Question about Optoma RD50 50" Rear Projection HDTV-Ready Television
Optoma TV light Engine or Optical Engine Replacement
Does anyone know where to find one or install, for a RD/50 Optoma TV.
  • Anonymous Jan 19, 2009
    Same problem, same result. I spoke with customer service, and basically they tell you you're SOL. I will never buy an Optoma product again.
Technical Service Corp 888-942-2929 is where you can purchase an optical engine, I inquired for my RD 65. The part cost over $900, not quite worth it.
Hope this helps
Posted on Sep 23, 2008
2 Suggested Answers
  • 13433 Answers
SOURCE: Optoma TV light Engine or Optical Engine Replacement
have you tryed calling optoma for the part?
Posted on Jun 09, 2008
My 50" Viore DLP Television has white dots showing
Bad Light Engine/Optical unit Assy Block
Encompass Parts Distribuiton 1-800-638-3328
UED 1-800-648-6657
Dec 14, 2010 | GRY Viore RPT50V24DHD 50" HDTV DLP TV
The colors of my television do not work when i turn my tv on .My hd colors turn green.
check with diferent input , if still the same the problem on ur tv is the optical block , but try diferent input , or a dvd player sometimes the cable box goes out
Aug 26, 2010 | Sony KDS-R50XBR1 50" HDTV
Optoma RD50 TV which shuts down on #1 fan failure
This could be a variant of, or a newer (or older) version of the "DMD fan failure" message.
Symptoms I had are, I stop hearing a fan when the message is displayed.
Then the temp LED keeps flashing RED until I either try to turn the TV on again,
Or turn MAIN power off/on again. BUT it repeats when I try to turn the TV on.
The picture appears normal until this happens ( about 15 sec.)
The solution is to FORCE a normal shutdown by hitting the TV off button
before the message appears.
You should see the power LED flashing RED/GREEN (cool down) and then RED (standby).
Apr 20, 2009 | Optoma RD50 50" Rear Projection HDTV-Ready...
Optoma RD-50 DLP has dark vertical shadow on right side of screen
turning off the main can be very harmful to rear projectors if you dont wait for the cooling off period, for instance when you turn off the tv from the remote, the fans inside are still on in order to dissipate the heat given out by the lamp. as a result some of the lens inside the engine may have burns-in caused by excess of heat.thus leading to shadows on the screen.
hope this helps
please rate me!
Mar 19, 2009 | Optoma RD50 50" Rear Projection HDTV-Ready...
My Optoma HDTV Model RD50 needs replacement of its internal lamp. Which model lamp is the correct one and how much does the lamp cost? Regards - Lee
Call Optoma technical support listed on the optomatv website. They will ask for the set serial number. Based on the serial number, they will tell you which replacement lamp is the correct model for your TV. (I found this out after ordering the wrong replacement lamp based simply on the model number of my TV and finding that it did not fit.)
Jan 11, 2009 | Optoma RD50 50" Rear Projection HDTV-Ready...
Sony wega 50"SXRD (green tint)
They are one in the same IIRC. I'm having my TV repair for the same issue. Don't worry for now because the item has had its warranty extended to Oct 08.
May 18, 2007 | Sony Grand WEGA KF50XBR800 50" Rear...
How to fix black shadows appearing on both sides of the screen?
i beleive its electrical problem (horizontal circuit). if u are not inclined with this job just bring it there and besides they will give you warranty for their work.
Jan 14, 2007 | Optoma RD50 Television
Optoma RD50 50" Rear Projection HDTV-Ready Television Logo
570 people viewed this question
Top Optoma Televison & Video Experts
jasbo
jasbo
rostit
Are you an Optoma Televison and Video Expert? Answer questions, earn points and help others
