Sharp ar287 HELP ME PLEASE!!!!
Hello there, I have the a sharp ar-287 showing a HS-01 code, have tried to do the reset code you mentioned in an earlier post,, but it may be that Im being thick, but i cant find the * key on the keyboard of photocopier.
can you please talk me thro it, i would be most grateful.
Dave
    President:
  • 2,072 Answers
I may have the wrong machine in mind. can you repost this. I am not one to not admit they are wrong;
Posted on Apr 18, 2008
How to fix Sharp Copier AR-5731 Error code
good day, my Sharp AR 5731 showing the message Call for Service . Code : H4-00 can you help me to fixed my problem. thanks and God Bless
Mar 11, 2013 | Sharp AR-BC260 Color Copier
Sharp AR-M450N+ Code: H2-01
Hello sir; You may do a reset simulation; press "p" "*" "clear" "*" enter 14 press start enter 0 press start , machine will go back to working condition.
Sep 12, 2009 | Sharp Office Equipment & Supplies
I want a solution for a Sharp AR - 287 Digital Image problem
H-4 is an error code for the fixing assemblyand needs to be reset thru a simulation code, sometimes a power flucuation can cause this error and therefore may not need parts.
press #
press *
press clear
press *
when it is done properly the display will go blank
then enter 14
then press the start key, turn the machie off and then back on.
If the code comes back you'll need something for the fixing assembly
Good luck
Bob
Apr 27, 2009 | Sharp Office Equipment & Supplies
Sharp AR-287 error code HR-00
The AR 287 does not have any codes that begin with "HR". Please recheck the display and post again with correct code and I will try and help you.
Dec 24, 2008 | Sharp AL-1641CS Laser Digital Copier
My Sharp AR-287 Copier is showing F2 error
there Should be 2 additional numbers. F2-??
Oct 29, 2008 | Sharp AR-235 Copier
H4 for an error code on all Sharps indicates that the fusing temperature isn't correct. It needs to have a new thermistor installed or the heating lamps need to be replaced.
Oct 21, 2008 | Sharp AR-235 Copier
Ar-287 H5-01 code
Try this...
This code means you have had to many paper jams in the fuser without removal. Make sure all is clear in the fuser and exit sections.
Then on the control panel you will press a series of buttonsas follows.
Press the P, Press interrupt, Press clear, Press interrupt, Enter # 14, Press start, Press execute to reset, Press clear all or cycle on/off.
Hope that helps...
Lbcoaster
Apr 15, 2008 | Sharp AR-M237 Copier
Sharp Copier AR-C270 Code Problem
jam in the fuser unit, try simulation 14
and/ or possible bad sensor switch actuating as tho paper is stuck in the fuser. check that exit switch is not stuck open or bad. if jam elsewhere , fuser will not allow operation untill jam somwhere is removed.
Jan 30, 2008 | Sharp AR-160 Copier
sir there is no code of HS may be it is other code H4 or H2 so please write correct code
Oct 06, 2007 | Sharp AR-C270 Color Copier
74 people viewed this question
k24674
jasbo
jasbo
