Question about Kenmore Elite 45986 Front Load Washer
Now the washer wont come on
Hey i been having a lot of problems with this washer now it wont come on and i cant get my clothes out it is like the unit gets no power what do i do...i need my clothes.
    Genius:
  • 1,028 Answers
Remove bottom cover just below lock assembly will be a tear shaped plastic piece pull straight down door will unlock possible problem with pump out caused door to remain locked
Posted on Apr 19, 2008
I have a washer dryer combo DWC LD1013 it stoped drying. My clothes are more wet when put in to dry. The clothes would be extremely hot but all wet. It works 1 cycle and then stops. Please help ????
In order to dry cloths, you need two things, heat source and air flow. Sounds like you have heat but no air flow. If you can, pull unit out and check vent for washer. Look around unit and make sure there is nothing blocking any vents. If you don't see any thing, try drying with vent not installed. I run into a lot of homes with clogged vents inside walls. By drying with no vent installed, it might tell you if you have dryer problem or a home issue. Good Luck
May 25, 2016 | Washing Machines
My Samsung fully automatic washing machine WA10B7Q1 has a problem when it tries to spin it is giving a click click sound and will not spin
are you getting an error code ? If not the only time I have seen this is when my daughter crammed too much in her washer and it was to much weight to spin the gear was stripped out. Is there a lot of laundry in the washer, how old is the unit and lastley, less is more meaning your clothes do not get clean if you put tooo much in the washer, imagine how heavy the weight of all those wet clothes are. I would try unpluggling the unit hopefulling hitting the power first it should drain the water so the door will unlock, then remov some of the clothes.
WA10B7Q1http://downloadstuffplease.net/fonts/samsung-wa10b7q1-user-manual.html theres the manual download address for you.
May 02, 2016 | Samsung Washing Machines
WHY IS my bosch maxx 6 CANT SPIN THE CLOTHES OR DRAIN THE WATER ?
Hey there, welcome to Fixya! The above answers were pretty helpful, did you fix your problem with them? Did you check the manual for further instructions? You can find a PDF copy here: Bosch Classixx 5 Manual
Jul 11, 2014 | Bosch Maxx 6 WAB28260GB White 600 mm...
Wont drain
First Try Unplugging the washer for 15 minutes. Sounds like the pump is the issue. Was it a normal load of clothes or a Bath rug or blanket?After you plug the unit in try to select rinse/drain Or drain/spin.
If it starts try to cancel the cycle. The washer should drain the water out for you. Pls update when you can.
Sep 01, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore Elite H3E Washer Drain/Spin Problem
hi
it is the belt problem
check it///thank u
please rate it
Jul 04, 2009 | Washing Machines
My font load washer wont fast spin or drain
gimme those older models anytime. their having a lot of trouboe with this front loaders
Jan 07, 2009 | GE WSXH208A Front Load Washer
Frigidaire clothes washer model #FWT445GES1. The door wont stay shut, it pops open. The unit wont turn on even when I hold the door shut
I was having this problem. I thought the door catch was damaged but looked it up online and saw that it was intact. I was just about to call the repairman when I took another look and found that the rubber seal around the door was not properly seated. Duh! Almost cost me $100+ and lots of humiliation.
Jun 22, 2008 | Frigidaire Washing Machines
My indesit widl126s
my washer works fine but the dryer wont heat up or dry the clothes it goes onto dry but all the clothes are still coming out wet and the drum is cold
Apr 01, 2008 | Washing Machines
Fisher & Paykel no spin, no rinse
hums sound proble coming from the drain pump. sounds like its trying to pump out water but cant. try tipping back andsee if you can spin the pump manually, (usuallya fan cooling blade coming outta back end of pump.wont spin if it cant drain
Mar 22, 2008 | Washing Machines
Door clicks and wont open and washer runs but wont do anything
Potential reasons for it: - Door Lock/Switch Assembly Failure - In this case it should be replaced. - Door Lock unit is broken or removed from the door. - Look for disconnected wires to the door Lock/Switch unit. - Door Lock/Switch unit Failure You should remove machine's top cover and then you will have an access to the door lock unit. Be aware you should discconect machine's power cable first !! Good luck!
Jun 15, 2007 | GE WBVH6240F Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
Sal De
fordexpert
Robert Rankin
