I have a honeywell programable theromosat and I need to know how to set it. Can't seem to get the tepreture to rais above 73 degrees.
  • 4 Answers
If it is a Vision or Focus
Pro 5000 it should just have 4 buttons on the face. If you hold down the top arrow and the far left button at the same time it should unlock to you can reprogram it. It should say 1 on the left and some other number on the right. You need hit the button under "next" on display until you come to number 27. Setting 27 is your heat setting move it up and down until desired temp is reached. Next is selection 28. This is the cool temp move up and down until your desired temp is reached. After this you should hit the done button and thats it.
Posted on Apr 15, 2008
  • Scotty Brannon Apr 15, 2008
    I would recommend only setting the cool on 70 and the heat on 80..
How do i adjust AC temperature variance on a Honeywell TH5220D1003 thermostat
If you are talking about the difference between heating mode and cooling mode and the room setpoint, you can not change it. It comes from the factory with a 3 degree difference. In other words if you raise the heat setpoint until it is within 3 degrees of the cooling setpoint, for every degree you raise the heat setpoint the cooling will raise a degree.
About all you can do is increase the distance between the heat and cooling setpoint. To do this either lower the cooling setpoint to 3 degrees higher than the heat setpoint you want and then increase the cooling setpoint the desired setting. For example heat and cool setpoints are 67 and 70 respectively, and you want 65 and 73. Lower the cooling setpoint to 68 and then raise the cooling setpoint to 73. Now your heating will come on 3 degress lower than 68, the 65 you wanted and cooling will come on at 73. Remember, the thermostat new setpoints will turn on the cooling at 75 and turn back off at 73 and heat will turn on at 63 and turn off at 65.
You can perform the same using the heating setpoint, just have to look at it backwards. If you need to lower the difference I recommend a 8000 series thermostat. They are the most functional thermostat that Honeywell makes, be in mind they are about 3 times more expensive and many of the setting require a well trained tech to interpret and set properly.
Hope this helps.
Aug 24, 2014 | Honeywell Th5220d1003 Non-programmable...
Honeywell thermostate will not kick off on set temperture
There's a "throttling range." The unit starts (say, in heating) one degree below setpoint and shuts off two degrees above set point.
You can change the "temp" but you can't change the throttling range.
Mar 02, 2014 | Honeywell Programmable Thermostat Heater
TH8110U1003 Touch screen thermostats. My problem is I don't have a manual to show me how to operate it. But the big problem I'm dealing with now is when I set a temp. say I set it for 75 and the house...
If your program that you have programed into the stat is set to 73 it will go back to that setting if the stat is in the program mode....... Push the HOLD button on the stat and keep pushing it till it say permanent HOLD right above the buttons on the bottom and then you can set your temp to what you want. Here is a download link for the manual from Honeywell..
http://customer.honeywell.com/techlit/pdf/PackedLit/69-1894EFS.pdf
Mar 22, 2011 | Honeywell Heating & Cooling
The thermostat is programed to go only up to 73 degrees but it keeps going and it starts getting really hot in the house, is soo annoying. I have to get up in the middle of the night to fix it by pressing...
If t'stat is overshooting your set temp but you can reset or otherwise shut it off, then you need to replace the t'stat. If you can't get it to shut off by resetting t'stat , then the problem could be in your heater.
Jan 12, 2011 | Honeywell Programmable Thermostat Heater
My thermostat is set to 73 degrees when i get home at six it is set at 75 during the day when im not home the past couple of days it wont get to 73 it actually goes up to 76 77 it is working cool is on why...
may need charged a out of adjustment can cost lots is it old unit is outdoor temp. very hot may have trouble catching up to setpoint.on a 95 degree day good luck.
Jul 07, 2010 | Honeywell Electronic Programmable...
Honeywell T87f 3855 Doesn't Activate Heater
thats becaue you need more than this zone working like you said about the master/slave this zone is a slave.
Jan 25, 2009 | Heating & Cooling
Temp shows 2 degrees warmer than what is was set to
sometimes the furnace does a better job than anticipated, i wouldn't worry about it, especially if the furnace shuts off.
the setpoint is the temperature you want it to be
cycle lenghts are determined by how much recovery you are requesting. for instance, in the morning when you wake up, you want the temperature to be at its setpoint. what the thermostat will do is make the furnace run a limited lengths during the recovery process.
Nov 11, 2008 | Honeywell Programmable Thermostat Heater
My furnace cycles too often. Do I suspect that my Honeywell digital thermostat (Model CT3500A) Smart Recovery features are faulty? How to you adjust the sensitivity? Thanks!
recovery has nothing to do with on off on off. you have a new digital stat that holds an exact to the degree temp a change of a half a degree can bring it on.. so stat needs to be above main return 5 feet off floor. away from any drafts , doors supplys etc. also be sure the hole in the wall is sealed . the cold air in the wall is more than enough to make stat come on . they are incredibly sensitive.an old mercury bulb stat would have a swin g of 3 or 4 degrees . so set at 75 it may heat up to 78 and stay off till temp fell to 73 so you get a longer run cycle or and longer off cycle. the new ones are on off on off keeping a perfect temp 75 exactly. thory is the heat exchanger is already hot and a quick short cycle is more efficient than being off 20 minutes and reheating the heatexchanger from scratch again. having said that if you look aT the installer set up instructions that came with the stat it may give you an option to reset or adjust the stat so it will have a one (default) two, or three degree adjustment , so 75 equals up or down three degrees on call for heat.see honeywell toll free number in their literature
Oct 24, 2008 | Heating & Cooling
Cooling Problems
Your filter is clogged. Not the one at the bottom of the unit.The one above the unit. It is like a raditor coils, kind of a bear to get to. We have cats and dogs the filter gets most of the hair but not all.Usualy about 6 bolts to take out.The proublem will be at the bottom of the top filter.
May 09, 2008 | Honeywell Electronic Programmable...
Heating & Cooling Logo
97 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
