Question about Maytag Washing Machines
LE error code on maytag neptune - Maytag Washing Machines
  • Anonymous Apr 26, 2008
    What doe's the LE stand for.............
  • 50 Answers
SOURCE: how to fix the LO error code on Maytag Neptune front load washer
Not really bad news. The unit requires a door lock assembly.
Posted on Feb 23, 2009
dh1200s
  • 335 Answers
SOURCE: Error Code showing UC
Hello plthrsn64 ,
You should open up a separate problem for this but I will post as a solution for the Lid Lock Issue.
For the FAV6800AW that is you machine type correct? The "LO" console error is "Lid has failed to unlock". I haven't experienced the "LO" error code to the display but this is the direction I would go in. I feel you have a signaling problem back to the control board in the console from the lid is unlocked contacts in the left/right Lid Locks.. I would disconnect the left and right lid lock plugs to the washer. The right lid lock is not necessary for operation. The left lid lock is the important one because of its dual signaling function, the Lid is closed signaling from the magnetic reed relay and lid magnet and the lid is locked signaling from lid locks slide switch in the lid lock. I think you may corrosion build up in the left lid lock such as the Pic’s I will attach show of other users. The left lid lock is subject to corrosion brought on by the bleach dispenser.
You can start by un-seating the right lid lock and leave off. Then try un-seating and re-seating the left lid lock plug a few times and see if that will get you back in service. Be careful those plugs are difficult to pull out. Please remove power to the washer first then you will need to lift up the washer top to access the lid lock plugs. Here is the process, use the service manual for additional support.
The Service Manual for reference. Sears Parts Direct for reference.
Raise the top of the machine. Insert a flat blade putty knife approximately 2.5” from the left and right sides of the washer top, depress the spring tabs securing machine top to the washer base. See page 33 of the SM for putty knife insertion point.
If seating/reseating the left Lid Lock a few times doesn’t help I would remove the left lid lock per the Service Manual, carefully open up the left lid lock and see if corrosion is the issue. The plastic latchs around the lid lock enclosure can break off very easily be careful when opening the lid lock. If you have severe corrision I would use some WD-40 to clean up the contacts with a Q-Tip. The cntacts for the Lid is locked slide back and forth with the activation of the solenoid in the lid lock. You may have to rock back and forth the solenoid to clean up the slide switch. Just watch how the relay parts sit in the lock the latch arm will come out and you will have to fit back together to operate correctly. Sounds complicated it is not, it's just difficult to explain. If you have to replace the left lid lock here is a link.
Left Lid Lock Double check Part number if you order.
Corrision of Left Lid Lock
Close up of contacts in Left Lid Lock
My normal left lid lock in my machine which was purchase in 7/05.
Posted on Apr 05, 2009
  • 296 Answers
SOURCE: cycle stops 3E code appears
Well the error code 3E means that the overcurrent is detected at the moter.
Please check it if you have some overcurrent problem!
Thanks!
mannu_rakesh
Posted on Sep 01, 2009
SOURCE: MAYTAG NEPTUNE ERROR CODE OE
I have a Samsung Washer and the water would just keep pouring in and not stop. Eventually the OE error code would show and I would have to stop and turn off the water.
Thanks so much. You can fix this problem yourself. There are only two screws holding this part on. It is easy. I bought my part here.
http://www.appliancepartspros.com/part_details.aspx?image=0&part_id=4044218
Nobody stocked the part for the samsung but I found out that the Whirlpool part was exactly the same.
Posted on Sep 25, 2009
dh1200s
  • 335 Answers
SOURCE: error code of "dc" on my TL Maytag Neptune
If your machine is FAV6800AW or FAV9800AW the dc/UC errors are caused by a clutch malfunction. Your machine is shutting down with those errors so your Tub Displacement Sensor is working as designed.
Fix the Clutch malfunction and you can wash a single sock or a load of blue jeans and you will not take the dc or UC unbalance errors. See this post for the fix.
Post back if you have questions or need help.
Rich
Posted on Oct 06, 2009
Error code od maytag Neptune
http://homeguides.sfgate.com/maytag-neptune-washer-model-mah8700-troubleshooting-codes-102595.html. Here's the site for Maytag Neptune Washers. You can also find other modes there. Hope this helps. Enjoy.
Sep 30, 2014 | Maytag MAH6500 Neptune Front Loading...
Le error code
The error code "LE" appears after an unsuccessful attempt to fill the drum with water that results in the water level being too low to safely begin cleaning. The product manual suggests calling for service, but there are several steps you can take to try to resolve the issue at home.
Read more: http://www.ehow.com/info_8696564_maytag-washer-repair-code-le.html#ixzz2zXrmqUO5
Apr 21, 2014 | Maytag Neptune MAH5500B Front Load Washer
Error code FL-maytag neptune front load washer won't lock
replace door latch (fl = faulty latch ) good luck APPLIANCES R EN
Mar 09, 2013 | Maytag Neptune MAH5500B Front Load Washer
What does the code od mean?
The "od" code appears when you must open the washer door. The Maytag Neptune washer requires that you open the door between cycles.
Read more: Maytag Neptune Washer Error Codes ' eHow.com http://www.ehow.com/list_7170826_maytag-neptune-washer-error-codes.html#ixzz2GZKry68n
Dec 30, 2012 | Maytag Neptune MAH5500B Front Load Washer
My maytag neptune Model #: MAH5500BWW is flashing
The error code you describe is not listed in Maytag's book of codes. The link below will take you to Maytag's website error code page where you might be able to match it up.
http://maytag.custhelp.com/app/answers/detail/a_id/2885/session/L3NpZC8yY3lEMjNEag==/sno/0
Jul 15, 2009 | Maytag Neptune MAH5500B Front Load Washer
"od" error code Maytag Neptune FAV6800Aww
At 12 years of age, your Maytag may be telling you it needs to be replaced.
Sep 23, 2017 | Maytag Neptune FAV9800AW Top Load Washer
I have an le error message
in the top console off you washer is an tech sheet with the codes on it take a look see if can get a clue there.God bless,tom
Dec 29, 2008 | Maytag Neptune MAH5500B Front Load Washer
LE Code
Sorry I missed the LE code in the book.. Too much fun lastnight I guess.. AT any rate.. The Le fault code is a Motor overload warning.  Unplug it for 2 hours and try the machine again with a test wash.  if it persists you need to get a technician out for it.  Hope this helps :)
May 26, 2008 | Maytag MAH6700AWW Neptune Front-Load...
Washing Machines Logo
178 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
