Question about Philips HDRW720 DVD Recorder
HDRW720 will only do demo mode
If I do the test with the play-button while powering on, it shows fail 2100 02
What can that be?
  • 396 Answers
The error code has a Nucleus Group and Number followed by an Error Code.
The Nucleus 2100 references
DS_HDD_Communication
Check the communication between the digital board and the hard disk drive by querying the device type of the device type of the hard disk.
The Hard drive 282206200034 is no $399.80 available from partstore.com which you can just drop in since it is formatted. If you can find a hard disk which is rare due to the small size no one buys, it can be formatted to just drop it in. You will need the hard drive ( 120GB ATA), the PC communication cable 312278590017 $22.75 and the Service DVD 312278590710 $36.96 which will allow you to format the hard disk for the unit. I would do this for you but you might have other problems with the system which can only be found with more diagnostics after the drive is installed. Or it could be a drop in and go.
For the unit which is stuck in trade (demo) mode,
Unplug the unit.
Simultaneously hold the Stop + Open close while plugging in the unit.
Posted on Jun 24, 2008
Whay does my AIWA CA-DW63OU start playing by itself?
are you sure it's not going into demo mode after you turn it off? Is there just lights and display flashing? - that is demo mode. Probably a button on the remote to turn it off.
May 13, 2014 | Aiwa Audio Players & Recorders
Sony music hi fi system mhc-gzr88d show only demo not started
If only demo mode is playing,it's mean set is in standby mode.Normally
in standby mode it can't be operated.You have to power on the set by pressing power botton during demo mode.Once it gets power on,it will
start to work according to user required function.If the set not get power on after pressing power botton,then it's an electrical problem
and need to visit your nearby repairing centre.
Oct 17, 2012 | Sony MHC-GZR88D USB MINI DVD HI-FI SYSTEM...
I have a KDC-PM445U kenwood stereo and the problem is that it won't play any music, on the display it shows that it's reading the iPod or CD but there's no music. But when I play the radio then it plays...
Firstcheck whether it is still in demo mode. to cancel demo mode -- press [enter]when message flashes "to cancel DEMO mode press ENTER key" for 10-15 secs. Turn the control knob to "YES" and press ENTER key. If it still fails to operate properly press the rest button to return to factory settings(The reset button is behind the front console)
Dec 30, 2010 | Kenwood Kdc-mp445u Car CD / USB/ MP3...
My Philips HDR720 will not power up - clicking in power supply
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Apr 22, 2017 | Philips HDRW720 DVD Recorder
Can't get it out of demo mode; radio/cd changer won't come on. reads only welcome to sony and shows clock.
try holding down the mode or power button... another menu should pop up... also refer to manual
May 28, 2009 | Car Audio & Video
Philips HDRW 720/17 stuck in '':demo'' mode???
Okay. I found that there IS a manual release for the disc tray UNDERNEATH the unit. It is a sort of toggle lever that you have to slide to the other side and that releases the disc. The Manual does not even mention this manual release lever!
Also, it may be hidden or covered by a paper like cover.
GL
Mar 15, 2009 | Philips HDRW720 DVD Recorder
Pictures distorted play/record mode
Run the diagnostic software by unplugging the unit. Hold the Play while reinserting the power cord. Continue holding the Play until the diagnostic program is displays NUC XXXX where XXXX is a series of numbers. Once the diagnostics is finished it will pass or fail. To return to normal operation unplug the unit and reinsert the power cord after 15 seconds or so.
Mar 30, 2008 | Philips HDRW720 DVD Recorder
Stuck on DEMO Mode
Just try to initialize THE plager again. Without cd in the player switch on the power while pressing the Play, Open and Next Track button. On the display it says " initialized" Ready. Frits van Heekesen Nijmegen The Netherlands
Dec 27, 2007 | Denon DVD-2200 DVD Player
[DEMO PLAY]
Push the play and stop buttons simultaneously and hold them for about ten seconds. This will get you out of demo mode.
May 29, 2007 | Sony DAV-X1 System
Lock and Demo Play Display
while the demo is playing you must press "Play"and "Stop" buttons, then display shows DEMO OFF and you can now take the DEMO CD out.
In some models you need to turn off the power and turn it on while pressing the EJECT Butoom.
SONY SPECIALIST
Dec 29, 2006 | Sony DAV-X1 System
Philips HDRW720 DVD Recorder Logo
369 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
