E7-00 code with sharp copier, still
Where do i look for the white wire connecting to the control panel
  • 19,396 Answers
I gathered more info on E7-00. The exact code meaning is : no comm to hard disk . The problem with e7-00 should is on disk side, remove the plate, as in picture I have posted, and check cables to disk, as in picture.
If is is not the cable then you need to pull out the hard disk and test on a computer, or have it tested, If the disk is gone, you will need to replage the hard disk. it should be a 40gb Sata hdd. It is not an expensive replacement, and is also easy to find, the problem is that after this you need to reinstall software on disk inside machine.
You will probably need an image disk. I do not think there is a download available, and Sharp distributes it only to authorized services.
Posted on Apr 15, 2008
ERROR CODEE7-10
E7-10 Shading trouble (Black correction)
The CCD black scan level is abnormal when shading. Improper connection of the CCD unit flat cable CCD unit abnormality MCU PWB abnormality. http://www.printcopy.info/?l=en&mod=free&chap=erc&brand=Sharp&model=AR5320
upon on extra research I've found that this problem was once solved by tightening any loose panels and screws...
Thread Sharp ar5320 error code e7
Sep 23, 2015 | Sharp AR-5320 Black and White Copier
ERROR CODE H5-01
Make sure you get all of the paper out of the machine that's jammed in it. Then you have to clear the H5-01 by doing the following at the machine's control panel:
touch P * C *
14 - then the black and white start button
Execute
Yes
the machine will reboot and it should clear the code as long as the jammed paper was removed!
How To Sharp Copier Printer Scanner Instructions Troubleshooting...
Feb 05, 2014 | Sharp Mx-3501n Color Copier Printer...
Sharp mx-350n will not print in color from the network
Which model is it? The MX-350N is black and white, the MX-3501N is a color model. I'll assume it's the MX-3501N.
Either it's defaulted to print B&W in which case you just go to your printing preferences of the print driver in the printers menu in the control panel, and uncheck the "black and white print" box, or you have account/user codes that you need to enter in your print driver in order for it to print color. Instructions for adding a user code to the printer driver are found here.
Setup and Manage User Codes Account Control on Sharp Copier
Feb 03, 2014 | Sharp Mx-3501n Color Copier Printer...
Sharp Mx-M350U shows L04-02 service code
L4 -02 cause Drum motor trouble
Improper connection of harness between the
PCU PWB and the drum motor.
Control circuit trouble
Dec 29, 2010 | Sharp AL-1457 Black and White Copier
H2 problem sharp AR 5516
sharp ar5516 showing code f2 or h2
Jan 14, 2010 | Sharp AR-5320 Black and White Copier
SHARP CONNECTED TO A NETWORK THROUGH A PC BUT USERS ARE NOT ABLE TO PRINT USING IT
Did you mean shared trough a pc ? If yes each of the users must have the driver installed. Make sure the copier/printer is shared and do not use the account control function
Jun 24, 2009 | Sharp AR-5320 Black and White Copier
Problem with sharp ar 5320 copier
Sounds like a bad earth or loose connection. Try using the parrallel port instead, or take the panel off and look for bad connection
cheers
Nov 29, 2008 | Sharp AR-5320 Black and White Copier
No power
plese you press the copy key an error code will blink tell that error code
Sep 11, 2007 | Sharp AR-153E Copier
94 people viewed this question
jasbo
jasbo
