Panasonic DMR-HS2 DVD door won't open - Televison & Video
  • renn0928 Oct 25, 2008
    after disk is put in it spins fast and just keeps saying loading.......
  • mtpatel37 Jan 27, 2009
    I have a SONY blue ray that's taking a longer than usual time to load. Once loaded, I see the main screen but can't access any of the DVD menu features (i.e playing the movie, scene selections, etc.)
Dvd player just keeps on loading
Posted on Jul 06, 2008
My Panasonic DMR E S45V just stopped working. The Error message is F04. The DVD door won;t open, the VHS door won;t close.
Check the servo unit to see if the actuator is changing modes when press the buttons. If one door is open the other will not function either.
Feb 02, 2015 | Televison & Video
Panasonic dmr-hs2 dvd recorder / player disc stuck in door will not open
try opening the cabinet and release the friction
Thanks for using Fixya
Jul 06, 2008 | Panasonic Televison & Video
Won't recognise DVD Ram and non-finalised discs from own recordings.
Usually, the U11 error code in a Panasonic DVD player indicates an optical problem. You could of course try doing a cleaning using a CD cleaner normally readily from computer parts stores. Alternately, you can open the unit up and do a manual cleaning with soft bristle brush and/or cotton buds. Other than that, it could be indicative of a weakening laser eye which of course would require parts replacement.
Hope this be of initial help/idea. Pls post back how things turned up or should you
need additional information.
Good luck and kind regards.
Thank you for using FixYa..
May 24, 2008 | Panasonic DMR-HS2 DVD Recorder
DVD door won't open
you should get the DVD door cleaned either profesionally or just do it yourself
Feb 19, 2012 | Panasonic DMR-ES40V DVD-Video Recorder
I want to reset the reorder but i don't know how.
If you do not have your original instruction manual, you can download a free pdf from:
http://www2.panasonic.com/consumer-electronics/support/Video/DVD-Recorders-Players/DVD-Recorders/model.DMR-HS2
(right-click and save link/target as... - it is a 3.2MB file (total size))
It may or may not help. Either way it's free.
Apr 25, 2011 | Panasonic DMR-HS2 DVD Recorder
On switching on, has single circle spins with dvd led
I had a similar problem with an RCA DVD recorder and I had to replace a capacitor inside the machine.
Jan 16, 2010 | Panasonic DMR-HS2 DVD Recorder
My panasonic dvd recorder dmr-hs2 keeps switching to standby mode
I have the same problem, but it takes a while longer...just get the circle rotating in the LCD on DVD!
tried unplugging HDD...still does it.
Jan 13, 2009 | Panasonic DMR-HS2 DVD Recorder
Locked DVD Tray
I'm pretty sure the force disk eject is the same across all Panasonic models - however I couldn't find anything specific for your model number. Still worth a shot, though.
With the unit in standby, press and hold the 'Stop' and 'Ch up' buttons together. It should power up and force the tray open. If this doesn't work, try changing up your timing by pressing and holding 'Stop' first, then a half-second later, press and hold 'Ch up' and keep them both held together. You can also try the opposite.
If none of these work, it will have to be taken apart to get the disc out. If you aren't comfortable trying, it will have to go to service.
Mar 09, 2008 | Panasonic DMR-HS2 DVD Recorder
Hard disk failure
It really depends on what is failing on the old drive...accordianman
Oct 24, 2007 | Panasonic DMR-HS2 DVD Recorder
Televison & Video Logo
424 people viewed this question
Top Televison & Video Experts
Electro Med Services...
