Hi:
This message is and indicator that the heat exhaust fan is failing. this fan removes the heat produced by the lamp. I suggest you just replace the fan entirely. Vacuuming it will not solve your problem as the bearings in the fan assembly is faulty. The fans sense wire is reporting to the main system control board that it is not turning at the right speed to keep the unit at a safe heat level.
I got the same problem as Brenda1717 with my Samsung 650 series. I open up the back cover and clean the fan, it worked for a few hours. just turn the TV on again after turning it off for a couple of hours, the message appears again and kept turning itself off after a few minutes. I guess, cleaning it will only work temporary and have to replace the fan.
You need to test the fan if it is working or not or better replace the fan with a new one.there must be shortage of voltage coming from the fan thats why the unit turn itself off.over heating of components near the fan might be the cause because your fan is malfuntioning thats why you got a keep getting the message check the fan better replace it..
I went on and did an online chat and the guy told my husband what to do. I had to pay $20 for him to do that so I guess I don't need this assistance. Thanks
