KV-28CL10U colour circles
My sony KV-28CL10U television has coloured concentric circles on the screen.
  • PETE0629 Mar 04, 2009
    I have the same problem with 28in Beko widescreen TV. Is degaussing thermosistor located as in Sony?
    Genius:
  • Televison & ... Master
  • 1,689 Answers
There are two things that commonly cause the fault that you are describing. Below is the main one.
It is very possible that the degaussing circuit or the degaussing coil is no longer working. A common fault is that the degaussing thermosistor has gone defective and the CRT has become magnetized. The earth's magnetic field along with other environmental things cause the CRT's internal mask to become magnetized over time.
The thermosistor in most Sony TV sets is located in the power supply area. It looks like a little black square box with 3 solder posts on it. In some models it has 2 solder posts. After a number of years this part may fail.
When the power is first turned on, the thermosistor is very conductive. After it heats up, it goes very high in resistance. It drives a high decaying AC mains current through the degausing coil (located around the shroud of the CRT assy) for about 50 to 60 ms. It then allows the current to decay to zero over the next 50 ms. When you turn on the TV set, you normaly hear a kind of a loud thump noise. This is the degaussing action.
Once the degausser is serviced and is working properly, it may take a number of power cycles to eventualy demagnetize the CRT. After shutting off the TV, it takes about 20 minutes before the degausser can work again. The thremosistor needs some time to cool down.
If you are not experience and trained for doing TV service, I would suggest you give the set out to an experienced TV service tech to change this part. There are serious safety issues when working inside of TV sets.
It is possible to purchase a manual hand held degaussing coil. There is a proper procedure for using this type of coil. If you were to manualy degausse your CRT, you would have to do it on an almost daily basis. The manual degaussing coil is fairly expensive to purchase. It would be better to service the set.
The second thing that causes the CRT to show colour purity problems (color splotches, or circles, or patches), is that the mask inside on the face of the tube has become dislodged off its supports or became warped. This can happen if the set has been dropped, or hit hard enough to do some damage to the mask. I have seen this where TV sets were roughly handled during moving them.
The only fix for a damaged CRT mask is to replace the CRT. The cost would be as much or more than the set is worth. This is if you can even find a replacement CRT. Most all of the manufactures no longer manufacture replacement CRT's for consumer products.
Only specialized CRT's are still being produced on a limited bases for specific industrial and military equipment that must still be kept in service. These are for some types of radar, medical, aerospace, and other related industries.
Jerry G.
Posted on Apr 16, 2008
Sony kv-EF29M80 blue colour missing and takes time to turn on unlike how it was before. the images are blur.what could be the problem and what solution is there for it?
Check the collector voltage of blue output transistor at its video output board, which can be located directly plugged onto the neck of the picture tube. Check for any loose solder terminals at this board.
Dec 04, 2012 | Sony KV-32FX60 TV
Sony wega 28 inch colours wrong, circle on screen
It sounds that there is some magnet near by TV that is affecting picture tube. Please remove any extra speaker or any thing that has strong magnet inside, unplug TV for 20-30 minutes, replug back in, turn it ON, hope that will solve your TV problem.
Thanks.
Nov 16, 2009 | Sony WEGA KV-28HX15 28" TV
Sony Trinitron Colour TV Stopped showing and switch light flicker
The vertical output IC has failed/Power to the vertical IC is out/ or there is bad solder on the pins of the vertical output IC.
Dec 01, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Incorrect Tv colours
Hello Roloi,
This sounds like a problem with your yoke transformer. I would suggest having a qualified TV technician work on this problem, because it involves testing a component that could have dangerous current in it.
I hope this helps,
Thank you,
Shuttle83
Oct 26, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
KV-32FQ75E colour loss
Go to the Sony website and check out the correct antenna cable and scart lead configuration for your set up. I did and with a few simple connection changes it was like getting a new TV.
Jan 07, 2008 | Sony FD Trinitron WEGA KV-32FQ70 32" TV
Colour problem with my Sony KV-X2931S 29
Hi.
This problem is usually do a 15pf varicap faulty.
Not expensive to have repaired.
http://dysonmanuals.llc.nu/
Chris.
Dec 30, 2007 | Televison & Video
Monitor colours are only fluro purple & green!
use a 10 ins, speaker magnet to front of picture tube degussing color
Nov 29, 2006 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Screen Image is Concave
sony trinitron colour 29ins tv its black and white not colour but the teletext is colour
Sep 01, 2006 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Televison & Video Logo
704 people viewed this question
Top Televison & Video Experts
