Question about Dell Inspiron 1150 Notebook
Dell Inspiron 1150 not staying on even with new battery
I recently ordered a new battery for my dell laptop because the computer seemed not to be holding its charge, and would make a loud, rapid beeping sound whenever I tried to start it up. However, when I replaced the battery, the computer started up as normal and I saw the opening screen and then it went blank and the three indicator lights at the front of the computer started to flash. I have not been able to get it started since then.
1. Is this a problem that can be fixed if I bring the laptop into the store?
2. I desperately need to gain access to the data stored on the laptop, is there a way to transfer it onto an external hard drive before the problem is fixed?
3. Is it a virus?
  • 159 Answers
1.yes this can be fixed.
2.buy a laptop hard drive caddy the ide not sata to gain access to info. you'll need to open the hard tray remove drive place it in the caddy connect ythe caddy to desktop or laptop. start the desktop/laptop go to my computer the pc will give your caddy a drive letter maybe g or e copy your info from that location to disc or local drive.
3.its not a virus. motherboard issue
motherboard cost USD180-240
Posted on Apr 15, 2008
Inspiron 1150 Latitude D600 14.1 LCD Display-LP141X14 CD-ROM Drive: I installed window xp on my DELL inspiron 1150 lap...
you need the drivers...look here...http://support.dell.com/support/downloads/index.aspx?c=us&cs=19&l=en&s=dhs
you will need a computer thats online to download them,, put them on cd or flash drive
May 17, 2010 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
My dell inspiron 1150 won't connect to the internet
Go into your device manager and disable the device, and then reboot. That may give the device a chance to reset itself through windows
Dec 05, 2009 | Dell Inspiron 1150 Notebook
Inspiron 1150 will not start even in safe mode
will it start with a boot disk? If not ... and your power supply (battery or wall power) is solid, your computer is beyond most do it your selfers to fix.
You might want to take it to the big box store to have them take a looksee
Nov 03, 2009 | Dell Inspiron 1150 Notebook
How to remove battery on dell inspiron 1150
From Dell manual MAIN BATTERY
"Slide and hold the battery-bay latch release on the bottom of the computer, and then remove the battery from the bay. "
Image -
http://support.dell.com/support/edocs/systems/ins1150/sm/begin21.jpg
CMOS battery is located on the systemboard and requires disassembling the computer
Nov 02, 2009 | Dell Inspiron 1100 Notebook
New power adapter and new battery, wont charge through power chord, dell inspiron 1150
If ac adapter and battery have been replaced (Dell Branded AC adapter is required) then the only thing left is motherboard.
Oct 28, 2009 | Dell Inspiron 1150 Notebook
Inspiron 1150 won't turn on. Noticed recently that battery life seemed shorter, plugging it in did not prevent it from shutting down after receiving the low battery warning, and it took a long time to re...
A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective.
Oct 18, 2009 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
1150 dell inspiron. Laptop won't power up. If
This seems an issue with inverter board need to checked by an expert.
thanks
Jul 27, 2009 | Dell Inspiron 1150 Notebook
Connexant Modem, Sigmatel Sound and USB fail to work or install
I had the same problem with a dell m1330. Dell did not provide the xp drivers. I used various programs to identify hardware and then try to hunt them down on the internet. I finally gave up and bought driver scanner from uniblue for $30. Solved all my problems. It also sounds like your chipset driver maybe the wrong one. Also you can download "PCWizard" it will tell you the details you need to know to find the correct drivers.
May 27, 2009 | Dell Inspiron 1150 Notebook
Dell inspiron 1150 won't turn on
Remove the battery the memory the ac adapter,the hard drive, the cd rom.Press and hold the power button down for twenty seconds.try again if no go you will have to replace the systemboard.
Good luck
Jan 13, 2009 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Problems with Dell Inspiron 6000 Battery ? DELL Inspiron 6000 laptop battery is popular, why ?
You can also pick up the batteries less expensive than most computer places at batteries plus. And yes it sounds as though it is the batteries charge is getting low, especially if it runs fine when the battery is out and you have it plugged in.
Mar 13, 2008 | Dell Inspiron 6000 Notebook
Dell Inspiron 1150 Notebook Logo
106 people viewed this question
Alun Cox
