posted by No-mech-eng on Apr 15, 2008
hi,
I am trying to figure out what I should set up as torque settings on my electrical drivers in building and assembling our product.
We are a small company and do not have any mechanical experts but we are using basic sized screws into an aluminum chassis.
6-32 philips head screws 3/16,5/16,3/8,1/4,3/4,1-1/4.
4-40 philips head screws 3/16,3/8,11/16.
Hex Nut 4-40 and 6-32.
Please let me know if you have any answers or areas i can seek tis informations.
Thanks,
Solution #1
posted on May 29, 2008
I can't give you exact answers but I can tell you this: the torque required will vary with the thickness of the chassis material and its hardness. You also need to take into account what is being fixed to the chassis.
I'd suggest either contracting a suitable mech engineer for a day or doing a bit of trial and error: use a test chassis, drill a row of pilot holes, insert screw and torque down at a low setting; Increase torque for next one. When you find one that either damages what's being fixed down or strips the thread, back off a couple of steps and try 1/2 dozen more at that setting, just to be sure.
If the product is liable to be subject to vibration (including delivery, transport by purchaser, etc) then you'd need to check that the fasteners can cope with that as well.
The whole field of fastener torque is a minefield - try a Google search and you'll see what I mean!
Was this solution helpful? Show your Appreciation by rating it:
This Problem Also Relates To:
HP Compaq ProLiant DL580 G3 (364636HP1) Server
HP Compaq ProLiant ML110 G4 Server
HP Compaq ProLiant ML150 G3 Server
HP Compaq ProLiant ML530 Server
HP HP BladeSystem c-Class c7000 Enclosure 3-inch LCD - Three Phase (412136-B22) Server
HP LC Series 1000 32 node DL140 cluster (350060002) Server
HP (370507001) Server
Can you Help with these Servers problems?
HP Compaq ProLiant ML150 G3......
I am facing the problem with... Answer This...
Fujitsu Siemens PRIMERGY TX300...
L2 LED on main board flashing,...
board was replaced, CPU was... Answer This...
IBM Netfinity 3500 M20 8657 Server
Network & Speed Problem
My IBM servicer is very slow... Answer This...
VisionMan 1U NAS / 1TB / Dempsey 5050 / 1GB...
Hoover dryer 5959 ED
How can I obtain an instruction... Answer This...
Repair Service
Find Server Repairman Near You:
