Question about Kenmore 63942 Dryer
Kenmore Heavy Dut Model 86427810 runs but does not heat
This clothes dryer runs but does not heat up all of a sudden. I checked the fuse box, and the vent, to make sure it was not clogged. The other info on the label, states: 3 wire, 120/240 volts, 60 hz, 4.0 amp motor, and 23 amp heater & accessories. Please help if possible!
  • 1 more comment
  • Anonymous Apr 15, 2008
    Run but no heat
  • Anonymous Aug 05, 2008
    Same problem here...was working fine and just stopped.
  • Raine80 Aug 05, 2008
    Same problem here...was working fine and just stopped producing any heat.
    Novelist:
  • 142 Answers
You need to have a look at the thermal protection devices and the thermostat section and make sure they are functioning such that power is reaching the heating elements. If they are and there is still no heat, the elements are probably malfunctioning. If the dryer is producing ANY heat, then the thermostat and thermal circuit is OK, and all you need are elements.
Posted on Apr 16, 2008
I have a kenmore dryer 80 series it only makes a lite sound when I push the start button. I won't come on. The power is good.
The Kenmore 80 Series of dryers are consumer grade dryers for home use. As with most home appliances, the Kenmore 80 series dryers will occasionally not work as intended. If a problem occurs with your dryer, however, you do not necessarily need it serviced by a technician. You can attempt to troubleshoot and fix any problems with your dryer before contacting a technician.
  1. Kenmore 80 Series dryers may not run for several reasons. First, make sure that the power cord is plugged into a working power outlet. You may need to plug a different device into the outlet to check that it is receiving power. If the second device does not run on the power outlet, you may have blown a fuse or tripped a circuit breaker. Check your fuse box or circuit breaker box and make the change as needed.
    Next, make sure that the dryer door is fully shut. The dryer will not run with the door ajar.
    Finally, check that the "Start" button was fully pressed and that a cycle was chosen on the machine. If you do not choose a cycle for the dryer, it will not run.
  2. If your Kenmore 80 Series dryer does not heat up during use, check that a heat cycle has been chosen for the load. There are several different dryer cycles you can choose, some of which do not use heat. Make sure that you have chosen a heated cycle.
    As above, check that you have not blown a fuse or tripped a circuit breaker. The dryer may use more than one fuse or breaker: one is used to power the drum, and the other for the heating element. Make sure that both fuses or breakers are in working order.
  3. There may be times when Kenmore Series 80 dryers do not fully dry your clothes. When this occurs, check the lint screen and clear out any lint. The air may not flow as well if the lint screen is clogged.
    Next, check to see if the exhaust vent is clogged. Lint and other particles may clog the exhaust vent over time, restricting air flow and making it more difficult to dry your clothes. To check the vent, run the dryer and hold your hand under the vent. If you do not feel any air flow, clean or replace the vent.
    If you used cold water to rinse the clothes it may take longer than normal to dry. The same is true if the load of laundry is very wet or is filled with items that are very absorbent.
    Finally, check the load size. The more clothes in the load the longer it will take to dry. If you want to reduce drying time, separate the clothes into piles of light and heavy items and dry them separately.
  4. please comment on these solution by saying how helpful.
Dec 22, 2010 | Kenmore Dryers
I have a kenmore 80 series, It starts and runs fine, but there is no heat inside, the clothes are not getting dried. What should i do??
Check your household fuse/circuit breaker box. The dryers run on 2 fuses -one for drum motor and one for heat. Remember, if it's fuses, you need to replace it with a "p" type fuse.
Mar 14, 2010 | Dryers
Kenmore electric dryer (model # 110 60202990) dried a load of clothes like normal. But with the current load, it suddenly stopped heating. How can I fix this?
Hello Friend, Your problem is very simple to fix. You need a thermal fuse, very simple and affordable to replace. To replace the thermal fuse just remove back cover of dryer and look down where the air blows out. Now, just to the left where all the wires are you will see a white plastic part with two wires plugged into it. This part is called a thermal fuse. Just remove these wires and replace the thermal fuse. Your dryer will run like new. Happy to help, Tim.
Jun 12, 2009 | Kenmore 64742 Electric Dryer
Kenmore 70 Series Dryer Model# 110.64742400
check the thermal fuse if it is blown also change the high limit thermal cut-off fuse www.repairclinic.com shows your parts. go there and enter model number. Also check the heat element. to get into it remove the lint filter and the two screws you'll see there then pry the top up at the front corners. And through the back you should find the heat element and blower housing and thermal fuse and high limit fuse and cycling thermostat.
Apr 06, 2009 | Kenmore 64742 Electric Dryer
Kenmore Dryer not heating
thermal fuse kit.it is blowing due to improper ventilation.their is a clog somewhere from dryer to where dryer vents outside.thermal fuse is located at top of your elemnt cage.you will replace the thermal fuse and your high limit fuse at the bottom of the elemnt cage.but have your venting checked or swept out.
Mar 09, 2009 | Dryers
Kenmore heavy duty clothes dryer will not heat
REMOVE THE BACK AND CHECK THE HEATER FUSE AND THE HEATING ELEMENT-MIKE
Feb 25, 2009 | Kenmore Dryers
I am currently having a problem with my Kenmore Dryer. It is running but it is not heating up to dry the clothes. Someone told me to take the back off and check the heating element but I can't find the...
I would check your vent if I were you disconnect the vent and run the dryer to see if it works better. also clear the vent line. good luck
Jan 10, 2009 | Dryers
Kenmore 70 Series Dryer Won't Heat
won't heat. fuse good,breaker good,heating element test ok. How do I check the thermostate, and timer.
Apr 29, 2008 | Kenmore 63942 Dryer
Kenmore heavy duty dryer
You didn't mention if the motor runs or if it heats. If it does both of these, you'll need a new belt.
Mar 09, 2008 | Dryers
You really need a volt / ohm meter to check for Continuity & Volts Its well worth the investment... $15.00 bucks give or take a few I would check to see if you have 220v to back of dryer where the cord mounts to dryer, If dryer is getting only 1 leg 110 volts instead of the 220 will it not heat. Check themostates & heater for Continuity... Most models, Now have a.. Hi-limit fuses that need to be checked for Continuity
Oct 08, 2007 | Kenmore 63942 Dryer
Kenmore 63942 Dryer Logo
461 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
