Question about Panasonic NV-HS1000 S-VHS VCR
Panasonic Video Recorder has stopped working
Hi on Saturday I rewound a video tape in my Panasonic NV-HS1000B video recorder but near the end it sounded like the machine was labouring to rewind it. I managed to eject the tape and all was fine a bit.
My video recorder has now started to make a high pitch noise which is the video drum running continually without a tape in the recorder.
I unplugged the video recorder and then plugged it back in and it appeared to be OK again.
I came downstairs this morning to video making the noise again so I unplugged. When I got home from work at least 10 hours later I plugged it back in again and the noise started straight away the digital display is showing E9 which I assume is some kind of error code. If I leave the video plugged in occasionally the noise stops and the clock display returns but within a few minutes the head starts spinning again and E9 is displayed.
Any help would be gratefully appreciated.
  • Scorpio53 Apr 18, 2008
    I have have now downlaoded a PDF Service Manual but the schematics are too small too read trying to source legible schematics and will see how I get on from there. I have found out from the service manual Code E9 indicates a Serial Clock Transmission failure between IC6001 to IC7501 I will be having another look over weekend.
  • 975 Answers
Looks like some kind of sensor within the mechanical part, its seems like the mechanism doesnt return fully to its original point giving you these kind of malfunctions, I suggest to take it
to an authorized dealer for a complete check up & tune up
Posted on Apr 16, 2008
Panasonic NV GS25GN How to download from camera's tape to a new iMac OSX? Do I need special drivers? My iMac has a firewire 800 connector (not a 400).
I expect that Firewire 800 is backwards compatible with 400. You just need a cable with the appropriate connectors on each end. The Mac surely comes with the drivers already installed.
How it works with my mini-DV recorder (on a PC) is that when I fire up the video editing software, it sees the camera as a source and can control it from the computer to rewind and download. The book says use the mains power adapter to make sure the camera stays powered.
Nov 30, 2010 | Panasonic NV-GS25 Mini DV Digital...
MY PANASONIC CAM RECORDER STOPPED WORKING BECAUSE
The tape will be badly damaged if trapped in camera, this always happens when the camera has got dirty heads and capstan rollers, some times the door wont open if this happens, but if it does open your local camera shop may get the film out.
Jun 16, 2010 | Panasonic NV-DS60 Mini DV Digital...
Hi, My samsung VHS rewound a tape saturday night but was stuck on the rewind button sunday am! It is a four month old peice of equipment. Doesn't seem to work today. A tape seems to play, fastforward, stop...
The best thing i see is to return the machine to the store where buy it and replaced for a new one..
if you cant you will have to clean the head system
hope that will help you.
have a nice day.
May 10, 2010 | Samsung DVD-VR320 DVD Recorder/VCR
Panasonic NV-EX3B Help
It is 10 years past its useful life.
Sep 23, 2017 | Panasonic Video Cameras
F 04 - Tape stuck in recorder
F04 means that the mechanism locks during unloading. You need to check the Load motor and it's timing.
You have by the way a K Mech model. This will help you find parts and other information on the mechanism.
Dec 18, 2009 | Televison & Video
Panasonic NV-DS30. Camera and VCR works only at
i had same problem and i took out the tape cartridge and found tape hanging out i fixed that carefully then it worked fine
Sep 08, 2009 | Panasonic Video Cameras
Removing fade out .
Go to the Tape mode. Press and hold the joystick untill a small menu-thingy comes up. Go left with the joystick, and voilà, problem solved.
Mar 03, 2009 | Panasonic NV-GS17 Mini DV Digital...
Panasonic DMR-E55 Won't Let me Record my own VHS
Hi
This is probably caused by an irregular magnetic encoding pattern being generated by the tape itself. If the DVD recorder does not fully recognise the code, it may incorrectly interpret it as copy protected. If there is any tape flutter or there are tape edits, these can contribute to the problem. In addition to this magnetic imprinting can occur on old tapes that have been stored for a number of years without being spooled. basically wrong bits of the tape get magnetised. You can sometimes hear an echo on old tape recordings caused by imprinting.
You could try the following:
1) If available, try using a different video machine to play back and record from.
2) Whatever video machine you use, put your tape in, fully fast forward and rewind a couple of times, then try your recording again. This is particularly important if you haven't used the tape for some time.
3) If it fails again, check to see if it always fails at the same point.
4) If it does, try winding forward a little and then try to resume recording.
5) If you can record it means that a short section of tape is giving a spurious code to your dvd recorder and confusing it.
6) Use a re-recordable dvdrw to make a master. You won't keep wasting discs if the recording stops. You will also be able to produce another dvd from your master and edit it if your recording ends up in a number of segments.
7) Always use the highest quality setting possible when producing a master.
8) If all else fails, if you have a friend with another dvd recorder, maybe try that.
Have fun....
Jan 21, 2008 | Panasonic DMR-E55 DVD Recorder
Recording direct to dvd
this cable is not helpful, use a video grabber instead.
Aug 31, 2017 | Panasonic NV-DS60 Mini DV Digital...
Panasonic NV-GS50
check to see if iris is opening and closing, could be seized vanes on iris motor. Good luck
Mar 09, 2006 | Panasonic NV-GS50 Mini DV Digital...
Panasonic NV-HS1000 S-VHS VCR Logo
339 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
