Question about Intuit QuickBooks Premier 2008 (3-User Pack): Windows
Ran SpyBot to fix lag issues, now can't access my Quickbooks 08
When I click on my desktop icon, Quickbooks says loading... , as normal then the loading window goes away and no program come up.
Did I delet my .exe loading comand when I agreed to fix multiple errors spybot found?
Signed
Cal
  • undertoe Apr 15, 2008
    I corrected the trouble which was with Microsoft .NET Framework 2.0 Service Pack 1 that was damaged. Once I uninstalled and re-installed that program, my Quickbooks is back up and running.
    I guess I needed to reach out to the experts, to activate the expert in me.
    Thanks for this fourm.
  • Dick
    Dick May 11, 2010
    .Net is up to version 3.5 now, you should keep your computer up-to-date.
    Champion:
  • Intuit Expert
  • 237 Answers
Spybot has been known to damage the QuickBooks program in the past.
You will need to reinstall the program.
Posted on Dec 24, 2014
  • 108 Answers
SOURCE: QuickBooks has experienced an error on startup
Step one is run scandisk. If you have a cross linked or corrupted file it will sort that out automactically. Step 2 is to google "where is the quickbooks repair feature".....odds are someone has used it before. Step 3.....save your Quickbooks database (in at least two places) and delete and reinstall Quickbooks if all else fails.
Posted on Jan 24, 2008
QBPOSScott
  • 237 Answers
SOURCE: Quickbooks error ~~ transfering files from 2003 to 2009
There may be more than one issue going on here. In some cases, going to a version that is several versions later requires a stepped upgrade. 2003 to 2004, 2004 to 2006, then to 2009. There may also be data damage existing in the 2003 file that will prevent an upgrade, until it is resolved in 2003.
Intuit used to have a policy that it would have you send in a copy of the data file and would convert it for free if you were going to the latest version.
If you are still unable to resolve this, let me know.
Posted on Nov 16, 2008
  • 32 Answers
SOURCE: Problem loading Quickbooks
Hi Mike,
First try reboot your machine, in case an update required a restart.
If that doesn't fix the problem, the next step would be to go to the task manager (Ctrl/Alt/Del) and go to the processes tab. Scroll down to QBW32.exe, highlight it and then click End Process (at the bottom right), then click file and exit.
Restart quickbooks from the icon by right clicking and clicking open. Do this only ONCE, hit it more than once will make Quickbooks attempt to start multiple times. Give the program time to launch.
If this doesn't work find the reboot.bat file (do a search for this if you can't find it in the quickbooks folder) - double click on it to run it. Once that is complete try again to restart Quickbooks.
If you are still having trouble you can try a a repair of quickbooks (2006 and higher). Go to the Control Panels, add remove programs, scroll down to quickbooks and click on Change remove button, choose the repair option.
If this doesn't work, you will need to do a clean install - (be sure to copy your quickbooks files to a remote disk or into another file (my documents would be a good place to put them if you have to put them on your hard drive) - If you get to that point ask about doing a clean install and I will be happy to walk you through it -
Posted on Feb 06, 2009
computerdeb
  • 323 Answers
SOURCE: Quickbooks accounting software fatal error
have you tried to verify and repair your database?
http://support.quickbooks.intuit.com/support/pages/knowledgebasearticle/1002282
Posted on Mar 15, 2010
boatadjare
  • 195 Answers
SOURCE: How to load data base into quickbooks pro so it is
From there, it's easy to invoice clients in a few clicks so you won't miss any ... Based on 2008 survey of QuickBooks Pro & Premier customers who expressed an opinion ... Easily transfer your existing data file into QuickBooks 2010. ... Quicken 98 through current version can be transferred to QuickBooks 2009. ...
quickbooks.intuit.com/product/.../small-business-management-software.jsp
Posted on Jul 16, 2010
Quickbooks error code 6000 80
The error -6000, -80 typically occurs when you are using your company file over a network and its data is either converted or restored. To resolve this error you may use "QuickBooks Company File Diagnostic Tool". In a case if you still have issue with accessing your QuickBooks file then you can try a third party QuickBooks Recovery tool to repair your corrupt file. QuickBooks repair software
Sep 19, 2013 | Office Equipment & Supplies
Error message 1324. The path My Pictures contains an invalid character. Version 2.5.2.36 Can I remove? Can I update so my Quickbooks program can update? Need help please!
There are 3 possible reasons why you are getting this error message:
1. An invalid character in QuickBooks installation path.
2. An incorrect path setting in the Windows registry.
3.Insufficient hard drive space available to install the QuickBooks program.
To fix this problem, please do the following:
  1. Restart your computer, and reinstall QuickBooks.
  2. Confirm that at least 2.5 GB of disk space is available for installing QuickBooks (Quickbooks 2010 requires 1.5GB of disk space):
    1. Double-click the Computer (for Windows 7 or Vista) or My Computer (for Windows XP) icon on your Windows desktop.
    2. Note the amount of free space shown in the window next to the drive letter where QuickBooks is being installed:
      • If the amount of free space is less than 1 GB, free up disk space before installing QuickBooks or install QuickBooks on a different drive.
      • If the amount of free space is greater than 1 GB, proceed with step 2.
  3. Remove invalid characters from the QuickBooks installation path:
    1. Right-click the Windows Start button and select Explore.
    2. Navigate to the path shown in the error:
      • If there are non-alphanumeric characters in the name of any folder in the installation path, right-click the folder and select Rename to remove them, and then reinstall QuickBooks.
      • If there are only alphanumeric characters in the installation path, proceed with step 3.
  4. Create a new user in Windows to rewrite any Windows registry settings that may be causing the error and log in as that user to install QuickBooks.
Note: You must be logged in as a Windows administrator or as a member of the Administrator group to add a new user.
If this solution does not resolve the issue, you can read discussions and post messages and questions relating to your issue on the Intuit QuickBooks Community site for free, or you can contact a technical support agent for additional guidance. Fees may apply.
Nov 30, 2012 | NTI Backup Now EZ
I am installing quickbooks 2011 Pro and keep getting Error code 3371 status code 1
The 3371 error means that the software couldn't read the license information. possibly due to an incomplete install. You need to reenter the license; you may need to do a full uninstall and reinstall. Have the license available before starting.
First try just deleting the license file:
Close Quickbooks if it is open. Depending on your OS, search for the hidden folder with the license file and delete EntitlementDataStore.ecml . (You may need to enable viewing of the hidden folders. This is accessed via the File Explorer. Double click the Computer (My Computer in XP) icon (or Start > Control Panel > Computer) to open the explorer. Click on Organize and go to the Folders and search options. In the View tab, select Show hidden folders.) For Windows Vista or Win 7, search for C:\ProgramData\Intuit\Entitlement Client\v6.0 . In XP, you need the folder C:\Documents and Settings\All Users\Application Data\Intuit\Entitlement Client\v6.0 . Just select the file and choose delete then confirm the delete command. Launch Quickbooks and follow the on-screen directions for registering the program.
The MSXML 4 software may be damaged or missing. This program is on the CD; however it may be better to download it from Microsoft, http://www.microsoft.com/downloads/details.aspx?FamilyID=7F6C0CB4-7A5E-4790-A7CF-9E139E6819C0&displaylang=en . Try to repair the software with the command msiexec.exe /fvaum "%userprofile%\desktop\msxml.msi" (then press enter) with the above file saved to the Desktop. (Click Start or Start > Run, depending on the OS.)
If the repair doesn't work because the program isn't installed, install with the downloaded file. Otherwise uninstall it (Start > Control Panel > Programs > Uninstall) and then reinstall first the MSXML 4 and then Quickbooks.
If the above step doesn't work, then you need to uninstall Quickbooks completely. First uninstall Quickbooks from the Uninstall Wizard mentioned above. Then run the Clean Install Utility from Intuit, https://www.quickbase.com/up/bd9yykidd/g/r9/eg/va/QuickBooks%20Clean%20Install%20Utility.exe , to remove any information from the program that was left after uninstalling. Reinstall Quickbooks after clicking OK when the program says Quickbooks is ready for a clean install.
You could manually rename the installation files instead of using the Clean Install Utility but that would clutter your hard drive.
I hope this helps. Let me know if you need any help; if you do, please add a comment with your OS.
Sep 19, 2012 | quickbooks.com
Hello I am not able yto get into quickbooks
If you were able to open the Quickbooks before then you can try these steps:
Run reboot.bat to register QuickBooks files in Microsoft Windows:
  1. Open the folder containing the reboot.bat file:
    • Windows 7 or Vista: Right-click the QuickBooks icon on your desktop and select Open file location.
    • Window XP:
      1. Right-click the QuickBooks icon on your desktop and select Properties.
      2. Click Find Target.
  2. Double-click the reboot.bat file.
  3. Restart the computer - Reopen Quickbooks.
If these would not work:
You have to reinstall Quickbooks.
Hope this helps!
Good Luck!
Mar 17, 2011 | Intuit QuickBooks: Pro 2005 for PC
I have QuickBooks Pro 2005 and was able to easily export to Excel. That is no longer an option and I have to export to a cvs file. What happened and how do I fix it?
Open QuickBooks. At the top of your screen to the right you should see two black arrows next to your ICON's that say things like reminders, search and feedback. Do you see the arrows? Click on them. This will take you to another screen to add or subtract your ICONs or shortcuts. Click "add" and then scroll the options until you see "Export to Excel" and choose it. Then hit "ok" and close the boxes until you are back on your desktop.
Jun 17, 2010 | Intuit QuickBooks: Pro 2005 for PC
Hi Mike,
Jan 29, 2009 | Intuit QuickBooks® Pro 2006 Full Version...
Went to open Quickbooks pro 2008 and received an error code of 80029c4a. It also said there was an error loading type library/DLL. Any solutions? Thanks
Update your Quickbooks, run reboot.bat, restart your computer and then restart Quickbooks
  2. Windows Vista: Right-click the QuickBooks icon on your desktop and select Open file location.
  • Window XP:
  1. Double-click the reboot.bat file
Jan 06, 2009 | Intuit QuickBooks Pro 2008: Windows
Quickbooks Pro 2008 will not load
Have you tried repairing the program? Go to control panel, add/remove programs. Scroll down to Quickbooks, click on remove. It will give you the option to remove or repair. You might need to have your CD hand in case it prompts you for it.
Dec 07, 2008 | Intuit QuickBooks Pro 2008: Windows
Intuit QuickBooks Premier 2008 (3-User Pack): Windows Logo
195 people viewed this question
Top Intuit Computers & Internet Experts
Alun Cox
Chris Larocque
Dan Shibata
Dan Shibata
Are you an Intuit Computer and Internet Expert? Answer questions, earn points and help others
