Hi. I have a ST6400S HONEYWELL PROGRAMMER and cant reset it after my boiler service so I can only have my heating on for an hour at a time!! can you help?
  • 1 more comment
  • fletch65 Apr 18, 2008
    SNAP - same problem ! looking on internet but haven't found anything - if I do I'll let you know.
    Sounds like this model is used by landlords and prevents overdue services and recommeds that honeywell reset it ( at a cost of course ) but we have it in a normal everyday house - surely we don't need honeywell just to reset !
    Liz
  • patch04 Jul 12, 2008
    The manual refers to special key sequence that is required and refers to a leaflet EN0R8542 which surprisingly does not come with the main manuals. Very dissapointed if i need to get a honeywell representative to come out, as it will be cheaper to replace the unit completely. What a con!
  • Anonymous Feb 19, 2009
    please can anyone help as anyone got the sequences
The only way to get the key sequence is to contact honeywell tech support, they will give you the sequence over the phone as long as you are a contractor (or pretend to be one), but they will not send out any literature on it. If you live in an owner occupier dwelling then it has been fitted by mistake, and the best thing is to replace it.
Posted on Sep 10, 2008
Hi - I have a sort of solution !!!!!!!!!!!
take if off and smash it and replace it !!
I went to our local electrical supplier and asked about this problem and he said that he'd had lots of people complaining about this issue and many many more. The builders who fitted it didn't know about the problems but electrically wholesaler's did !
We now have a Danfoss which fits nicely over the backing plate so no big holes in the wall and works a treat - there is an option to set it for landlords on this new one but you have to contact them and ask them to come out and set it up - NOT the other way around.
Sorry it's not the answer you wanted - but we took the unit the bits to see if we could get around the prob but couldn't !
regards
Liz
Posted on Apr 19, 2008
Hi, I have a drayton lp522 programmer with a
go to boiler Disconnect red line and jump out White and red line at boiler if the fires reconnect red line and replace thermostat
Sep 23, 2013 | Heating & Cooling
Hi, I am having problems with the timer that controls my boiler. It is a 'Lifestyle LP522'. The hot water is set to come on in the morning for 4 hours and again at 4pm for 3 hours. The heating is...
then there must be a problem with the programmer as the boiler thermostat will call for heat only if the programme is on try setting the water side to 24 hrs it won't cost any more to run , but will prove if programmer is working .
Mar 07, 2017 | Heating & Cooling
Honeywell T403A1174 suddenly doesn't appear to call for heat
some times inside the boiler on the internal pipework you will see little sensors, on the central heating piping there sometimes is a thermastic sensor on side of flow pipe with a little reset button on ? i guess with the problem you said the poiler locked out and the pipe work overheated ? this is a safety feature on some boilers not, all and easerly reset via this button ?
Jan 31, 2009 | Honeywell Water Heaters
Replacement of heating programmer
yea you should be able to just when you remove the old one mark witch wire went to witch connection by marking it some how i personaly take one wire at a time wrap it with a small piece of white tape and write the letters on the piece of tape then when i replace with the new one i cant mess it up also look for any of the wire connections to see if any have to be or have been jumped out
Nov 14, 2008 | Honeywell Water Heaters
Oil fired boiler
Check how all three "on/off" sequences are programmed firsrt, then all other programmable options. Make sure sliders are in the sliders are in the correct possition. If it becomes more complicated than launching a space shuttle, reset it. Unless your house is a mansion keep it simple with just day and night modes. the money you save wont even cover the cost to fix the hole you punch in the wall trying to do fancy programming ;-D
Nov 24, 2017 | Honeywell Programmable Thermostat Heater
Cant turn heating off
do you have a separate or built in programmer? if itis separate ISOLATE MAINS undo the screws on the bottom of programmr and checkthat ther are no loose wires ( make a note of where they go for future ref. ). If wires OK check that the valves are working switchoff HW and Heating switch one on at a time and check that each valve is opening and closing and that the boiler and pump fires up ( it could b the micro-switch in the valve is broke! )
Sep 06, 2008 | Honeywell Programmable Thermostat Heater
Honeywell ST6400C programmer
Hi yes sound like it not working on hot water only it would check ou the wiring on this side
Jul 25, 2008 | Honeywell Programmable Thermostat Heater
Honeywell junction Box and QE2 Programmer
Hi check the wiring to the cylinder stat is there power to it then is it going to the valve
May 15, 2008 | Honeywell Programmable Thermostat Heater
My boiler keeps firing up even when the Honey well programmer is in the off position. The programmer is about 7 years old.Do I need a new one, a new battery for it or is it to do with the boiler (oil)...
I had the same problem. I traced it to the micro switch in the water/central heating motorised valve having shorted out.
I replaced the (Honeywell) motorised valve and it is now only running when it should.
Jo
May 01, 2008 | Honeywell Electronic Programmable...
Heating & Cooling Logo
606 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
