Question about LG DLE2532W Electric Dryer
Loud Thump each time the Drum Rotates
It looks like I'm at least the 2nd person with this similar problem with this model. My only guess is that maybe too heavy of a load was dried once or twice and now this loud thumping noise is a constant. Each time the drum turns, it sounds like a brick is falling inside the drum.
Can anyone let me know what this really is and how it can be fixed?
  • 2 more comments
  • Scubafreak Apr 15, 2008
    still need help on this problem.
  • y2k_ready Oct 28, 2008
    i have the same problem. it's always been noisy and finally the drum separated. trying to get LG to cover in warranty since it was a defect that should have been recalled. the guy who wants to service it says he has replaced several defective drums. this dryer is a pricey piece of junk, i've already had the thermal safety switch replaced out of warranty - probably because the drum was begining to separate and lint was going in the seam insulating the switch and causing it to overheat. good luck.
  • vickdor Nov 19, 2008
    I have the same problem...but aslo the sound is the worst at start up - the entire dryer shutters to start. I called serveral repair shops in the area and none of them will service LG applicances. I was told that they are inferior products and difficult to get parts for....so I am still looking for someone to repair - of course it's out of warranty
  • Anonymous Nov 30, 2008
    I have the same problem. I think it may be a guide wheel with a worn out bearing. Won't know for sure till I take it apart.
  • 489 Answers
You have a problem with your dryer drum.  The seam weld has cracked and the drum needs to be replaced.  You will need to call a qualified LG technician to resolve this issue.
Posted on May 02, 2008
LG DLE5977W THUMP DRUM WAS CRACKED-REPLACED FROM APP.PARTS.COM NEW DRUM OUT OF ROUND.SENT NEW DRUM SAME THUMP.REPLACED ONE ROLLER I SAW WAS BAD-SAME THUMP.REPLACED OTHER THREE ROLLERS-SAME THUMP.HELP
Anything is possible but I doubt 2 drums are bad. Since you replaced all the rollers and I assume you installed the drum on the rollers properly, i would look at the other drive parts. It might be a bad idler pulley and bearing. That is the small pulley that is spring loaded and puts tension on the belt. Check the complete assembly for any unusual free play that might cause a thump. Also look at the belt itself for any cracks or bumps.
Mar 02, 2015 | LG Dryers
LG electric dryer model DLEO332W or DLE0332W
Sounds like the belt broke..."loud thump"
Sep 21, 2013 | Dryers
Our electric dryer sounds like it csme off trsck...drum turns freely and dries good,but when drum goed round it's like thump,thump,thump,thump... Rick THANK YOU
Hello Rich,
What your describing sounds exactly like one of the drum support rollers has a flat spot on it. Depending on your brand and model number dryer drumm rollers vary somewhat by are pretty much similar. Reply with your brand and model number and ill be able to give you specific info about your dryer
Sep 10, 2011 | Dryers
When i turn on the dry it is making a loud Squeaky sound. the dry is still heating, just making loud squeaky sound
Hi an welcome to FixYa, I am Kelly.
This squeaky sound your hearing is usually the idler pulley, idler pulley shaft, but also can be the motor or the drum roller bearings. Usually if the drum roller bearings are bad the dryer will thump as it rotates.
The idler pulley and lever is and assembly that is item 8 of this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5174194&diagram_id=28598568#d28598568
Since it is squealing at this time when you have the repairs done that you replace the belt that is item 21 this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5174194&diagram_id=28598572#d28598572
The motor is item 7 this link:
I recommend that if you do the repairs that you replace the idler pulley, the drum rollers, and the belt.
Drum rollers are item 17 this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5174194&diagram_id=28598572#d28598572 (make sure to check the drum roller shafts that are item 19 of the same link.)
While repairs are being completed also inspect the drum front and rear seals. Thare are items 14 and 26 (Same part number) of the above link.
By doing all of the above you should be able to get many more years of service out of your dryer.
If you need to purchase a service manual for self repair it can be downloaded here for $9.95:
http://allrepairmanuals.com/maytag-dryer.htm?model_number=MDE308DAYW
Thanks for choosing FixYa,
Kelly
Feb 15, 2011 | Maytag MDE308DAYW Electric Dryer
Dryer makes banging sound as drum rotates
The drum rollers are worn out and wobble when moving..it should be more of a thump/thump sound, unless really are almost gone...UNPLUG dryer and raise top...Since no model. i'm going with standard kenmore/whirlpool dryer type. The top has two screws by lint filter..Remove these and raise top...The front can be removed by removing two screws inside each front corner. The door switch must be disconnected at wiring..Remove front and set aside...The drum can be removed after the belt comes off...look down in right rear corner under drum..you will see the belt pulley and you want to see how it goes around pulley to help reinstall..remove belt, there will be tension and make sure you draw yourself a diagram of path of belt to ease install of belt....now once belt is removed, you can pull out drum...there are two drum rollers. They are bad if you roll them and they wobble and make noise. They should be almost quiet when you roll them if they are good..the belt roller can be bad and squeek...check this as well...replace parts and reinstall
Jan 31, 2011 | Dryers
LG DLE2514w electric dryer has loud thud every turn
Most model dryers are supported at thge rear of the drum with a bearing configuration, but usually the front of the drum is supported by some lining pads or guides. These help hold the rotation of the drum concentric. It sounds like your drum is not spinning concentric. My guess would be that some new guides might need to be installed.
Hope this helps...
Sep 02, 2009 | LG DLE2514 Electric Dryer
Making a loud thump sound
Frigidaire 5.8s dont have roller to support the drum instead they use a machined ball in back sat down in a plastic hub that is cupped to hold it in and covered in grease. the front rides on wear strips on the front panel felt pads. take front off and check these for excessive wear, cracks, etc. then take drum out (remove plastic hook at top center to give clearance) lift up at rear to take out of bearing cup.
if by some chance this is a 7.0 then you should still have a warranty
Jul 11, 2009 | Dryers
A new drum and rollers should have solved this issue. The rollers were upgraded to have a harder rubber consistency about 1 year ago. Ensure that the technician did not use old stock parts. The new, updated rollers should have a blue dot on them. As for a cracked drum weld, this would be a defective part. Make sure to call LG customer service to have the issue documented so that there will be a history. This way, even when your unit goes out of warranty they will have records of the service and the repairs should still be covered for sometime.
Nov 23, 2008 | LG DLE5977 Electric Dryer
Kenmore heavy duty
I can only assume by rollers you mean bearings were replaced. Unless your dad measured both the ID Fit of the bearing and the OD fit [ inside diameter and outside diameter of the shaft and housings] new bearings could be on the small side of their tolerance, [new bearings are made to be within a certain amount of "slop" if the new bearing was on the outside tolerance, and the shaft or housing was on the large side of the tolerance, the bearings are still allowing the drum to move, and thump.
OR if belt driven, the alignment of the belt is important, if one pulley is out, and the other in, one shaft will be pulling and the other pushing, again a thump.
Something in the bearing/pulley setup has not been discovered bad yet, it takes micrometers and some knowledge of bearing tolerances to resolve this kind of problem.
Think about it, what can thump in a dryer? The tumbler cage. It is most likely that the journal or housings are wore, second the motor may have a front or rear bearing/ housing the same thing, gone bad,
This machine is old enough I would expect to find a worn housing or shaft, either drum or motor,most likely drum, check the alignment of the belt also, but most likely the thump is not cost effective to repair, plus Dad's time which is invaluable.
Start searching the sale sheets, and reading consumer reports, time for a new energy easy dryer anyway.
Will
Sep 16, 2008 | Kenmore 63942 Dryer
ASKO t700 dryer thumping sound
usually whin you get one thump (or a quick double thump) you have a dent in the roller surface of the drum itself. Easiest way to check this is to unplug the unit and take the top off by removing the 3 torx screws in the rear, then lifting the top off. Once the top is off look at the very front edge of the drum as you rotate the whole thing by hand. If you see any irregularities on the surface, thats your problem. If you see nothing it could be a bad motor or roller, but its unlikely if its happening in the same place on the rotation evry time. What has usually happened with dents in the surface of the drum is that the unit was set down too hard (or dropped) and the wheels it rests on dented the metal they ride on. If thats the case the only solution is to replace the drum or live with it .Good Luck!
Feb 10, 2007 | Asko T700 Electric Commercial Dryer
LG DLE2532W Electric Dryer Logo
325 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
