Question about HP LaserJet 1020 Printer
Please there are dots of powder on roller, this makes troubles when printing .I cleaned it several times but the problem is still.
  • sun rise Apr 15, 2008
    that dots are comes to be in charge roller
  • suresh thomas thomas May 11, 2010
    please say that dots are comes to be in which roller
    Problem Solver:
  • 15 Answers
Are you using original toner cartridge or refilled cartridge ?. If this problem comes to your original cartridge, then better to replace with another original cartridge. Dots comes to your refilled/ recycled cartridge is due to the problem of its drum, doctor blade, wiper blade, pcr rollers etc.. and check weather your cartridge is getting leaked, if so replace a new one.Some times transfer roller and pressure roller and scanner assembly insdie the printer may damaged or dusted due to insects. Open the machine and check all these parts.
Posted on May 02, 2008
  • 88 Answers
If you are using original hp catridge (not refilled) u got warranty exchange it
else change the drum it costs around 4$
Thank you
Take care
Bye
Posted on Apr 18, 2008
2 Suggested Answers
  • 15 Answers
SOURCE: please
this the cartridge problem, change the cartridge with new one
Posted on Apr 29, 2008
I have a problem with the colour prints...there are different kind of lines all over the page..how can i clean the laser heads?is there any automatically way?
Dots, Lines and smudges on the printouts are due to deteriorating cartridges and cleaning the green drum of the cartridge may help temporarily. Take out the cartridge and gently clean the roller/ green drum with a dry, soft, lint-free cloth wiping off the toner dots marks/ lines. (corresponding to the location where you are having a green line on the paper)
Also, make sure that the visible inside of the printer is clean and there is no spilled toner inside, which sometimes results in dots.
Moreover, streaks (thicker lines) and dots etc indicate faulty PCR Roller which is located behind the green drum inside the cartridge. Replace the Cartridge or get the PCR Roller changed by a professional.
Try cleaning the toners and see if it makes any difference. You would also have an idea about the toner drum/ parts quality etc and check if they need to be replaced. Furthermore, issues with Laser Unit like dust/ toner dust on the lenses and mirrors inside the printer usually result in faded or discolored prints. For instance, faded text/ picture at certain areas or any color missing when you print.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jun 21, 2011 | HP COLOR LASERJET CP 3505 N PRINTER
When making copies one edge of the paper has three dark spots. Look as if they could possibly be roller marks? Something need cleaned? Thanks
hello
probably right, remove your toner drum and clean it with tissue paper or smooth cloth, this dots happen when your roller drum has some spot on it due to ink powder and also slide the tiny button on the fuser kit to clean it.
thanks
Apr 14, 2011 | Brother MFC8890DW AllInOne Laser Printer
Hi, my HP2600N colour laser jet leaves two 1cm wide coloured smudge lines length ways on all my A4 prints. The printer is getting to about 2 years old now so i'm fearing that some major part needs...
Rest assure that the printer is fine and needs no major replacement.
Don't forget to convey your feedback
CreativeTECH
Jan 22, 2011 | HP Color LaserJet 2600n Printer
Using Brother Printer HL-2040, not so many pages printed, but have some dot in pages about 3 black dots and some fade letters. what should i do to clean drum?
Remove the cartridge and look carefully at the rubber roller. You have debris stuck on the roller that needs to be removed. Get a cotton ball and dab some rubbing alcohol on it. Then run the cotton ball back and forth over the rubber roller making sure to use a clean section of the cotton ball each time. Now advance the rubber roller and repeat with a new alcohol cotton ball. Do this until you made it all the way around the rubber roller. Allow to dry for 10 minutes and then insert the cartridge back into the machine.
Nov 12, 2010 | Brother HL-2040 Laser Printer
Vertical fainted dots in the middle of the page
turn on/off, unplug, wait a minute, plug back in, should reset.
take all paper out. check to see if any paper is jammed in the rollers or if there is something causing the ink dispensary to dribble
go to application folder for your computer, dbl click icon for make of printer, for settings, check to ensure everything is order. run a 'test' print to clean the drum, this might help
lastly, check make of printer trouble shooting web site for more information
hope this helps, good luck.
Apr 29, 2010 | Brother HL-2170W Laser Printer
Rollers on Pixma 2600 won't pull paper through
Unfortunately you have come to a dilema of the printer world. The rollers are mearly chunks of rubber, expected to last forever and pick up pieces of paper. Every time a piece of paper is picked up, it drys out the rollers, and dust covers the rollers. Here is a temporary solution.
Temp Solution: Open the printer, look for rollers, you will likely find several small black in color, rollers. You may see cracking, or white powder on the rollers. Even if you don't, here is your solution. Take a damp paper towel, and wipe each roller thoroughly. Make sure you look all around to make sure you are getting all rollers.
Longer solution: Purchase a maintenance kit for your printer. I know HP carries them for their printers (HP is the way to go with printers). They will include rollers, and little tools to obtain the rollers along with detailed instructions. If they do not make one, find one broken on ebay for 12 dollars and get that. The kit would have cost you between 12 and 30 dollars anyways.
I wish you the best of luck. Please e-mail me if you still have issues. Chris173@gmail.com
Sep 20, 2009 | Canon Pixma iP2600 Photo InkJet Printer
Please
Apr 15, 2008 | HP LaserJet 3030 All-In-One Printer
Samsung 1710 stops after warm up
Chances are, you're getting paper jams.  Try cleaning the rollers (as indicated below.)  If that seems to help the situation, then you'll need to get new feed rollers.
Look where you put the paper in. See if you can see inside there and see the roller that turns and picks up the paper. If you can, make a mixture of alcohol and a little dish soap. Damp a rag with it, and reach in there to clean the rollers.  See if the rollers will turn manually, but be careful not to force anything.  Another way to get to the whole roller, would be to start making a print, while watching the rollers.  As soon as the rollers have turned half way, unplug the printer.  Now you can reach the other side and clean that.
There is another way to clean the rollers.  Using the alcohol mix, take a single sheet of paper, and damp one half of it with the solution.  Stick the single sheet in the paper tray, and make a print, but hold on to the paper so that it doesn't feed through the machine.  Do this several times, and the rollers turning against the wet paper should clean them.
Try to print again. It might take a few tries. The rollers have to turn against the paper and dry themselves off again.
If this works, then you need new rollers (cleaning them will only make them work temporarily and the problem will come more frequently until you change them).
Thankyou,
Oct 29, 2007 | Samsung ML 1710 Laser Printer
Dots on page
shivan, did you change the toner if it yes then open printer and clean the surface of toner and the roller see is there any dust or ink powder is there. bye
Sep 22, 2007 | Brother HL-5280DW Laser Printer
Black dots on copies.
Try using the roller cleaning or wire cleaning procedure in additional functions. If fault persists, it might be toner build up on the fuser roller from dots worn onto the surface on the fuser rollers.
Aug 03, 2007 | Canon ImageRunner 3320N Copier
HP LaserJet 1020 Printer Logo
89 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
