Question about HP LaserJet 3030 All-In-One Printer
Multi function scanner while in the end of moving get strucked at the initializing possition.
  • 86 Answers
Reinstal
Posted on May 26, 2008
Clear a radio shack triple trunking scannrt
If the scanner's display locks up or does not work properly
after you connect a power source or install batteries, you
might need to initialize it.
This procedure clears all information you stored in the
scanner's memory. Initialize the scanner only when you
are sure the scanner is not working properly.
1. Turn off the scanner, then turn it on again. Multi-system
Trunking Scanner appears.
2. Press 0 while Multi-system Trunking Scanner appears.
3. Press 1.
4. Press ENT. Initializing please stand by. appears for about 5
seconds.
Do not turn off the scanner until the initalization is
complete. When the initialization is complete, M000
appears on the top line of the display. Bank 0 Ch 00
appears on the third line.
Notes
Notes
Mar 20, 2013 | Uniden Radio Communications
Error C3100
This code means machine's scanner home possition error. Try to check scanner home possition sensor if fixed in its possition. if not try to check scanner lamp unit movement .
Jan 20, 2013 | Kyocera FS-1035MFP
Radio shack pro-96 scanner screen blinks and loss of audio
3. Press 1.
seconds.
Notes
Notes
Jan 10, 2013 | Radio Shack Pro-96 Scanner
Looking remove all stored channels from scanner and start over.
Initializing the scanner will erase all programmed information and return your scanner to its original factory settings. To initialize your scanner:
- Power the scanner OFF.
- Power the scanner ON. "Multi-system Trunking Scanner" appears on the display.
- Press 0 (zero) while the above message is displayed.
- Press 1.
- Press ENT. "Initializing please stand by" appears on the display.
DO NOT power the scanner OFF until the initializing process is complete and the display shows "M000 Bank0 Ch00"
Bill B.
Listening in professionally since the 60's
Mar 22, 2011 | Radio Shack Pro-2055 Base Scanner
I have a pro 97 hand held cant get it out of clone mode
Your scanner is designed to automatically enter CLONE mode when a cloning cable is attached, and to exit CLONE mode when the cable is disconnected. If you do not currently have a cable connected, you will need to INITIALIZE your scanner to return it to normal operation. NOTE: Initializing the scanner will erase/delete all programmed data and return the scanner to its original factory settings. Before starting this procedure, be sure that you have a record of all programming information so that you can reprogram your scanner.
To INITIALIZE the PRO-97:
1. Turn the scanner OFF.
2. Turn the scanner ON. "Multi-system Trunking Scanner" appears.
3. Press the 0 (zero) key while "Multi-system Trunking Scanner" appears.
4. Press the 1 (one) key.
5. Press the ENT key. "Initializing please stand by" appears on the display for about five seconds.
Do not turn the scanner OFF until the initialization process is complete. When it is complete "M000" will appear on the top line of the display, and "Bank 0 Ch 00" will appear on the third line of the display.
Once the process is complete you can begin to reprogram the scanner.
Bill B
Listening in since the 60's
Oct 06, 2010 | Radio Shack Pro-97 Handheld Scanner
LOCK ALL CHANNEL
If all channels are showing the lockout icon, and all are displaying the frequency 000.0000, you just need to program the scanner. Entering a frequency will remove the lockout.
If all are showing lockout and programmed frequencies, and the scanner will not function, you need to initialize it. This procedure will erase all data that you have programmed into the scanner and restore it to original factory settings.
- Turn the scanner OFF, then power it ON again. "Multi-system Trunking Scanner" shows on the display.
- Press 0
- Press 1
- Press ENT
"Initializing please stand by" shows on the display for about 5 seconds.
Do not turn the scanner OFF until initializing is complete and the display shows "M000" on the top line and "Bank 0 Ch 0" on the third line.
Need more information on your scanner? You can download/print the operating manual here:
http://scancat.com/OnLineHelp/OEM_Radio_Owners_Manuals/PRO-97_OwnersManual_ome20-527.pdf
For a comprehensive database of active frequencies and systems in your area, visit:
www.RadioReference.com
Bill B
Apr 21, 2010 | Radio Shack Pro-97 Handheld Scanner
Duel trunking lites up stillno reception hand held scanner 1000 c
If the scanner is completely locked up, you need to reinitialize it, but be aware that this procedure will erase/delete all information that you've programmed into it. To initialize the scanner:
3. Press 1.
seconds.
Need the complete manual for your scanner? You can download/print it here:
For a comprehensive database of active frequencies and systems in your area, along with a lot of useful scanning data, visit:
Bill B
Apr 05, 2010 | Radio Shack Pro-97 Handheld Scanner
I have a a hand held radio shack triple trunking pro-164.someone thought they knew how to program it , and know it is worse than before. is there a way to clear it out and start fresh?
Radio Shack calls it "Initializing," but to totally reset the scanner to factory settings,
“Multi-system Trunking Scanner”
appears.
2. While “Multi-system Trunking
Scanner” appears, press 0.
3. Press 1.
4. Press ENT. “Initializing please
stand by” appears for about 5 seconds.
appears on the second line of the display.
“Bank 0 Ch 00” appears.
Note: Do not turn off the scanner until
the initialization is complete.
Need the manual for your scanner? You can download/print it here:
http://rsk.imageg.net/graphics/uc/rsk/Support/ProductManuals/2000164_PM_EN.pdf
BillB
Jan 19, 2010 | Radio Communications
Nois from the scannermecanism under initalizing
The problem is not in stop sensor.It's in scanner section.The scanner is not initialization couse inside in section has a to much ash on mirrors and the scanner lamp.Replace the scanner section or clean up it.
Sep 28, 2009 | HP OfficeJet 6110 All-In-One InkJet...
HP LaserJet 3030 All-In-One Printer Logo
140 people viewed this question
Seeker5211
Seeker5211
