Brother MFC-420CN All-In-One InkJet Printer
Problem for Brother MFC-420CN All-In-One InkJet Printer
Not printing
By jeromecres on Apr 15, 2008
I changed to brother inks, printing in cyan only and the other parts of the page is not printing, black not printing at all, cleaned, all the tips I used, ready to never buy a brother,
Comments:
Apr 21, 2008
- I was sold another ink in the mall for the printer and , yes, it never worked since. It was only the black. The other inks was brother's ink.
I have since cleaned out the ink from the viens, but could not get to the head, any help of cleaning the head.
But I have used other printers, with the mall inks and it has worked, well, I have learned my lesson.
As for Brother, I wish they will, introduce one black and one for color, cost wise for overburdened cost for inks.
Thanks for the feed back.
Apr 23, 2008
- Is there a cleaning kit for the Brother MFC420cn...if so, please let me know.
Same Problem
Oct 22, 2008
-   Those cheap chinese aftermarket printer cartridges ruined my printer, all i can print is color no black, i have a brother mfc-420cn -   Guest
Apr 18, 2008
-   my printer is not printing black. it prints like image but not writing. also yellow keeps saying ink near empty. i cleaned it 10 ttimes i put in new ink and still cannot get it to work.
My email is nyminute05@aol.com Thank you-   nymub95
Apr 16, 2008
-   we have cleaned it ,it will only print half of the page in black only the part of the page blank,sometimes it will only print and it will skip on the other page
thank you karla lalonde
-   Guest
Best Solution
posted on Apr 21, 2008
Helpful)
Soulvisitor
Rank: Guru  Brother Computer Hardware  Expert
Rating: 88%, 2384 votes
I can tell you all without a doubt in my mind you all have been using "cheaper" inks, wont matter a bit now if you put real brother ones in, it is too late the contaminated, incorrect ink type or particle size ink, is in the veins(ink tubes) of your printer and have reached the head which is now blocked. You cant fix blocked brother heads, and they are too expensive to replace.
You don't notice you stuffed your printer with dodgy ink till it is too late, sure they work sometimes, but what you find most of the time is that after a while about 1/8 of a cartridge of use, your new dodgy inks travel the veins until they inject poison into the head and stuff it forevermore.
Expect without a doubt in your mind any modern inkjet printer fitted with dodgy ink will not see 2 years old.
I see thousands of machines broken from block heads, the only old printers I've seen are uses of nothing but manufactures product.
I not selling you a machine, brand or supplies, just telling you how it is.
Refill and aftermarket ink will always cost not save you money.
unless you can find a supplier of such inks/toners to fix it free when it breaks from their supplies or guarantee you a refund of repair costs if found to be due to their product.
Comments:
Apr 23, 2008
- Guest ...Throw in bin due to stuffed head and it is too late the contaminated, incorrect ink type or particle size ink, is in the veins(ink tubes) of your printer and have reached the head which is now blocked. You cant fix blocked brother heads, and they are too expensive to replace.
jeromecres on very rare occasions will one ever unblock a brother head. Sometimes like 1/1000 a power purge with brother ink gets the hunk of junk out of the way of the flow to the electronic heater element that fires the ink particle in the head.
Press the Menu/Set, Black Start, Menu/Set, and Black Start keys in this order to enter maintence mode then 76 set 4 set 1 set... i think , display should read after entering 76 "cleaning", then you want "init" purge, then "all" ..... if you aint got number pad use arrows to change digits.
Watch what you are doing my numbers may be out of order ie 76-4-1 might be 76-1-4 .
THATS IT ALL OF YOU FUTURE BROTHER NON GENUINNE INK USES WHO HAVE STUFFED THE HEAD ON A TWO BOB PRINTER. throw IT IN bin !!!
USE REAL INK NEXT TIME.
BETTER STILL PRINT WITH TONER AKA LASER BASED MACHINES... HEAPS CHEAPER RUNNING COST (use NON REFILLED IN THOSE TOO)
THE 420 IS THE SAME ENGINE AS
MFC620CN/425CN/420CN/410CN/215C/210C
DCP315CN/310CN/120C/117C/115C/110C
and FAX2440C SO LOOK IN THOSE THREADS TOO.
99 exits Maintence mode........
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Apr 22, 2008
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I just changed my black ink with the correct ink but printer is not printing any thing . I just get blank sheets. What do I do
Solution #3
posted on Nov 23, 2008
Not Rated)
jbaley779
Rank: Apprentice
Rating: 0%, 0 votes
Before i gave up and threw my MFC210c away, I used an ear syring like a toilet plunger on the jet where the ink enters the printer from the cartridge. This cleared up my problem with cyan printing. I do use aftermarket ink in three MFC machines. The cost savings is woth the risk to me.
Was this helpful?
Yes
No
Popular Solutions for Brother MFC-420CN All-In-One
Questions and Unsolved Problems for Brother MFC-420CN All-In-One
Do you recommend Brother MFC-420CN All-In-One InkJet Printer?
Answer
Answer
I try to print something, the printer jumps to the task, pulls on the paper, and stops, message says... (More)
Answer
print has rather quickly faded to almost nothing. only prints 1 color now. cartridges have ink. I... (More)
Answer
How do I set up the 420CN to print all the frames of a web page? Right now it prints the graphics... (More)
Answer
Brother 420CN printer will not print black ink. Have replaced the cartridge and after several... (More)
Answer
trying to connection MFC 440 printer via bluetoot, but on pc I cant find the printer through... (More)
Describe your Printers problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Printer Experts
Top Printer Repairmen
in , IL
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(918) 583-5483
Elite printer Services, Inc. is a full service HP...
Elite Printer Services
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
