Question about Brother MFC-845CW multi-function All-In-One InkJet Printer
Brother phone handset cannot find the base unit.
I have a brother mfc845cw and it came with the a wireless phone handset. it has been working well until yesterday when it refused to work. The handset cannot find the base unit and i tried to register it but it cannot register. i dont know what might be wrong. I have tried terminating the handset but still i cannot register it. I have tried to switch the machine off and remove the battery from the handset in order to reset it but still it cannot work out for me. i will appreciate if you could help me out with this problem
  • josevargas41 Aug 13, 2008
    I have a brother mfc845cw and it came with the a wireless phone we cannot get to snyc. The handset cannot find the base unit and I tried to register it but it cannot register. We will appreciate if you could help me out with this problem.
    Post Solution
    Work Queue
    --> Have the same problem?
    Have the same problem? Click Here
    This Problem has been added to the Share Your Expertise Page under "My Work Queue".
    OK Work Queue --> Have the same problem? --> Have the same problem? Click Here
    X This Problem has been added to the Share Your Expertise Page under "My Work Queue". OK
  • Anonymous Aug 18, 2009
    I have brother MFC-885CW and i have the same problem.
5 Suggested Answers
  • 832 Answers
SOURCE: Brother Multifunction Inkjet MFC-210C Reset Required
press menu then start bk-copy then fourtimes arrow-up.
machine will be in maintenance mode.
press 8 then 0 (zero) and then several times til PURGE 96xx (not sure about digits). press 2-7-8-3 and then 9 -9 to leave maintenance.
You have to replace the waistink absorber, too! Without changing you will seriously demamge the machine!
Posted on Mar 11, 2008
SOURCE: Brother mfc-490cw is offline
If you are running Vista and SNMP is turned off
1. Check to see if SNMP is turned off this is a component of Vista
a- Control Panel
b- Program and Features
c- Left side of screen you should see turn windows features on or off
d- Click on this a window box should open scroll down and see if SNMP feature is checked if it is then turn it off (unchecked) follow these steps
e- Under printers select Brother MFC-940CW printer right click
f- Select run as administrator
g- Select properties
h- Select ports
i- Select button configure ports
j- Under port settings uncheck enable SNMP
k- Click ok printer should be on line
l- To find MAC address for MAC filtering on router
m- Run the brother remote setup program and note the IP address
n- Run the command prompt as an administrator at the prompt type the following “apr –a” without the quotes and then hit return and note the physical address (MAC) for the above IP address you noted. Log on to your router and enter the MAC address from the step above and save.
o- Run the brother remote setup program again and change TCP/IP from “auto to static” please note you must have box checked at the top of the window edit network settings.
p- Restart the computer
Posted on Apr 16, 2009
SOURCE: how to reset the drum counter on a brother printer HL5270 DN
There should be a way to reset the drum setting. Call Brother they will help you are look in your manual.
Posted on May 30, 2009
  • 4041 Answers
SOURCE: Got an error code on a brother mfc845cw Can you
Hi there
With some Brother printers you can try this.
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, and then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then the printer will restart, hopefully without the annoying cannot clean message.
Some times this happens because of using cheap compatible ink cartridges if this is the case change the ink cartridges.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Apr 25, 2010
My brother printer has an error unable to clean 50
XXXXX XXXXX look on the printer, do you have these keys:
Menu/Set, Black Start, or Function?
Brother Printer Support
Sep 28, 2012 | Brother LC51BK Print cartridge, Inkjet...
Cordless Extension handset (non-color) screen remains blank and does not connect to Multi Function Printer.
Hi, the handset is not registered with base, to register please follow this process:
1. On handset press Menu/OK.
2. Press cursor up or down to choose "Register HS", then press Menu/OK.
3. Press Menu, 0, 6 on the control panel of base unit (MFP)
4. Press OK on the control panel of MFP.
You should hear one long beep when the handset is registered correctly. If not (three short beeps) repeat steps from 2 to 4.
Aug 02, 2012 | Brother BCL-D10 - Cordless extension...
Printer screen reads unable to print 50on my MFC-845CW
I would reinstall the driver and see if that first fixes the problem. be sure to restart the printer and the computer after installing the driver.
You can find the driver from here:
Jul 15, 2011 | Brother MFC-845CW multi-function...
I bought a used handset for my Panasonic wireless phone system, and now it is still registered to the original base and won't communicate with my base unit. Handset is KX-TGA931T and base is KX-TG9331T. ...
They are correct - the phones are married to the original base and can only communicate with that unit since they share frequencies. Other handsets have different frequencies ans will not work
Sep 20, 2017 | Panasonic KXTGA931T Cordless Expansion...
How do I use the phone
There are two phone jacks on the back of the unit, one is for the line and the other is for a phone. In the brother units that have a phone handset, you can plug this in and it will work as a phone simply by picking up the hand-set, on the ones that don' will need to hook up an analog phone and when you put the unit in fax mode you can then pickup the handset and use the phone.
Jun 16, 2010 | Brother IntelliFax-2920 Plain Paper Fax,...
Can't unlock tray for removal of paper, without major pull. Am afrais of breaking printer (Brother MFC845CW) Should I use WD-40?
I banged the **** out of it. I never got a decent (or any) answer for ny problem from Brother or anyone else.
David Godfrey
Jul 30, 2009 | Brother MFC-845CW multi-function...
Brother mfc845cw code 4f no paper jam or obstruction found... can i reset this or am i out a printer..
4f means the printhead is bad, the part is $89.00 and with the labor the cost is around $200.00. You can buy a new MFC 490 for around $120.00 with 1 year warranty.
Jun 30, 2009 | Brother MFC-665CW All-In-One InkJet...
Fax replacement parts
The jacks generally used for handsets on fax machines are a smaller (fewer contact positions) version of the one that are used for the wall-mounted outlets.
Unless the Brother handset jack looks totally different than the one in which the fax machine is currently plugged at the wall, then the handset jack should look pretty much the same but smaller.
A friend or relative may have a retired corded phone that they haven't tossed out yet so check with them before poking around to look for a replacement as described below.
If you are in the US, check the dollar stores and chain drugstores for corded telephones. Coming from China, they shouldn't cost more than $10 US and may have the exact same connector attaching the handset to the base of the phone. Check them if possible before hitting the cash-register since it is becoming more common to have the handsets on these cheap phones permanently wired to the base which, of course, makes them useless for your needs. Most stores though will let you return the item for a refund.
Checking a couple of stores, you may even find it possible to match the color of the fax machine with your substitute handset.
Nov 13, 2008 | Brother IntelliFAX 560 Plain Paper Fax
The handset says SEARCHING for base......what do I need to do
That's usually a network problem brother, contact your service provider for free customer support. It could also mean that the unit may be having problems with its signal, like your out of coverage area.
Jun 25, 2008 | Olympia OL5870 Cordless Phone
Brother MFC-845CW multi-function All-In-One InkJet Printer Logo
87 people viewed this question
James Cagle
James Cagle
Jim Keysor
