Question about LG DH30 GoldStar Dehumidifier
On and off switch..........
Need a new switch(on & off), can't find one.........help....
    Champion:
  • 210 Answers
Check it out, here are the part numbers for you.
Sgt 48
266003 SWITCH ASSEMBLY, ROTARY 6601A30001B
Posted on Jun 04, 2008
How do i replace the humidity sensor
Only two wires and two screws. Shut off the furnace disconnect switch before doing anything. Then Pull off the cover and I do mean pull off. Then undo the two screws remembering what terminal they go to. Remove the screws from the back plate and let the wires fall through the back plate as you pull it off the wall or duct. Put the new back plate in place with the wires pulled thought. Install the screws I the same place as the old ones. Re attach the wires into the same labeled terminals as the old one. Put the new cover on. Turn on the furnace disconnect switch and away you go. To check operation all you need to do is, turn the knob on the humidifier control and listen for the solenoid to open and water to flow to the humidifier. If nothing happens then you need to check for power to the humidistat. Should be 24v. If no power then you need to check the source.
good luck
Apr 19, 2014 | Dehumidifiers
Put empty bucket in,it runs for minute,then shuts off. need a switch that won't shut off. Where could I find one my zip code is 44451.
The switch may not be the problem. However, a dirty or clogged air intake filter or the humidity extraction level set to high could be.
Turn the unit OFF & unplug it.
Remove and clean the air intake filter thoroughly. Be sure the filter is completely dry, before reinstalling. Never operate the unit without the filter in place.
After the filter is dry, reinstall it, plug the unit and turn it ON. Lower the humidity extraction level to 35%. If you have an analog unit (No LED screen) set the humidity extraction knob on Maximum.
And finally, be sure that the water collection bucket is installed properly and is not vibrating loose when the unit runs. It should fit squarely into it's holder, making contact with the bucket safety removal switch on the back wall of the bucket holder. When installed properly, it should not tilt down at the bottom of the bucket.
All of the above should solve the problem and you won't need to purchase a new switch. But, in the unlikely event, that you will have to. You will need to furnish the Brand Name of the unit and the Correct Model Number. As, they are not all the same.
Hope this helped you and thanks for choosing FixYa.
Aug 23, 2011 | Dehumidifiers
Coil is freezing up.rusted coil sensor bracket. i need a new freeze switch sensor for the front coil. i guess it turns the compressor on and off so the coil doesn't freeze solid. can't find the...
Buck, as you seem to be aware, Fedders no longer exist as the Fedders you may have been familiar with 8 years ago. Finding manuals and parts, is like looking for a needle in a hay stack. However, the new company Airwell-Fedders may be able to help you. There Customer Support Dept 866-829-2440, is who you need to contact.
There is one other possible source, as some parts are interchangeable. Appliance Factory Parts
http://www.appliancefactoryparts.com/airconditioners/fedders/ does carry some of the older Fedders Parts, as well as Maytag. So, that may be worth a try.
Hope this helps you find the parts you need. Good luck and please let me know how it worked out for you. Thanks.
Jun 11, 2011 | Fedders A7DH45B2A Dehumidifier
I bought an LG dehumidifier last summer and it worked fine until about 2 months ago. Then there was this constant clicking noice. It seemed like it was electrical with the switch or something. It was...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Apr 22, 2011 | LG LHD45EL Dehumidifier
My new LG "ld450eal" DeHumidifier
The switch that says 'Bucket is full' is not adjusted properly.
It will need to be adjusted, normally a screw driver or pliers,
so that when its empty the switch is not made or the contacts
are open.
If it is in adjustment properly, then the switch is bad and needs
replacing.
Before you replace it, check to make sure the wires leading to it
are not touching, it may be sending a signal meaning 'full' by
electricaly touching each other at the switch.
Feb 25, 2011 | LG Dehumidifiers
The unit is several years old - the float keeps falling in and the unit shows full -can I get a new float and will that fix the problem?
If the float falling in tells you its full probably not. Unless the float floats off a switch. Then a new float that wont fall off would probably do it.
If the float keeps falling off...why not tie a small piece of fishing line to it and suspend it above the switch? It will stay where its needed until water lifts it up.
Jun 27, 2010 | Maytag M7DH45B2A Dehumidifier
Empty drain pan light on unit level and plumbed to sump unit stll runs normal
Hi Kevin,
If your dehumidifier is a Compact that is over 6-12 months old the problem may be a defective drain pan safety light switch. On the early units this waterproof switch wasn't as waterproff as the vendor described. A new "MORE" waterproof switch is now being used in that unit. The new switch is a direct replacement for the old switch. Please call the Thermastor Warranty Dept and they will send you a new switch at N/C. Their # is 800-533-7533 ext 8451 or contact Dwaine @ ext 8450.
Jan 13, 2010 | Therma-Stor Santa Fe Dehumidifier
Danby dehumidifiers
Try manually work the float and switch the float controls to make sure it is not hung up. You may need a new switch if that does not work.
Dec 31, 2008 | Danby DDR6588EE Dehumidifier
Tripping BreakerS
Same problem as both above. Humidifier trips after maybe 5 minutes. Top of machine is very warm; there's no on/off switch, so plugging in does nothing until the heat dissapates. What's the solution, to just buy a new piece of equipment?
Sep 13, 2008 | Dehumidifiers
My dehumidifier is dead
WIZ huh? NAGEV says:
check the plug!??? - DUH! I also love ...
5) Remove and test the overflow cutoff switch.
6) Remove the humidistat and check it. Replace it if necessary.
7) If the unit still doesn't work, call an appliance repair person!!!
I guess he's only helping the repair person! Who would pay for this kind of advise? The layperson needs details not big words!
Jan 18, 2006 | Fedders A7DH65B2A Dehumidifier
LG DH30 GoldStar Dehumidifier Logo
83 people viewed this question
Top LG Dehumidifiers Experts
Bill Long
Michael Van Der...
Michael Van Der...
Gil Shultz
Are you a LG Dehumidifier Expert? Answer questions, earn points and help others
