Question about Frigidaire FRS26H5AS Side by Side Refrigerator
Kenmore 57572791 Side by side refrigerator
Just came home and noticed frig is not working. No lights no nothing there is power going in and there is power to the fan and wiring in freezer panel. That is far as I have trouble shot.
    Genius:
  • 1,073 Answers
Check the defrost board connector into the celing of the fresh food section and if a wiring diagram is handy the defrost board its self
Posted on Apr 15, 2008
I have a Kenmore 795.5881 side by side refrigerator and I came home this afternoon and it has lost all power, no lights or anything. No breakers had tripped and the receptacle will power other items.
i had same problem, no compressor no lights nothing. power was good at outlet. took cover off top of unit. noticed a blown glass 15 amp fuse. cost less than 30 cents to fix
Sep 05, 2011 | Kenmore 59962 / 59964 / 59969 (25.5 cu....
What is the cubic ft measurement of a Kenmore side by side fridge, model # 57572791, serial # SH2448358
25.0 Cu. Ft.
http://products.geappliances.com/ApplProducts/Dispatcher?REQUEST=SpecPage&Sku=GSS25QGPBB
Aug 07, 2011 | GE GSS25QGPBB / GSS25QGPCC / GSS25QGPWW...
My icemaker works slow to make ice. Sears Kenmore side by side refrigerator. Model.57572791
check temperature in freezer compartment,needs to be near zero,if it is,there may be a problem with the internal thermostat on the icemaker,also checkthat the icemaker mold is filling completely with water,all the cavities should fill
Jan 22, 2010 | Frigidaire FRS26H5AS Side by Side...
I have a Kenmore coldspot side by side- not cooling properly
Setting it to 5 is what the manufacturer recommends. If you set it to 1 and the frig is still not cold, then you probably have a faulty cold control (thermostat)
http://tclaundryrepair.com/home
Feb 19, 2009 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
My kenmore refrigerator side by side
All the cooling takes place in the freezer and is blown over to the frig side so the frig side will start to warm up soon. Possible cause is the starting device to the compressor is faulty, compressor motor locked up or cold control faulty and not closing.
Feb 19, 2009 | Kenmore Refrigerators
Model 57572791 not cooling or freezing on either side
IF YOU LOOK INTO FREEZER BACK WALL CAN YOU SEE HEAVY FUZZY FROST?
Jan 29, 2009 | Kenmore 53642 / 53644 Side by Side...
Kenmore refrigerator not working
Hi!!! Go to the back of the frig and see if the compressor and condensor fan motor are working.If not then you have a bad current relay.easy fix.its located in the compressor where the wires go into..Good luck.Heres a picture of your current relay..
Jan 04, 2009 | Kenmore 57029 Side by Side Refrigerator
Load noise coming from freezer
nothing to do with light bulb - noise is probably fan hitting ice that has built up. to check, remove back panel inside freezer and check for ice build up. melt off with a hairdryer and get back to me if i'm right
Nov 12, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Kenmore Refrig #57572791 - Keeps blowing circuit
If you have an OHM meter, check from the flat conductors of the plug to the ground section of the plug. Any reading at all indicates a short in the circuit. Most likely place of the short could be the compressor. If you are capable, with the unit unplugged disconnect the leads from the compressor, then see if the breaker trips when you plug it in. If not the problem is the compressor . At ten years old it would be more expedient to get a new refrigerator than to replace the compressor. The warranty is up and you would pay the big bill for the compressor and labor.
May 28, 2008 | Refrigerators
Frigidaire FRS26H5AS Side by Side Refrigerator Logo
429 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
