Question about Bush 2871NTX 28" TV
Power supply fault?
Hi all
Wonder if you can help.. have a bush 32" LCD TV - the green "power on" LED light is on, however the TV doesn't power up or have any sound or picture.
Can you please help?
Many thanks
    Genius:
  • 1,665 Answers
Check all electrolitic capacitors at power supply area : better replace them.
Posted on Apr 15, 2008
  • Bush Master
  • 13,433 Answers
Possibly the mainboard is faulty or possibly the power board but since you get a power led .. Id suspect the mainboard.
Oh this is a old style tv? Id have it checked but the repairs might cost alot.
  • Ekse Apr 15, 2008
    wait.. you posted it under a difrent name and type. but its still a lcd.. So yes
    Mainboard or powerboard / inverter.
    is the problem you can check for bad capasitors yourself. if they are bulky or something has come out from them then they would need to be replaced, might be better to replace the whole board or boards, the screen is most likely Ok!
I TURN MY TV ON IN A FEW SECONDS GOES BLACK .BUT THE GREEN LIGHTS STAYS ON
The internal power supply is failing. The green light merely indicates that house power is getting to your TV
Aug 08, 2013 | Viore 32" LED LCD HDTV
Hi! I have a 32" LCD led backlit bush tv (not sure
Yes, all the issues point to a problem in the standby power supply which runs 7/24 if the set is plugged into wall power--get it taken care of under warranty before it really fails bad.
Dec 17, 2012 | Televison & Video
I have a tv sharp lc 32sb24u dont turn on the green led is blinking i have voltage in both sides of the power switch 3.2 volts
power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hope this help in solving the problem, take care in handling the fault.....
May 25, 2011 | Sharp AQUOS LC-32D44U 32 in. LCD TV
The red led on the front of the unit flashes. unit will not turn on and led doesn't turn green. is this a power supply issue?
The power supply board of the Television is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I hope this will help in solving the problem.....
May 06, 2011 | Akai LCT3201AD 32 in. LCD Television
Red light power blinking
power supply problem this can be done by a professional tv repair
Sep 12, 2009 | Panasonic Viera TX-32LX70 32 in. LCD TV
BUSH IDLCD27TV006
http://www.chsinteractive.co.uk/pdf_data/KT02.pdf
Order Code….. KT02
POWER SUPPLY REPAIR KIT
BUSH MAXIM 1157 1154 Medion
Goodmans (Standard) 04TA069I 05TA71B 05TA071C
A standard power supply repair kit for faults attributed to the standby +5v rail.
BUSH IDLCD27TV006.
MAXIM 1154, 1157.
MEDION MD30112.
GOODMANS IDLCD27TV006.
The numbers off the boards will read: 04TA069I 26” 27” 30” 32”
& 05TA71B, 05TA071C.
LCD TV POWER SUPPLY PROFILO-TELRA.
Please check the primary of TR20 before fitting the kit.
Primary windings should read approx 2.700mH / 4.00 Ohm.
We recommend all kits are fitted by qualified engineers
We accept no responsibility for loss, injury or damage caused by your use of this kit as a successful repair
depends on your own skill and fault finding ability.
Circuit Reference
Loc Description
F300 T3.15A FUSE
IC21 FSD200
IC30 ICE1QS01
D315 12V ZENER
D318 2V4 ZENER
Q300 BC337
Q302 BC848C SMD
D325 1N4007
C213 33UF
C322 47UF
C356 47UF
C330 1000UF
LINK (IF NEEDED)
Oct 31, 2008 | Televison & Video
BUSH 32'' LCD AT FAULT
Most of the time, this is from a failed power supply board, and or a short on one of the other boards. Without board swapping this is a difficult thing to troubleshoot.
Jerry G.
May 25, 2008 | Bush Televison & Video
Hitachi 32LD8700 - TV won't turn on although has power
The general problem with LCD type TV's is that the power supply fails. They are very sophisticated designs that are difficult to troubleshoot and generally best to just replace the module, but sometimes there is visible damage in some of the electrolytic capacitors (visibly bulged) and high voltage rated parts can be substituted.
Hope Ya Fix It
Feb 10, 2008 | Hitachi 32LD8700 32 in. LCD Television
Televison & Video Logo
614 people viewed this question
Top Bush Televison & Video Experts
Joseph Hoffmann
Are you a Bush Televison and Video Expert? Answer questions, earn points and help others
