Question about Dryers
I think I need a new belt and maybe bearings on my squeeks. Other than that it works fine. I am a single lady and dont know how to fix it myself. Dont know if it would be really expensive to have a repairman do it or if I should just look to get a new appliance?
  • 178 Answers
If you can post a reply to me with your model number, I can walk you through a belt replacement. A repairman is usually 75.00 an hr with an hr min charge. The belts are typically 7-10 dollars each and easy to replace for the most part.
Posted on Apr 16, 2008
Very squeeky dryer, starts out quiet then intensifies through the cycle untill it can be heard from outside; has a rhythmic squeek.
The belt is probably rubbed smooth. Since you already sprayed it, after the spray dried out, it starting squeaking again. I suggest examining the belt and replacing it if necessary.
Mar 22, 2016 | Dryers
How do I fix a squeek on a whirlpool elec. dryer
this is the sound of a bad belt tentioner ... small plastic wheel that keeps the belt tight .. easy fix cost maybe 12.00
Aug 06, 2014 | Whirlpool Dryers
My kenmore heavy duty extra large capacity 2 speed motor when drying my clothes squeeks when turning to dry clothes can I spray wd40 to make it stop squeeking and how or what do I oil?
Most likely a wheel bearing on the tub of a front loading washer, or the belt tensioner pulley on a top load washer. Either is not fixed by lubrication but replacement is called for. There are usually 3-4 wheels on front loaders that could be out. Replace all of them if you are going to replace one. The belt tensioner is a single assembly that can be ordered from any appliance parts warehouse or Sears.
Aug 01, 2012 | Kenmore Washing Machines
Dryer squeeks
sqeak is caused by a dried up roller bearing that keeps the belt tight that turns the drum around
Get the belt and bearing which will come installed on a new belt tensioner puller at Sears at a good price
Replacingf the belt at the same time is highly recomended
Jul 16, 2011 | Dryers
My dryer is making a very loud, constant squeeking/squilling sound. I took apart the front and top and examined the belt. The belt is fine! The dryer works but even wth my laundry door closed, it is really...
In the back of the dryer there is a ball bearing unit that it rotates on... I have changed these before,
and they all made the same noise you described.Most dryers ( ALL TYPES ) have the same basic design.......This should be your problem....I think they are about 30 or 40 dollars..kinda hard to change will need plenty of room to work in and maybe an assistant to help hold it in place because it has to be centered.
Feb 20, 2011 | Dryers
Whirlpool model LEQ8800 - squeeks when running, periodic in nature (1 squeek per revolution), sort of like a high pitched chirp; louder and longer when fully loaded. Is this a bearing (that needs to be...
he belt tensioner has a roller with a bearing in the middle of it. that is your squeaking problem on every revolution it turns
replace the roller and belt sold as a kit at SEARS
Jun 10, 2010 | Dryers
My dryer is squeeking and grinding, but not all the time. What could be wrong? When it first starts, it sounds like it is grinding, but continues to work. After a few minutes, it stops. Then it will start...
One of two issues is going on, or maybe both. The first cause for the grinding noise is going to be the main bearing that is bad, and needs to be replaced. The squeaking is actually coming from the belt. So I would check under the unit and make sure that you do not have any metal shavings under the unit. Then also check the belt
May 18, 2010 | GE DBL333EA Electric Dryer
Squeeking while dryer is drying
i would suggest calling the repiar. The longer you wait the more expensive this will be. One of two things is happening. One, bearing is going out, or most likely the belt is slipping on the drum and needs replacement. Good luck
Jul 09, 2009 | Dryers
I have a Maytag Legacy Dryer SDE305DAYW that is squeeking. How do I change the belt?
the belt is not causing the squeek. either the tub rollers, or the idler pully is squeeking. you must remove the front panels and drum to inspect these parts. usually when a roller or idler pully is squeeking, you need to replace them. if they arnt to worn, you can clean the shaft and grease them to stop the squeek, but i dont recomend that, as it will just be a temporary fix and will start squeeking again. this isnt a easy repair if you've never done it. let me know if you have any further questions. Shane
Jun 19, 2009 | Dryers
Ge electric dryer
most likely source of sqeak fornt front glides or rear bearing, the front glides can be seen be removing the front panel, 4 plastic strips the tub rests on and spins across, they will look worn or even missing if thats the casse( they simply twist on) as far as the rear bearing ,,a.k.a. "top hat" , for it looks liek a top hat, the drum is simply pulled foward and out of rear post and the bearing can be reinstalled without even removeing the belt form the pulley
May 12, 2008 | Dryers
Dryers Logo
56 people viewed this question
Top Dryers Experts
