I'm running 10.4 on a mac titanium notebook trying to hook up an HP4550 using ethernet. I've downloaded the latest drivers for the HP4550 and installed the printer using the Add Printer utility in the System Preferences. I've identified the HP printer with the IP address. But when I go to print the Mac cannot connect to the printer. What am I doing wrong? Have I left out a step?
  • 81 Answers
Open the Printer Setup Utility in System Preferences:
  1. In the Printer List window that opens, click on the Add Printer button.
  2. A new window shade will appear:
  3. Make sure that the IP Printer tab at the top of the window is selected (instead of the Default Browser tab).
  4. Make sure HP Jet Direct - Socket is selected in the Protocol pull-down menu.
  5. In the Address field, type the queue name (e.g., plib3a). When you have finished typing the queuename, the message "Incomplete or invalid address" will disappear or may be replaced by "Complete and valid address."
  6. Leave the Queue Name field blank.
  7. Type in where the printer is located in the Location field.
  8. From the Print Using pull-down menu, select the printer manufacturer. A new area with a list of possible models will appear. Select your printer model. If the printer's model is not listed, select Generic in the Print Using field.
  9. Click Add.
  10. Depending on the printer added, a Printer Browser window may appear. If you have a duplex printer, check Duplex Unit. Leave all other fields unchanged and click Continue.
  11. The window shade will disappear, and the new printer will appear in the list of printers in the Printer List window.
  12. The new printer is listed by its queue name. This can be cryptic especially if you have many printers listed. You can change the name of the printer by:
    1. In the Printer List window, click once on the printer to select it.
    2. Under the Printers menu, select Show Info.
    3. A Printer Info window will appear. Change the name of the Printer in the Printer Name field.
    4. Click the Apply Changes button.
    5. Close the Printer Info window.
  13. From the Printer Setup Utility menu, select Quit Printer Setup Utility.
Posted on Apr 15, 2008
  • Chris Doty
    Chris Doty Apr 15, 2008
    This is in reference to #2
My ibook won't connect to the intervet via airport or the ethernet
In your stage you can do this simple things.1. update your software call SOFTWARE UPDATEif the problem with network drivers after this step will solved it2_14_2013_7_00_24_am.jpg
2. Still the situation same... Reinstall with Install and Restore disk which came with the iBook (OS X 10.3 or 10.4).
Feb 13, 2013 | Apple iBook G3 Mac Notebook
Where can I find Acer 661fx-m71.2a ethernet controller? can anyone give me links?
http://download.cnet.com/intelv13-zip/3000-2112_4-195759.html
  • Intel 82557-based Integrated Ethernet PCI (10/100)
  • 82557-based Integrated Ethernet with Wake on LAN
  • Intel 82558-based Integrated Ethernet
  • Intel 82558-based Integrated Ethernet with Wake on LAN
  • Intel(R) PRO/100+ PCI Adapter
  • Intel(R) PRO/100+ Management Adapter
  • Intel(R) PRO/100+ Server Adapter
  • Intel(R) PRO/100 Network Connection
  • Intel(R) PRO/100 VE Desktop Adapter
  • Intel(R) PRO/100 VM Desktop Adapter
  • Intel(R) PRO/100 VE Network Connection
  • Intel(R) PRO/100 VM Network Connection
  • Intel(R) PRO/100 VE Desktop Connection
  • iSeries 2892 10/100 Ethernet Port
  • Intel(R) PRO/100+ Alert on LAN* 2 Management Adapter
  • Intel(R) PRO/100+ Alert on LAN* Management Adapter
  • http://download.cnet.com/intel82573l-zip/3000-2112_4-165111.html
  • if these arent right you will find ethernet drivers and more
  • http://download.cnet.com/2000-20_4.html
  • on the home page you should see a search tab just type in what you are looking for
    (be precise)but don
  • Oct 04, 2011 | EliteGroup 661FX-M7 (661FXM7V11)...
    Installed a new hard drive but can not locate the ethernet drivers for the Acer Ferrari 3400
    Go here http://us.acer.com/ac/en/US/content/drivers
    Select Notebook > Ferrari > 3400 > select your Windows and all the drivers will appear- get the LAN one.
    Jul 23, 2011 | Computers & Internet
    I've got a BT HomeHub which works fine with a 4-port Ethernet switch to give me a small home network of 1 Mac Pro, 1 Laptop and 1 printer. I have an older Netgear RO318 Router - with 8-ports. But when...
    When you use the older Netgear RO318 Router, make sure you don't use the WAN/Internet port, only use the numbered switch ports of the router.
    Jul 31, 2017 | NetGear RO318 Router
    My safari crashes on my laptop after about 10 seconds. I've tried several times. I've also tried to download again. I have a Macbook Pro, OS version 10.5.8, Processor 2.4 GHz, Intel Core 2 Duo,...
    The first thing you should try is resetting the PRAM, this can be done by following this guide.
    Then use the Finder to view your User/Library/Cookies/ folder, and drag the Cookies.plist file to the trash. now try Safari again.
    If that cures the problem, then we know the cookies file was the reason.
    Unfortunately you may lose various website settings and passwords, that were stored in the cookies.
    If the problem still persists after this I would try calling apple support.
    Jun 03, 2011 | Apple MacBook Pro PC Notebook
    I need a sound driver, ethernet controller for my ibm thinkpad r50
    Assuming that your Operating System is Windows XP I have given you the details to download the drivers. Visit the link: http://www-307.ibm.com/pc/support/site.wss/MIGR-53178.html
    Scroll down to Networking: Ethernet section
    Intel PRO/1000 MT Mobile Connection adapter (10/100/1000 Ethernet) - Click on 8 Feb 2007 - Build 135400 In the next page click on 7ira09ww.exe and download
    If your Network Adapter is Intel PRO/100 VE Network Connection adapter (10/100 Ethernet) then click in the other link Build 94590 (Build 94590 supports models with Intel PRO/100 VE Network Connection adapter (10/100 Ethernet) only. In the next page download 1urc13ww.exe
    Apr 26, 2011 | IBM ThinkPad R50e Notebook
    Hi,I m using windows7 on macbook 3,1, but my webcam & blue tooth not found in system. there is apple builtin cam, i try to download the drivers but cant.help me plz
    You should just need to insert your OSX disk maybe snow leopard, then install bootcamp drivers from it also run apple software update, from the start menu or programs. install the latest free updates and you should be good to go.
    kev
    Feb 21, 2011 | Apple 13.3 MacBook Intel Core 2 Duo...
    Dell Inspiron 1525 not connecting wirelessly to Sky broadband
    If your wireless router is configured with SSID, encryption, MAC address filtering (if enabled) etc. then the Dell wireless card needs to be configured with these settings to allow it to communicate with the wireless router.
    Check the settings on your PC's wireless settings, and configure the Dell the same way.
    Sep 08, 2009 | Dell Inspiron 1501 Notebook
    Wanted to install a MacOS X... can it work???
    Mac OS X won't run on your pc... you can however run windows on a mac now... the latest generations of macs will allow you to run both systems... pretty cool .. sorry it won't work the other way...
    May 28, 2009 | HP Compaq 6720s Notebook
    Ethernet controller on my laptop
    Go to the IBM/Lenovo WEB site - support/download page and download the latest Windows XP or Vista device drivers for your model laptop,
    Use this link :-
    http://www.ibm.com/products/finder/us/finders?pg=ddfinder&cm_re=other-_-suprcn-_-download
    After you download the driver file, click on this file and it will unzip/expand the drivers and copies the files to the hard drive in c:drivers... take a note of the folder it has created to store the driver files and then go to this folder and run the SETUP file.
    Apr 19, 2009 | IBM ThinkPad A21m 2628 Notebook
    187 people viewed this question
    jasbo
    jasbo
