Here are some steps you can take to troubleshoot and potentially resolve the issue:
1. Make sure the scale is on a flat, stable surface: Uneven or unstable surfaces can affect the accuracy of the readings. Place the scale on a hard, level floor and ensure it is not wobbling.
2. Check the battery installation: Double-check that the new batteries are inserted correctly, following the polarity markings inside the battery compartment. Ensure there is good contact between the batteries and the terminals.
3. Calibrate the scale: Some digital scales require calibration after battery replacement or when experiencing issues. Check the user manual for instructions on how to calibrate your specific model. Calibration usually involves placing a known weight on the scale and adjusting it accordingly.
4. Clean the scale: Dirt, dust, or debris on the scale's surface or sensors can interfere with accurate readings. Use a soft, slightly damp cloth to clean the scale, ensuring it is dry before use.
5. Try weighing yourself multiple times: Step on and off the scale a few times to see if the error persists. This can help determine if the issue is consistent or intermittent.
Step 1
Step lightly on the scale until it displays "--", "0000" and turns off if you receive the error "ERR0," which means the scale is not initialized. Initialization must occur after each battery installation.
Step 2
Set the scale on a flat, even surface, not on surfaces such as carpet if you receive an error "ERR1."
Step 3
Step off the scale and wait for it to reset before stepping on it again if you receive an "ERR2," which often means the unit was jarred or overloaded. Also, if you weigh more than the maximum weight capacity you will receive this error.
Step 4
Remove your shoes and socks and wet your feet slightly with a damp cloth if you receive the "ERR3" error. ERR3 is a contact error and your feet should ideally be bare and wet to achieve an accurate body-fat reading.
Step 5
Step off the scale and wait for it reset. Remove your shoes and socks and wet your feet slightly if you receive either the "ERR4" or "ERR5" errors, which means your body-fat or body measurements are out of range.
Step 6
Reset the scale if it doesn't work or you continue to receive error messages. Remove the battery and set the scale on a flat surface. Stand still on the scale for five seconds and step off. Re-install the battery and place the scale back on the flat surface. Place one foot on the scale until it displays zeros or dashes. Remove your foot and wait for the scale to turn off. Step back on the scale to weigh yourself.
Step 7
Replace the battery if you receive a "lo" or "bat" error.
If it's any consolation, my Jobar/Ideaworks JB5413 has developed the identical symptoms, although occasionally it will start working briefly. Batteries are new, and no corrosion in the battery compartments. I am thinking about just junking this nicely styled scale; what a shame.
Here are the basic ERR messages and their meanings:
Error 0: Initialization
Error 1: Instability (scale is on an uneven surface ex: carpet)
Error 2: Unit may have been jarred or unit was overloaded (customer went over the maximum weight capacity)
Error 3: Contact error (Feet were not wet for Body fat reading, feet aren’t big enough to reach sensors)
Error 4: Body fat is out of range
Error 5: Water is out of range
I got an ERR2 message and now the scale doesn’t work. What should I do?
The following reset procedure is used when the scale shows an err2, err, 0.0, inaccurate weight, or some other unusual error.
Remove the battery from the scale.
Sit the scale on a hard surface floor.
Step up onto the scale, stand still for about 5 seconds and step off the scale.
Re-install your battery.
Place the scale back on a hard surface floor.
With one foot only, place just enough weight on the scale for the display shows zero’s or dashes. Once you see zeros or dashes remove your foot.
Wait for the scale to turn off again.
Step up onto the scale for a weight.
If the reset is successful, you should receive a weight right away. If you continue to receive one of the error messages above please call our Customer Service department or contact us via email. You can also try the reset procedure a 2nd time. Sometimes the reset procedure will work the second time.
This is a reply I received from Taylor customer support. I have followed this procedure enough times to wear out the original battery and still get the Err 1 message. You may have better luck.
Thank you for your e-mail. The reboot below may clear the error from your scale. You may need to do this several times to completely reboot the system. Please let us know if you have any questions or continue to display the Error.
1. Remove the battery from the scale 2. Set the scale on the floor without the battery in place. 3. Stand on the scale for 10 seconds (still without the battery) 4. Carefully replace the battery without turning the scale on. 5. Using only one foot, tap the scale or apply just enough pressure to turn on the display. (It should show dashes or zero's) IMMEDIATELY REMOVE YOUR FOOT. 6. Let the scale turn off 7. Step on the scale for a weight reading
Regards,
Linda DLT Consumer Relations Taylor Precision Products & Salter Housewares 2220 Entrada del Sol, Suite A Las Cruces, NM 88001 Toll free - 800-289-0944 866-843-3905 Direct - 575-526-0944 ext 3172
Basically, the frisbee comment is on the mark. I called Taylor. a nice person walked me through a calibration exercise: take batteries out; stand on scale for 7 sec.; get off; put batteries back in (assuming they are still good); step on scale and if it reads ---- step off again, then back on to weigh yourself. My scale's display was blank, not -----, so they said calibration was unsuccessful & so I mailed it back to the NM address on the bottom. It just fits w/ padding diagonally in a USPS flat rate box. Waiting to see if they replace it (lifetime warranty).
