Question about Cameras
Camera will not turn on, and the battery is charged
  • 477 Answers
Try removing the battery for 24 hours and this could fix it. I repair these all the time and sometime they need to be discharged before they work again. hope this helps.
Posted on Apr 15, 2008
Battery exhausted message no battery charged
The manual says:
Confirm all connections.
Off is selected for Charge by computer in the setup menu.
When charging by connecting the camera to a computer, battery charging stops when the camera is turned off.
When charging by connecting the camera to a computer, battery charging stops if the computer is suspended (sleeping), and the camera may turn off.
Depending upon computer specifications, settings, and status, it may be impossible to charge the battery inserted into the camera via computer connection.
So be sure you are charging the correct way. Best way to do is to remove the battery and put it on the charger for a couple of hours. If you have the battery out, you can check all connections of battery and in the camera.
In trouble shooting, more than a full page is dedicated only to the battery and the method of charging. The manual is still online, but should also on the CD you got with the camera.
Nov 16, 2013 | Nikon Coolpix 3200 Digital Camera
Gopro charging problems flashing
GoPro battery dead. Won't charge in the camera. No charge light comes on when you connect the camera to a USB. There's the scenario. Good tip on the GoPro battery shocking technique posted by Rabscuttle above. I discovered that my vehicle USB cigarette lighter adapter drains the GoPro battery when it's turned off. With the GoPro battery completely dead, the camera will not charge it. If the GoPro battery voltage falls below a certain point, the camera's circuitry is set to turn off the internal charger as if there's no battery in the camera at all. The recommended solution is to buy an external charger, which is able to charge a completely dead battery. The battery shocking method saves that expense.
Connecting a 9 volt battery to the GoPro battery for 30 seconds can give the battery enough charge to allow the camera to recognize the battery. A 9 volt battery from a smoke detector, a pair of jumper leads, and two straight pins is what I used to get my GoPro battery charged enough to allow the camera to recognize the battery and begin charging.
battery_zps064fc8f6.jpg?t=1415296281
img_2564_zpse9e14b4e.jpg?t=1415296297
May 30, 2012 | GoPro Cameras
My nex tech binoculars will not turn turn on . Batteries are good
Was the camera dropped??
If it wasnt dropped try changing the batteries.
install a new or fully charged battery/batteries into the camera.
1. If the camera is on, turn it off.
2. If any accessories (memory card, lens, USB cable, camera or printer dock, etc.) are connected to the camera, remove/disconnect them.
3. Remove the battery/batteries from the camera.
4. Verify:
That you are using the correct battery/batteries for the camera
That the battery/batteries are correctly installed
That the battery/batteries are fresh or fully charged
Follow the battery installation and charging instructions in the camera User Guide
5. Turn on the camera.
Feb 08, 2011 | Cameras
I have sony cybershot dsc 10 digital camera but it dsn't power on batery charge is full
Please make sure that the Battery in the Camera is fully charged.
Please check if the issue is with the battery charger. Make sure that the Charge Lamp in the Battery Charger is lit when connected to the Wall outlet.
You can try recharging the battery pack for almost 6 hours as initial charging.
If you've another battery pack, try using the same to check if the issue is with the Camera or with the battery.
You can also try turning on the Camera by connecting the optional ACL-S5K AC Adapter. This Adapter can be used for turning on the Camera, it cannot be used to charge the battery pack. For charging the battery in the Camera, the supplied battery charged needs to be used.
If the Camera is not turning on using both the AC Adapter and new battery, then the Camera may require service.
Thanks for using FixYa.
Jan 10, 2011 | Sony Cyber-shot DSC-H10 Digital Camera
I have sony digital camara but it dsn't power on batery charge is full
Jan 10, 2011 | Sony Cyber-shot DSC-H10/B Digital Camera
I have sony digital camara its not power on plz help me
Jan 10, 2011 | Sony Cameras
My m863 kodak camera charging light won't turn on.
Is the camera charging? Remember when charging thought the computer NOT to switch the camera on since this will deactivate the model to charge. Try the following: 1. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Turn the camera on. 2. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a no power repair with KODAK or a new cable.
Jan 24, 2010 | Kodak EasyShare M863 Digital Camera
Should the power light be green or red, when I turn camera on it shows a green light then turns red
Red light indicates that the camera is out of charged., Try to charged your battery for 3-4 hrs if you encounter flashing red on a fully charged battery you need to call kodak 1 800 235 6325 ext 12
You can charged you camera using 5V AC Adaptor or a USB cable taht attached into the computer
Nov 16, 2009 | Kodak EASYSHARE M1063 Digital Camera
Battery keeps dying
Most likely the charging circuitry has failed. When you fully charge the new battery what does the battery meter read on the camera? Your two options no matter what the case are repair vs. replacement. If you need further assistance let me know.
Thanks,
Lee
May 13, 2009 | Casio Exilim EX-S500 Digital Camera
Sony dsc-s600
1= Use rechargeable battery cells and must be fully charged.
2= Check battery terminals in camera battery compartment. Must be cleaned and shiny.
3= Sony camera DCS-S600 won't charge batteries through USB cable plugged in PC. You need external battery charger to charge battery cells.
Oct 22, 2008 | Sony Cyber-shot DSC-S600 Digital Camera
Cameras Logo
76 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
