Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Replaced Lamp to no avail
Steady yellow was showing; replaced lamp.
Now steady red with no power. I've been told it is a ballast.
Black screen, new bulb ....told the ballast gone , solid red code 34 .... and an outrages price to fix is it the ballast ???
  • Mitsubishi Master
  • 8,617 Answers
That problem is caused by two bad 100Uf capacitors on the PWB . you will need the manual to be able to get the chassis out and I dentify the correct board. Go to this link get the reapair manual they will give you free tech support and when they email your manual ask then if you can have Sonny for your free support. He can fix that chassis in his sleep, and he will tell you the exact capacitors that need to be changed and you set will be as good as new. heres the link
http://servicemanuals.vstore.ca/
Posted on Apr 18, 2008
Installed new lamp. When powered up blue solid light and yellow blinking light (15x) , tv would torn off and on several times trying to light lamp. Once that failed red blinking light and yellow solid...
Hi Genaro,
Blue led light lit solid and yellow led light flashes is an initial attempt of the set to re-light the lamp.Red led flashes and yellow led light solid means that the lamp won't light up that's why it only has sound without the picture.
Since you've replaced the lamp twice and still the symptoms persist, I suspected that the fault came from the ballast board and not on the lamp itself. If the ballast board gone to malfunction, there's no high voltage will produce to light up the lamp and will sensed by the processor and trigger the error code (Flashes/solid led light with color code).
To verify whether the ballast board is faulty or not, check if the lamp will lit by looking through the lamp door louvers at the rear of the cabinet upon turning on the set.
Please let me know what you will find to assist you further.
Jdvillanueva
Nov 05, 2011 | Toshiba 65HM167 65" Projection Television
Misubishi wd-52631 DLP TV, it shuts off suddeny. when turn it on again, the green power light is flashing, then steady green, then shut off again. the lamp light is NOT falshing or red. the status light...
Hi, have you replaced the lamp after 2-3 yrs of usage? The lamps used by mitsubishi tend to last around 4000 hrs 1-3 yrs.It is common for the green light to light up.Other common failures are the ballast which is the board that powers the lamp.Also check if its not overheatin, dust out the fans.Heres where u can get the lamp or ballast http://www.discount-merchant.com/SearchResults.asp?Search=wd-52631
Apr 19, 2011 | Mitsubishi WD-52631 52" Projection HDTV
I have a NEC VT470 Projector. The power light is steady orange and the status light blinks red 6 times.
steady orange means projector in standby mode
red light 6 times is a lamp error.
either the lamp is old and wont start up or the ballast power pcb is not working.
can you hear the sparking of the high voltage trying to strike the lamp.
if you can then the lamp may be dodgy.
can you borrow one to test it out
Mar 02, 2011 | NEC VT470 Multimedia Projector
MY LG MODEL RU52SZ30 ( 2003), HAS A YELLOW LIGHT SHOWING BELOW THE LAMP ICON. IS THE LAMP BAD? IT STILL LOOKS PRETTY GOOD ON SCREEN EXCEPT FOR THE A BLUE TINT AREA ON THE RIGHT SIDE OF THE SCREEN
Yes, the lamp is nearing the end of life when the lamp light is a steady orange (yellow). Order a new one and replace it. (When other parts of the lamp system fail, you will see a blinking red light.)
I hope this helps.
Oct 14, 2010 | LG RU52SZ30 52" Television
My KDS-50A2020 TV has an error code indicating a lamp driver fault (5 red blinks). I replaced both the lamp and the ballast and it still doesn't work. I need further assistance troubleshooting the...
Hello.
Ballast in Sony is one of the most reliable parts, almost never goes bad.
I assume you have TV unplugged from the wall outlet to reset error memory (not to mention that you have to do it anyway during ballast replacement).
I hope you are using good quality lamp, because cheap substitute from E-Bay can cause same problem. Lamp and ballast works as duo and on-board diagnostic system is unable to separate them unless lamp is completely blown (in that case you will have steady "Lamp" LED blinking).
You need to set TV up with back cover removed but lamp door attached (there is switch that prevent TV from working if lamp door is removed). You need to locate large 2-wire connector on ballast and make sure that it's getting about 330V DC from power supply board when you turning your TV on. If it's not there - you have power supply board problem. There should be fuse on it (not on the ballast board but power supply board - just trace those two thick wires where they coming from). That fuse could be blown by previous bad ballast shortage.
Small connector on ballast have 5 pins. Some of them ground, one of them steady 5V and another trigger (turn on signal) 5V. Make sure all voltages are there. If there is no trigger 5V - you have problem with main board.
In my experience 90% cases - it is very bad quality new lamp or something is just not connected (forgot to put plug all the way or something).
Russ.
Aug 17, 2010 | Sony KDS-50A2020 Television
Recently my wd-52327 said it needed new bulb(steady orange light). i had replaced the bulb 7 months earlier and didn't want to see the light so i reset the lamp timer. well the bulb blew the next time i...
If you have a voltage meter you can pull the bulb out and check for continuity by placing the probes on the power plugs of the bulb. If you have continuity the bulb should be good, and it may be the lamp ballast.
Nov 21, 2009 | Mitsubishi WD-52327 52" Rear Projection...
TV shuts off after about 15 minutes of running. Shows steady red light on lamp indicator.
red indicator on the lamp is indicating the lamp is defective or the ballast isnt lighting the lamp. Try replacing the lamp. What model set do you have?
Mar 26, 2008 | Televison & Video
Lamp will not come on after replacement
Sounds like a ballast problem. Did you change the ballast or just the lamps? You may want to check your ballast, also the air filter, as this will stop your set from powering on.
Jan 18, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
