There's no cold water coming into the Whirlpool washer. The hose is fine. The filter in the washer where the hose attaches to the washer is plugged up. However, it doesn't seem to be one that can be removed to be cleaned out. How do I get it out?
  • 487 Answers
You can either normally twist it out or pull it out. This is your problem
Posted on Apr 15, 2008
SM 8525492A whirlpool washer rinse cycle no water comes out, just hums
when the washer goes into rinse cycle it only uses cold water so clothes don't rinkle,so most likey you have a problem with your cold water,do this,shut down the water to the washer,remove the water lines from the back of washer and mark them so you know how they came off,stick the hoses into the washer if they reach or a bucket,turn on the cold water to see if water is coming out of hose,if water does come out of hose good then stick the cold water hose back on the washer and run it only on cold,if it doesn't fill then you know you have a problem with the water valve on the washer and it's not the house water valve that's bad,and usually if you have a problem with the washer water valve it will just hum and no water will enter the washer so if you hear a humming sound it will be the water valve.tried looking up the model number you sent but it doesn't come up on the parts lookup
Apr 25, 2013 | Washing Machines
Whirlpool frontload WAsher. After I run a load, the clothes come out fine. Several hours later there will be an inch of water in the tub. 10 hours more there are 5 inches of water. I have checked the...
It sounds like the water inlet solenoid valve at the rear of the washer where the hose hooks up is leaking, more than likely the cold water valve.
Jan 31, 2012 | Whirlpool Washing Machines
Cold water trickles into the tub while it is being filled up
The hot and cold water supply hoses that connect the washer from the water supply faucets on the wall to the water connections on the back of the clothes washer usually have filter / sediment screens within there connection fittings at the end of the hoses, these will collect dirt,sand, calcium deposits, etc.,when they trap enough of these materials they will plug up and restrict the flow of water into the clothes washer. Turn off the water faucets at the wall, and you should do this for both hot and cold hoses, disconnect the hoses from the washer and the water faucets, look into the hose ends and pull out the screens and clean them out by running water and what ever you can use to clean them completely!!!!!
Now look inside the water connections on the back of the clothes washer,where you screw the hoses on the washer, and check to see if there are filter screens in there, if there is, remove them and clean out completely also, then reverse the removal process and reconnect the hoses, makeing sure to connect the hot and cold hoses to the right connection on the back of the clothes washer!!
Try filling the washer with water to see if you have corrected the problem.
Make sure hot and cold hoses are correct on the back of the washer!!!!
GOOD LUCK !!!!!!
Aug 03, 2010 | Whirlpool Washing Machines
No cold water coming in, only hot. hose is fine.
check screen in washer machine-turn off cold water unscrew the cold hose that goes into washer-check to see if screen is clogged a small filter
Oct 19, 2009 | Kenmore Washing Machines
Ty for being here. I have a kenmore stack washer dryer. Washer is a model 417.94802 301. The hot water feed work fine comming into the machine. However the cold feed only comes in at a trickle. I...
For low water volume - or "Trickling" effect...
1. Turn off the water supply to both hoses.
2. Remove hoses (one at a time so you don't get them confused)
3. On the washer side - look for a removeable screen inside wher you just removed the hose.
4. Using a small screwdriver - pop out the screen and reverse-flush it/clean it. It will likely be full of sediment and calcium deposits from your pipes.
5. Replace the inlet screens.
6. Re-fit the hose to the machine.
7. Turn on water supply valves.
8. re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 05, 2009 | Washing Machines
Cold water into tub of wash machine
8. re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!
Mar 05, 2009 | Kenmore Washing Machines
Cold water feed into tub seems somewhat pluged.
8. re-try.
No water for rinse cycle
Take the fill hoses off the machine and clean out the filter inside, right where the hose attached to the machine. Also, check to make sure there are no filter washers in either end of the supply hoses. Sounds like you only have to check the cold water side in this case.
Nov 08, 2008 | Whirlpool Washing Machines
Whirlpool washer approximately 2 1/2 year old
The screen at the cold water inlet is clogged. Cut off the cold water line and unscrew the line to the washer at the washer. Use a flathead screwdriver and pry out the metal screen that is visible Wash it out in a sink and re-install it. Re-attach the water line,turn it on and your'e good to go. If not you will need a new water inlet valve. These are the only things that can cause your problem unless there is a problem with your cold water supply pressure. Good Luck!!!!!
barneyluc
Oct 03, 2008 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
