them.
Some are like a tab you press down, others are like a small 'bulb, that you press down on. Suggest use your thumb.
Depress Lock to Install cable, and to Remove cable.
Between a SATA data cable's connector, and a SATA power cable's connector; a SATA power cable connector is Larger.
SATA data cable connector has 7-pins.
SATA power cable connector has 15-pins.
Example of a SATA power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#sata
Depress the Drive Release Latch, slide the drive towards the Back of the computer, lift up slightly to remove SATA data cable, and SATA power cable; THEN remove optical drive.
(CD/DVD drive)
For additional questions please post in a Comment.
Regards,
joecoolvette
Feb 18, 2013 | Dell OptiPlex 740 PC Desktop
Connections to the hard drive
The Harddrive is a SATA unit.
Uses a SATA data cable, and a SATA power cable.
SATA data cable, and connector on motherboard, example;
Between the SATA data cable connector, and the SATA power cable connector; the SATA data cable connector is the shorter of the two in width.
The connector end used on the harddrive side, and optical drive side, (CD/DVD drive), is usually a 90 degree Bent Elbow.
The connector end that plugs into the motherboard, is a Straight connector.
NOTE* Color of connectors does NOT matter.
Most of the time the SATA data connectors on the motherboard, are different colors.
This is to help discern what number of SATA data connector it is.
Four SATA data connectors on the motherboard?
SATA 1, SATA 2, SATA 3, and SATA 4;
Or:
SATA 0, SATA 1, SATA 2, and SATA 3?
SATA 0, or SATA 1, is usually reserved for the Harddrive.
The Primary harddrive with the Operating System on it.
(Unless you have harddrives set in a RAID configuration)
DOES NOT MATTER WHAT SATA DATA CONNECTOR, you plug into, on the motherboard.
Want to plug the harddrive into SATA 3, or SATA 4?
Go ahead.
NO matter what SATA connector on the motherboard that you plug into, BIOS will find the harddrive.
Note the L-shape in the connector.
Has to line up on the L-shape on the harddrive, optical drive, or motherboard, SATA data connector.
There is usually a lock on the connector. This you may not see.
Sometimes there is a little 'bump' on the connector. Depress with the thumbnail to install the cable, or remove.
This is an example of a SATA power cable,
NOTE*
IF, your SATA harddrive has a provision for plugging in a SATA power cable, AND a 4-pin Peripheral power cable; ONLY plug the SATA power cable in.
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
Using BOTH types of power cables will BURN the harddrive up.
May not happen right away, but I assure you it will happen.
Regards,
joecoolvette
http://en.wikipedia.org/wiki/SATA
Dec 10, 2012 | Acer Aspire X1 AX1470-UR11P Desktop PC...
How to Replace the DVD RW on my PC /HP Pavillion a6130n /
Better
There is Me
HP Support > Pavilion a6130n Desktop PC > Main Support page,
http://h10025.www1.hp.com/ewfrf/wc/product?product=3436817&lc=en&cc=us&dlc=en&lang=en&cc=us
How to > Adding / Replacing hardware > Opening the PC Case,
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00968217&tmp_task=useCategory&cc=us&dlc=en&lang=en&lc=en&product=3436817
Back page; Adding / Replacing hardware > Removing the Front Cover,
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00968624&tmp_task=useCategory&cc=us&dlc=en&lang=en&lc=en&product=3436817
Back page; Adding / Replacing hardware > Adding or Replacing a CD or DVD Drive,
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00981303&tmp_task=useCategory&cc=us&dlc=en&lang=en&lc=en&product=3436817
This is an example of a SATA data cable,
Note the L-shape inside the cable's connector.
It also shows a SATA connector for the motherboard.
Note the L-shape on the connector. The optical drive (CD/DVD drive) also has this L-shape on it's connector.
(SATA connectors on the motherboard come in various colors. Color signifies what SATA connector it may be. SATA0, or SATA1, or SATA2, etc.)
Between a SATA data cable's connector, and a SATA power cable's connector, the SATA power cable connector is the larger of the two.
SATA data cable connector has 7-pins. (Contact pins)
SATA power cable has 15-pins. (Contact pins)
A SATA data cable connector, and a SATA power cable connector, may have a small 'bump' on them, that you depress with your thumb, when installing the cable, or removing. The 'bump' is a Lock.
Usually the cable end going to a harddrive, or an optical drive; will be a 90 degree Elbow.
The straight end connector plugs into the motherboard.
A Top View look at the motherboard in your computer,
HP Support main page > Product information > Product specifications > Motherboard specifications, MCP61PM-HM (Nettle2),
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01077676&tmp_task=prodinfoCategory&cc=us&dlc=en&lang=en&lc=en&product=3436817
View shown has NO hardware on the motherboard.
(Processor, Ram Memory, etc)
The long Blue, and Black slots, with the White Lock 'ears', are Ram Memory slots.
The SATA connectors on the motherboard, are to the bottom/right corner, of the Number 3 and Number 4 ram memory slots. (Blue)
Yellow, Blue, White, and Black.
Scroll down, and click on the + sign to the left of the blue -
Motherboard layout
Using this illustration you can see;
Yellow SATA connector is SATA4 <-
Blue SATA connector is SATA3
White SATA connector is SATA2
Black SATA connector is SATA1
Due to standards set by JEDEC, and generally followed by all; the harddrive is plugged into SATA1.
HOWEVER, you can plug your optical drive, or drives, or harddrive, or harddrives; into ANY SATA connector on the motherboard that you want to.
The beauty of SATA is that BIOS will find the drive, NO matter what SATA connector on the motherboard you plug into.
Harddrive, or optical drive.
For clarification on anything I have stated above, or for additional questions; please post in a Comment.
Regards,
joecoolvette
Nov 05, 2012 | HP Computers & Internet
Dell t3400 power for 2 hard drives
Not a problem.
This is a general view of a SATA -> data cable, and it's respective connector on the motherboard,
Note the L-shaped opening in the SATA data cable's connector, and matching L-shape on the SATA data connector on the motherboard.
Note also that a SATA data cable's connector has 7-pins
Between it, and a SATA power cable connector, the SATA data cable connector is the smaller of the two.
A SATA power cable has 15-pins,
Note that it's cable connector opening is also L-shaped.
So is the matching connector on a SATA harddrive, or SATA optical drive. (CD/DVD drive)
A SATA power cable's connector generally has an area on it, that you depress with your thumbnail, and this releases a Lock.
Depress to install, depress to remove.
SATA data cable connector, Or SATA power cable connector; that goes to a Harddrive, or to an Optical Drive, is usually a 90 degree bent elbow.
The straight connector on the cable plugs into the motherboard.
(Can be straight connector on both ends through, but isn't CORRECT)
SATA connectors on motherboard;
IF, this Ebay link selling a Dell Precision T3400 Desktop PC motherboard, is correct, there are;
http://www.ebay.com/itm/Dell-TP412-Precision-Workstation-T3400-Socket-775-Motherboard-/360503300257?pt=Motherboards&hash=item53efabd0a1
1) FOUR Black SATA connectors
2) ONE White SATA connector
3) One Blue SATA connector
1 Black SATA connector, and 1 Blue SATA connector, at the bottom of the black Ram Memory slots.
1 White SATA connector, and 3 Black SATA connectors, right next to the where 24-pin ATX main power cable, plugs into the motherboard.
General example of said main power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24
(Note* Color of connectors does Not matter )
Originally the Master harddrive, should plug into SATA1 connector on the motherboard.
If you look real close, next to all of those SATA connectors on the motherboard, you may see SATA0, SATA1, SATA2, SATA3, SATA4, and SATA5, printed right next to them on the motherboard.
The beauty of SATA:
DOESN'T MATTER WHERE YOU PLUG IN WHAT, on those SATA connectors.
Use ANY one you wish, and plug whatever SATA device into it, that you wish.
BIOS will find the SATA device.
No matter what SATA connector you plug into, and no matter what SATA device.
Kapish?
http://support.dell.com/support/edocs/systems/wst3400/en/ug/ug_en.pdf
What a minute, this news just came in.............
The Blue SATA connector on the motherboard, under the black Ram Memory slots, is SATA0.
The Black SATA connector next to it is SATA1.
If you have SAS harddrives (Serial Attached SCSI), the power cable's connector has a provision, to plug the SATA data cable into it also.
If you do not have that particular SAS power cable it's OK.
You can just use a separate SATA power cable, (90 degree elbow to harddrive/optical drive), and a separate SATA data cable.
For additional questions, or to have me clarify further on anything I have stated above, post in a Comment.
Regards,
joecoolvette
Oct 30, 2012 | Dell Computers & Internet
How to connect a cd rom/dvd
If your CD / DVD is powered on Ok then you are missing the data cable connection which will be either a SATA (small connector) or IDE (much larger connector) both of which plug in to your motherboard....Look at the CD / DVD and try to identify which type of connector you are missing then look for an unconnected cable of the same type within your case.
Dec 17, 2011 | Gateway LX6820-01 Desktop PC
How do i install a wdeads hard drive? where is the power supply (4pin Molex)?
I'LL TELL YOU UPFRONT i HAVE ONLY INSTALLED SATA ON A NEW SYSTEM SO MY ANSWER MAY NOT BE CORRECT IN ALL SITUATIONS
Question is vague. Are you replacing a drive or building a new system? SATA drives have a dedicated plug on the Mother Board. Of course you already know you can't replace an IDE with a SATA without an adapter (Ebay has them for about $8) or the Bios is incompatible. The power is on the Motherboard and does not have a connector from the power supply like an IDE has.
Feb 20, 2011 | Western Digital WD15EADS 1.5 TB SATA Hard...
1.I have 2 Hard Disk instal but BIOS not detect any HDD 2.I want to instal XP but is say not detect Hard Disk. 3.Sorry for my englesh.
HDD2 implies there must already be an HDD1 in the system, unless the number refers to either the ATA-133 or the SATA connections.
If you are using the ATA-133 (parallel IDE) connection for your hard drives, make sure that either both drives have their jumpers set to "CS" or "Cable Select", or one drive is set to "Master" and the other to "Slave". For a single drive, set it to "Master" or switch to the other connector on the cable if you prefer "cable select". (The connector on one end farther away from the other two connectors must go to the motherboard to use "cable select".) Otherwise only one drive will be recognized.
Check the power and data cables to make sure they are properly installed - on some drives it is possible to put the data cable on backwards, but it won't work. The colored wire on the edge of the ribbon cable should be next to the power connector. Also, sometimes the wires work loose from the contact forks inside the connectors. If you think this is the case, run your finger across the cable next to the connector with light pressure to make sure all of the wires are pushed down into the forks.
If you are using the Serial ATA connections, make sure both the SATA cables and power connectors are properly seated.
If you still cannot see the drive in the BIOS, it may be defective, or the motherboard may have a problem with the drive interface electronics (this is much less likely than a bad hard drive).
Once you have both drives recognized, you should be able to partition and format them as needed before you install your operating system.
Jan 11, 2011 | Soltek SL-KT880E-RL Motherboard
I have a k8upgrade vm800 motherboard. I want to install a sata hdd for storage only but the bios is not seeing the sata connection. Is there any soloution to make this possible or are the sata connections...
Is the drive initialised ... if not it will not exist on your system.
1.1 Serial ATA (SATA) Hard Disks Installation
This motherboard adopts VIA VT8237 southbridge chipset that
supports Serial ATA (SATA) hard disks. You may install SATA hard
disks on this motherboard for internal storage devices. This
section will guide you to install the SATA hard disks.
STEP 1: Install the SATA hard disks into the drive bays of your
STEP 2: Connect the SATA power cable to the SATA hard disk.
STEP 3: Connect one end of the SATA data cable to the
STEP 4: Connect the other end of the SATA data cable to the
chassis.
motherboard's SATA connector.
SATA hard disk.
Nov 25, 2017 | Asrock K8Upgrade-VM800 Motherboard
Connecting to a motherboard with sataII
All you need is the two plugs that go into the hard drive. The S-ATA and the Power connector (Make sure that the hard drive is plugged into the motherboard in order e.g. plug 1 plug 2...).
Dec 24, 2009 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Saving Data from harddrive before reformatting
what kinda drive? SATA? IDE?SATAII?
older drives have pins at back, select jumper for slave. SATAII u can try to do from BIOS (DEL at startup)
May 21, 2008 | Computers & Internet
ASUS A8N-SLI Motherboard Logo
155 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
