Question about Freezers
Defrosting a fridge freezer
I was wondering if there is any way that you can defrost the freezer section of a fridge freezer without losing power to the fridge section?
Thanks
Kathryn Park
  • smoof Apr 18, 2008
    Thanks for your help anyway.
  • 145 Answers
No. All the cooling comes from the freezer unless you have one of the few split systems. A hairdryer will help but the fridge will warm up some.
Posted on Apr 17, 2008
The freezer cools half way top, below is warm.
If there is no cooling at all on the fridge section but the freezer works then it is confirmed that the compressor and gas pressure is OK. Now shut off the fridge and leave it powered off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge.
However if ice forms in the freezer then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked. Frost formation without defrosting could block the air flow and so shut the air passage to the fridge. Also the blower fan must work and if this is not working then the fan can be faulty. Also a fault on the control unit is a suspect to non functioning of any one of these components.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
So try this test using a multi-meter on the defrost timer and the thermostat and make your observations so that we come to the solution.
Jul 14, 2011 | GE 14.8 cu. ft. / 419 liter Chest Freezer...
I have a Artic Air White Reach In Freezer. It is not blowing cold air from he top where the cold air comes in. Freezer was at 60 degrees F. I turned the defrost switch to make sure it wasn't in...
Is the freezer itself getting cold.To blow cold air.the freezer should get cold/friezed.the cold air blows from freezer to fridge side.first the freezer side gets cold, then when the freezer side gets enough cool to its set cooling temperature, at that time the defrost cycle starts.In defrost cycle the fan in the freezer starts running and the cool air from freezer starts going to fridge side.There is a ventilation passage between fridge and freezer from where this cool air passes.---------------- If in your case, the freezer is getting proper cold, but its not blowing cold air from freezer to fridge, then possibility is that, there is a blockage in ventilations.But if ventilation its clear, then its defrost problem.First try manual defrost reset procedure. The procedure is as follows: ---- First unplug the unit from main power outlet. Then empty whole unit completely. Then keep both the doors open. Wait for 24 hours. All the ice collected on the coils and in the freezer section will get melted. Clean the water from the sections. Then Connect the power cord of the unit to main power outlet after 24 hours/.Then set the temperature to normal in both fridge and freezer section. It will take near to 4 hours to get run in its proper cooling cycle. Then check, if the problem returns again. Then its defrost board problem. ------------------------- BUT if in your case, the freezer section itself is not getting cold, then the problem is compressor related.The compressor is the part which cools the freezer frost.In the compressor, there is a refrigerant to cool the freezer.If the compressor gets weak or the refrigerant gets low, then it will not cool the freezer, if the freezer is not cool then it will blow warm air from freezer to fridge, in defrost cycle.In that case, the compressor is faulty and its the cause of problem.------------ So you will have to first check , that is your freezer getting cold or not.as per that you can start the troubleshooting.------------------
You can get required parts from from online sites like: --- www.repairclinic.com or from searspartsdirect online site. --------- This should help.Thanks.Helpmech.
May 01, 2011 | Arctic Air Freezers
My freezer is not cold. The temperature dial reads 1-5 then an igloo and a snowflake. Do I put it on the snowflake to get it cold or the igloo?
Insufficient cooling is a fridge repair job that you can do without the help of a professional. Often the fridge has a frost-free failure, or the compressor is faulty but there are many other reasons for a fridge not cooling properly.
Step 1 - Find the Problem
Your first job is to locate the source of the problem. Consider each of the following:
* Gaskets - Make sure the gaskets/seals are not torn and are sealing properly.
* Evaporator fan - Make sure it is working. If it is now working you may have a problem with the fan motor. Check for power to the motor and also examine the fan switches around the door (not all fridges have these switches).
* Air damper - Sometimes the air damper will not open up to allow the cold air from the freezer part to blow into the fridge section.
* Condenser coils - Check to see that the condenser coils don't have a dust build-up and that the condenser motor is working.
* Compressor - Make sure your compressor is working with on and off clicking noises.
Step 2 - Frost-Free Failure
This is the most common cooling problem in fridges. Expose the evaporator coils by accessing the panel in the freezer section. The coils in the freezer section can sometimes get clogged up with frost. This can stop the evaporator fan motor from blowing cold air around, or cause the fan to hit it and stop, or become noisy. The defrost timer can be a bit tricky to find but it is usually located behind the back bottom corners of the fridge, although they can sometimes be found in the ceiling of the fresh food section, or behind the cold control cover.
Step 3 - Find the Timer
When you find the timer, turn the wheel-like screw slowly with a screwdriver until the fridge shuts off. The refrigerator is now defrosting. If you find that the fridge starts now, you will need to replace the defrost thermostat and the defrost timer.
Step 4 - Volt Test
If the heaters do not come on, use a volt meter to ohm test the defrost heater or volt test for 120 volts to the heater. You can bypass the defrost thermostat if you haven't got power to the defrost heater to check if the defrost heater will come on. To bypass the thermostat, join the two wires together. Replace the defrost thermostat and the defrost timer if the heater comes on now.
If there is a ticking or squealing noise in the defrost timer, or it seems hot to touch, replace it.
Many fridges have and inline fuse on both sides of the defrost heater. You will need to replace the whole heater if one of those fuses blows. Check these fuses with a volt meter if the defrost heater doesn't work.
A quick check if you have a cooling problem is to inspect the evaporator coils. If there is a build up of white snow on the coils, this indicates a frost free problem; if there is balled ice on part of the coils with the rest bare, this indicates a system problem, like a problem with the pumping compressor.
Take care in solving the problem....
May 01, 2011 | Whirlpool 19.6 cu. ft. / 555 liter Upright...
After defrosting the freezer it will not cool
Don't panic about the hot sides of the freezer. It is quite common on all the freezer (make/model).
After defrosting, your removing the full temerature out of the system. It will take atleast 30 ~ 60 mins to come back to set temperature. This again depends on the load inside.
Jun 06, 2010 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Kenmoore upright freezer cold but not freezing
Hi!
Thanks for using FixYa. First of all please check that there is air flow in the upper vent baffle in the fridge section which is located behind the crispers. If there is no air flow at the vent baffle in the upper fridge section then this is the cause of the issue you’re facing with. The evaporator fan pushes the air through ducting into the refrigerator from the freezer and if there is any material obstructing it then clear it.
If still the problem persists then you need to check the following things:
The defrost circuit contains defrost timer, defrost heater(s) and defrost thermostat. Defrost timer failure will not put power to the circuit. Defrost heater failure will fail to defrost when the timer applies power. Defrost thermostat must be closed for defrost to take place. First locate the timer, rotate the clutch head screw clockwise slowly until one distinct click is heard. Now the timer will be set in defrost mode and defrost should complete within 30 minutes or less after which the refrigeration should start cooling again. If defrost takes place and it does not go back to cooling automatically turn the screw once again until you hear the second click, unit will start. Replace the timer. If defrost does not take place in the time frame above and the unit restarts in cooling test the defrost heaters. From the heater(s) follow the wires from each end to where they plug into the circuit. Unplug them and test through the heaters with an ohm meter. You should get a reading if they are good, if no reading then you need to replace the heater(s). If you get a reading on the heater(s) then you need to replace the defrost thermostat.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 14, 2009 | Kenmore Freezers
Freezer has frost in back- frig not coolling
You have a defrost parts issue.
Unplug the fridge. Remove the back freezer panel and check the defrost heater and defrost thermostat.
Without a model number I can not tell you where the defrost timer is.
Mar 04, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Fridge and freezer both freezing
If your control is not turned up too high you likely have an insensitive one. In this case it needs to be replaced with a new one, not too serious.
Dec 18, 2008 | Kenmore Freezer 20.6 cu. ft. Manual...
Power on but fridge/freezer not working (only lights)
Yes, boards may need replacing, but not at the expense of the door, apparantly your "engineer" would rather work on older models that may require a hammer. Best advice would be given knowing the make and model number of your unit. A professional should be able to diagnose the board processes as well as the compressor in a short amount of time. Check the defrost heater (after pwr is restored to unit) for the freezer side (placement depending upon model) for continuity (basically a heating element for the evaporator coils - which will freeze without defrost). Proper defrost will help lessen the load on the compressor. Check the overload relay on the compressor itself for failure and replacement of relay. Have the unit defrosted, svc defrost htr, thermostats/thermolinks , compressor, before checking computer board operations.
Oct 25, 2008 | Freezers
Fridge freezer
  • Check the temperature setting
  • Assure that there is enough room for air flow in the refrigerator or freezer
  • Check for air flow restrictions in vents
  • Test the temperature control
  • Clean the condensor coils
  • Check the door seals
  • Test the door switch
  • Test defrost heater
  • Test defrost timer
  • Test evaporator fan
  • Check for a clogged drain tube
  • Check for refrigerant leak
Sep 23, 2008 | Engel Freezer 22 Qt. Fridge/Freezer
Freezers Logo
105 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
