Question about NetGear WGR614 Wireless Router
Netgear router DG834GT
HOW DO YOU INSTALL SOFTWARE DISC TO AN APPLE COMPUTER,HAVE PUT INSTALATION DISC IN BUT CANT GET IT TO RUN EVEN BY CLICKING ON AUTORUN.EXE,I WANT TO SET UP A NETWORK PASSWORD TO PREVENT ANYONE ELSE USING MY WIRELESS CONNECTION TA ARTHUR
    Sergeant:
  • 221 Answers
To do this you do not need the installation disk.
1. Click Start, Run, CMD, enter. Type 'ipconfig /all' and write down or remember the ip address for your default gateway.
2. open your browser and type http://192.168.1.1 (or whatever the ip address is for your default gateway.) hit enter.
3. In the username and password login screen type admin for both. If this doesn't work, try using admin for just the password, if no luck try again for just the username, until you are logged in.
4. Go to wireless settings, security, and find the part where you can set your wireless password. It is also a good idea to use wpa personal instead of wep, because it is a stronger encryption method.
Posted on Apr 20, 2008
HOW DO YOU CONNECT A BLACKBERRY PLAYBOOK TOA NETGEAR DG834GT ROUTER?
Connect a LAN cable from the Netgear to the LAN port on yourcomputer, open a browser and enter the Netgear configuration URL -
http://192.168.0.1
The default login = admin
The default PW = passwordYou can now change the default admin password and configurethe wireless settings.
Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.
Now apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Jun 15, 2012 | Computers & Internet
How do I disable my DG834GT router firewall?
The router firewall only blocks connections coming from the internet.
Basically it only lets an outside IP connect to your network if you establish the connectoin FIRST.
The most common cause of not being able to see another PC on the LAN is not having the same workgroup name.
Go to Start > My Computer , right click > Properties > Computer name. Make sure all PCs have the same workgroup name.
Mar 05, 2009 | NetGear DG834G 802.11G Wireless ADSL...
Connecting to http://192.168.0.1
You need to use the desktop computer to access the Netgear page. Check the default gateway address of your desktop (this is the IP address of your Netgear). You may follow these steps if you don't know how to check the IP address of your desktop:
1. Go to the Command prompt or DOS prompt. Type in ipconfig and press enter. Check the Default Gateway address.
Oct 12, 2008 | NetGear DG834G Router
How do I install a netgear adsl modem router dg834gt
no you can't use the belkin usb 10/100 ethernet adapter CD to install the netgear adsl modem.
click here to download the installation manual for the netgear device
Sep 09, 2008 | NetGear DG834G Router
Connect netgear DG834GT to laptop - says limited connectivity
how do i connect the netgear dg834gt to my computer please help
Jun 29, 2008 | NetGear DG834G Router
Netgear ADSL super G wireless router
I hope this will help you to solve the problem...
http://www.jjclements.co.uk/index.php/2007/09/30/sky-router-dg834gt-unlock/
Apr 27, 2008 | Computers & Internet
Cant connect to cable
Hi Snuggles,
Make sure your networking permissons are setup properly, on the Vista. Since it varies with what version Vista you have, try this link.
http://windowshelp.microsoft.com/Windows/en-US/default.mspx
Great help site for Vista. Click on the Network tab, follow the info to setup your networking, and if you are still having issues, got to the troubleshooting. Please make sure you doing your setup with a cable, too, not over the wireless.
Good luck
Jan 10, 2008 | NetGear DG834G Router
Lost network password which I need to sign on an ipod touch using a netgear dg834gt
Key 1 should work in most cases. If you have additional keys listed, try them also.
If none work, turn off encryption and connect your new device, then create a new password.
The manual page is here:
http://kbserver.netgear.com/kb_web_files/n101675.asp
Nov 19, 2007 | Computers & Internet
Netgear router dg834gt
Have look in the router settings for the actual internet connection speeds, as these are a more true reading than the speed check as the speeds can vary at different times of the day and 2 or 3 speed checks can bring different results. your actual connection speed that is showing in the routers settings is the connection you are getting from your ISP. If you are with BT they usually recommend using their latest routers, why i'm not sure, as the only thing i have noted is that the MTU is set at 1500 (Maximum Transmition Units)and in other routers the MTU is automatically set at 1493, so look for the MTU setting and up it if necassary, but not above 1500, also double check all the settings, even put the bt router back in and see if speeds improve, if, you know the BT router is set up purposly for faster connection speeds. Also try checking your speed at a speed test site at a quieter time of day, you will also see different speed check sites give you different speed results.
Jun 18, 2007 | NetGear DG834G Router
NetGear WGR614 Wireless Router Logo
66 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
