Question about Euro-Pro Shark 80 - 7133
Sewing machines needle cannot pull tread up from the bottom bobbin.
  • 1 more comment
  • eltero Apr 15, 2008
    looking for Euro pro model# 473A owners manual.
  • skyebernier Apr 15, 2008
    my sewing machine is also not pulling thread up from the bobbin, but only on the right side, works fine on the left on a straight stitch, but zig-zag or button holes, forget it, and I just bought it
  • fredbarrett Jun 22, 2008
    unable to get machine to thread in order to sew. No manual with new machine. Help
  • 240 Answers
Firstly-check the needle is in correctly.If the needle is slightly bent it will not pick up the bottom thread. When top and bottom are threaded, pull the threads towards you. Hold the top thread between finger and thumb and hold but do not pull tight. Turn the flywheel towards you while holding the thread at a 45 degree andgle in front of you, upwards. You should feel it loop and give it a very gentle lift and pull as you feel it. There are some good videos of this on youtube Ive found which may help you-just search for "threading a sewing machine".If no manual supplied-contact either the seller or the manufacturer to get one.
Posted on Jun 13, 2009
Ive got a singer sweingmachine 247 model no when i put the bobbin in the bobbincasing with tread and guide so the needle goes down to bring bottom tread up nothing happens it doesnt feed it to come up i...
try changing the needle
try rethreading the machine, make sure the presser foot is in the up position
make sure the bobbin is turned correctly in the bobbin case,, counter clock-side
also could be a timing problem
Dec 22, 2014 | Singer Sewing Machines
29k13not picking up thread
Take a look at the manual and make sure you have the bobbin going in the right direction in the bobbin case. Each sewing machine is different. On my Kenmore the bobbin drops in counter clockwise, on my old Universal KAB you have to the bobbin with the tread facing away from you when you slide it in the bobbin case then pull it through the slot and put ut under the tension spring. It is the same for the Brother Lx3125 as the Universal.
Remember the needle bar needs to be in the highest point. Make sure the horn goes into the slot in the shuttle race and is properly seated in the race.
The bobbin needs to be about 5 inches long and your upper tread also needs to about 5 inches long from the needles eye. Hold your upper thread tightly so that when it enters the needle plate hole it can catch the bobbin thread. Pull both of the threads beneath the presuure foot and toward the rear of the machine.
Jan 02, 2012 | Singer Sewing Machines
Im having trouble with the bobbin tread when i sow the bottom threadcomes out in big clumps and then jams the needle
Sounds like a threading mistake. Try this, thread the machine all the way to the needle but not the eye. Then lift the presser foot up and down and pull on the tread as you do that. You should have tension when the foot is down and not tension when it is up. If this is the case try sewing(should fix), if it is not the case your machine will need adjustment.
Mar 31, 2011 | Bernina Activa 130
Bottom tread keeps jamming and getting all knoted up. The display gives me an E6 error code. what can i do
try re-threading your machine. usually when the machine is jammed at the bobbin or when the needle gets stuck to the bobbin thread, it means that there is an error with the thread. make sure that the thread isn't pulled through the wrong side of the needle, wrapped the wrong way around the wheels on the top, and that the bobbin is threaded correctly. if this doesn't work, you may want to contact their hotline.
Sep 23, 2009 | Brother CS-100-T Computerized Sewing...
Thread in needle or bobbin keeps on breaking
The tread only breaks in the needle. what can i do . i don't get to sew anything . I tread the needle and get everything ready and start the machine and as quickly as that the tread is broken and the machine has not sewn at all.
Apr 07, 2009 | Brother LS-2125 Mechanical Sewing Machine
Kenmore sewing machine older model 1345381
hi! there wind thread on bobbins winder 4 times by your hand rotate clockwise,insert in shaft bobiins winder on top of your machine near hand wheel push latch to engage loop thread on disc winder tension start your machine on pedal foot automatically winder disengage if already filled up of thead pull this winder and insert to bobbins casing insert thread to slot and pull out winder 6411c87.jpgshould rotate clockwise as shown.insert on shuttle hook casing and close cover needle thread your upper
97b52e8.jpgthreading tension as shown on red threading from spool pull threading and loop to dial tension threading and insert thread to lever needle and to needle hole tip. pull tread under the needle foot and feeder tooth.rotate hand wheel counter clockwise to hook up thread bobbibs and appear at top of needle plate,teo thread shoul appear,set dial tension to # 3 and stich to # 8 range to # 12 depend on fabric and layer of fabrics and set on straight stich sewing,let needle on upper position insert fabric for trial sewiing.put down foot needle lever. manually by hand rotate for assurance needle is free to sew if obtruction on loop bobbins thread occurs adjust all tension gradually then try again until free from sewing w/o problem star sewing.
Aug 08, 2008 | Kenmore Drop-In Bobbin 505S-21BH...
Needle picks up bobbin thread but then thread gets stuck
I had exactly the same problem on the exact same model 3205FA. I'm not an expert, but have a little experience on solving my wife and daughter's sewing machine mechanical problems. I would suggest the following: A. Page 6 of the owners manual see item # be precise it is 1 1/2 times around. B. Page 7 at the bottom, Make sure the bobbin tension spring is set so that there is tension. When holding the tread the bobbin shouldn't unroll. If jiggled about 2-3 inches the bobbin should release about 1/3 of that distance. C. Page 8 at the bottom, ill. # 2. There are two flange holders and screws that hold the bobbin case in position located at about 5 and 7 o'clock. Make sure both screws are tight. This is important. D. Make sure the thread is treaded through the upper tension adjustment properly. See page 9 # Illustration C. Terrible illustration. Keep the dial generally in the green range. E. Put in a new needle, the needles that come with the machine are just short of terrible. Wouldn't hurt to buy good top quality needles for the machine.
Aug 22, 2006 | Necchi 3102 Mechanical Sewing Machine
Euro-Pro Shark 80 - 7133 Logo
214 people viewed this question
Top Euro-Pro Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Greg Cann
Greg Cann
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
