Opened up one of the earcups and dont ask me how it was just by force. The cable that connects the 2.5 to the speaker is frail and there is quite a bit of shielded cable that can rub against each other over time. I fixed it by removing the cable and soldering in two separate cables of similar size.
When you pull the wire up does it increase the right ear bud volume/ sound? If it does, then it means the right side ear bud has a short within the head phones circuit which is aka the wire that leads to the musical device in which the ear buds branch off from.
If the right side ear bud does not produce an increased volume for sound by picking the wire up or pulling it in towards you or to the left side of your body or musical device then it means that the right speaker is blown.
I know that all head phones come spiced together aka they are stuck together and have to be pulled apart in order to get both head phones seperated from each other so that they can be worn in the ears. If you pulled the wire apart to much or too quickly then that is what ruined the right head phone.
I suggest that regardless if the ear phones begin to work by pulling the wire up,side ways, or into towards your body that you return them back to the store since after awhile the problem will eventually continue to happen causing the right ear bud to completely blow. Once you return the ear phones be cautious with the new set when you seperate the ear buds from each other since they are very touchy and have to be handled with delicateness when seperation is taking place.
Please let me know how it works out for you. I have had many ear buds and I tell ya something; they are very easy to blow one side when seperating. I had to learn after a few pairs that I was ruining the speakers by the way I was seperating my wires. I kept thinking for the first 3 pairs that the store was selling blown ear buds until I began having same problems with another few stores so I said to myself "well the solution is to figure out what I am doing wrong in order to blow one side of my ear buds every time". After few seconds it was not that obvious that all I had to do for assembly was to pull the wires apart in order to get both ear buds to go into my ears.
Unplug the dryer first, of course. With a putty knife, locate the clips under the front of the main top to release the spring clips. Lift the top and support it open. Disconnect any wire clips that are attached to the front panel, such as the door switch wires or wiring harness. There may be a zip tie attached to the wiring harness that you have to remove simply by cutting it off. On the inside, remove the front panel mounting screws down along the front inside edge of the panel. Pull the front panel up and out to remove. Disconnect the wires from the light bulb, carefully noting which wires go where, and press the release tab to remove the old light bulb housing. Install the new bulb and assembly by inserting it into the front panel and snapping it into place. Reattach the wires. Replace the front panel by aligning the slots at the bottom of the panel with the support clips. Lift on the front of the drum as you snap the front panel into place. Replace the panel screws and reattach any wiring that you disconnected to remove it. Rotate the top back into place, pressing down on the front to secure the spring clips. Plug it back in and voila! Good luck!
If you want to reattach the wires inside sure by all means. It will take a bit of soder and a sodering iron. The contacts for it should be obvious to the naked eye. It probably would be less hassle if you just replaced them though.
the wire is bad. usually at one end by the plug or up where it gos in the head set. as a rule this wire is made cheap you can get a new wire (Good stuff) installed or get a new end put on or shorten the headset end and reattach it inside.
you could have blown the right earphone but its more likely that you have a damaged wire or connection somewhere. move the wire around and see if that fixes it.
what happens is inside the cord where you have your ear phones connecting to your ipod, there is a thin wire that can easily brake. it happens if u for example, rap your ear phones around your ipod. if your rap the chords to tight, the wire can break. it can even brake when you move the cord too much. such as spinning it, shaking it and such. the wire that breaks connects to one side or both sides of your earphones, which produces the sound. if you can hear only on one side, the cord is damaged and cant be fixed.
i would go and buy new ear phones i perfer skullcandy in-ear earphones because the wire is secrurly wrapped, and doesnt brake easily such as other producers. the skullcandy ear phones are in my mind are much better then other earphones. you actually feel like your in the room or at a live show.
It's more than likely a small wire that has snapped inside the cable due to stretching it's probaby not worth fixing as the wires are very small and delicate ,nowadays people just buy a new set of headphones.John
