Denon Dn-X1500 Professional DJ Mixer System Logo
Posted on Jun 25, 2010
Why is my Denon DN-X1500 showing a version up error in the screen every time i power up the unit
5 Related Answers
Anonymous
  • Posted on Nov 19, 2008
SOURCE: How to reset my Denon DN-V210 DVD Player to factory default?
Hi Jason,
I have just bought this unit and have been using the menu recently. The only ways i can see to do it would be to either, (as you say) plug it into a HDTV, or navigate the menu blind and hope for the best.
If you press SETUP on your remote once to get to the menu setup screen and then push the RIGHT navigation button 3 times this should take you to the system setup screen. Then push the DOWN navigation button 4 times and then push ENTER. At this point it asks you for a 4 digit password to reset the unit which is a factory preset, 5555, so type that in. This should then reset the DVD player to factory settings.
Hope it helps,
Nick
funkwafffle
  • Posted on Nov 30, 2008
SOURCE: TOC ERROR ON DENON DN-C615
Take this info with a grain of salt. I recently received one of these units with a TOC error, and after removing the drive assembly and reinstalling it, the problem went away. Before removal, I observed the motor spinning poorly and even backwards. Rather than pull the whole drive assembly, I would first eject the drive and remove the face from the tray. This is done by putting your thumbs on the tray and pulling up with your pointer fingers underneath the face. It should just snap off and snap back on the same way. Try playing a disc now, if it works try loosening the screws on the drive assembly and shifting the assembly towards the front of the unit, tighten the screws and put the face back on. You should be good to go. There are four screws holding the assembly down, the two in the back can only be accessed when the tray is in the open position. The front two are accessible through holes in the tray, and I don't recall if the tray has to be open or not, but that's easily observable. If it's still not working, there is a flat-flex cable running to the laser assembly. Pull and reseat this gently. Try to only manipulate the cable by the blue reinforcement tab. I hope this helps!
Anonymous
  • Posted on Feb 20, 2009
SOURCE: need an instruction manual for denon dn-1800f?
http://www.denondj.com/Assets/Dimages/Products/Manuals/cd709d3d980d4f2d8013fea6e875c68d.pdf?ts=062556
bhatgiri73
Girish Bhat
  • 106 Answers
  • Posted on Jan 24, 2010
SOURCE: Hi. My denon dn s3500 just says disc error when I
clean the lens...if it does not work replace the lens.
Dennis McCollum
  • 137 Answers
  • Posted on Apr 22, 2010
SOURCE: denon error 104
error 104 is unable to actuate focus. Which means the laser lens assembly is most likely defective
Denon-x1500 not able to find sofware for windows 7
Just log in on the denon dj site and you can get the latest firmware and driver and manual. Read it and everything you need to know
is listed in the manual
gr. richard
tip
DISASSEMBLING SERVICE MODE AND POWER SUPPLY CIRCUIT
DISASSEMBLING
(Follow the procedure below in reverse order when reassembling.)
1. Top Panel Unit
(1) Remove 9 side screws and pull up the Top Panel Unit.
(2) Disconnect FFC cable and Connector.
(3) Detach Top Panel Unit
Note : Do not pull out aslant to prevent FFC cable damage.
Do not fail to pull AC cord from wall outlet before disconnect the FFC cable.
If AC cord is remained plugged into wall outlet,
power is kept supplied in the unit, which may cause
danger.
For more check the following link
http://electro-medical.blogspot.in/
1helpful
Denon DN-C635 CD Player problem.
In working with consumer electronics a lot of years, the pickup, mechanism or CD section is not always at fault but people that
are trying to work on their own equipment make assumptions that may not be correct. If you put in a new CD player then the other issues as with all wave soldered equipment can be bad solder joints and even bad solder at joints where the connectors are as these get a lot of activity in a repair. Look at the PCB well. I have fixed a lot of equipment by resoldering bad or broken joints. Check around power transistors and those larger drive transistors for these broken joints.
CDJ NOT READING CDS. STATES (DISC ERROR)
If it shows No Disc error to all CDs, either its Sled Motor [The motor which spins the disc inside], or its optical picku unit has the fault. You have to contact the nearest Denon authorised service center to get it repaired, as Denon uses special type machanism with theirs sets, and it can't be available at open electonic spare part market.
The Denon DN-C680 gives ERROR 105 on the display. Why?
How do i connect my laptop to denon dn-x1500s?
just download the driver from the site and select him as soundcard, but read first the manual
1helpful
Headphone cue buttons on dnx 1500 not working and fx button they work but stick on or are hard to turn off
pulled the cover plate off cleaned switches with freeon put back 2getha all sweet but 4 how long i don't know thanks any way DAN
Denon DN-V210 won't play DVD's burnt with Final Cut Pro
Then the format can't be read by the MAC, what reason this is I have no idea.
Power conversion
If you have 110 - 120 volts AC at 60Hz, then the mixer must be bad. Unless 50 Watts isn't enough. Does the voltage drop when you plug in the Mixer to the convertor?
Geno
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Sean Wright
Sean Wright
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
