Question about NEC MultiSync MT830 Multimedia Projector
Projector vertical running lines
I have an epson 821p mounted in ceiling a media center at my school. The projector is wired to the wall I have two computer lines going in vga mode, I have then the wire coming out to the ceiling and going into the projector. We have a company that comes out and installs them this way for are whole district.
I have other electronics running thru the ceiling, heating cooling, lights, infared sensors for alarm. I have tried several projectors and get the same results I have lines continually running thru the screen. Is something interferring? They are white lines, no color in them. The run vertical and scroll thru the whole screen. The sound seems to hum too. Any assistance would be greatly appreciated
  • 563 Answers
Hi there
This is definatelly a interference from a power cable. If any of your signal cables in the ceiling is closer that 5cm to one of those , you will get interference.
The Company that did the installation should know this and I would suggest you call them and tell them that they should sort it out. They should either move the cables or insulate them by means of conduit.
Posted on Apr 16, 2008
Upside down picture
turn the projector up the other way,
or
Press the Menu button.
Select the Advanced menu. You see the features and their settings on the right side:
Press Enter and use the directional buttons and the Enter button to set the following option:
Projection
Front: Projector is in front of the screen
Front/Ceiling: Projector is in front of the screen, mounted upside-down from the ceiling
Rear: Projector is behind the screen
Rear/Ceiling: Projector is behind the screen, mounted upside-down from the ceiling
Feb 22, 2011 | Epson EMP-54 Multimedia Projector
Wanting to mount this projector from ceiling. How and what bracket should i use.
get the epson parts
ceiling mount ELPMB35
ceiling mount adapter ELPMBAPS
Feb 22, 2011 | Epson PowerLite 50c Multimedia Projector
How do I flip the image on my Epson EMP 30 projector for ceiling mounting please?
Press MENU on the remote control (as show on picture below)
the menu window displayed
Press down arrow key to select ADVANCED
press ENTER on the remote control
use down arrow key to select ceiling (as show in picture)
press RIGHT arrow key to select OFF to ON status
press MENU key to exit menu
(the projected images are horizontally and vertically reversed.)
Feb 13, 2011 | Epson EMP 30 Multimedia Projector
My projectors image is upside down. how do i fix
Go to Menu> Extended> Projection> select Front ( to project from the front of the screen ).Front/Ceiling ( If the projector is mounted upside-down from the ceiling ). Rear ( to project from behind onto a transparent screen ).Rear/Ceiling ( to project from behind when the projector is mounted upside-down from the ceiling ).
Apr 11, 2010 | Epson EX30 LCD Projector
Epson 77c Projectors occasionally freeze - controls don't work
this is maybe overheating problem, check that the fan on it is working
Fosg2000, please Rate me
Mar 16, 2010 | Epson PowerLite 77c Projector
Image problem
IF I understand the problem from the limited info in your question, the problem is a distorted picture on whatever surface [probably a wall, or screen] onto which the image is projected.
With all lenses, the axis [centerline of the lens projected] MUST be absolutely PERPENDICULAR [in both the vertical and horizontal planes] to the perfectly plane [flat] surface onto which the image is projected.
IF for example, the projector is mounted in a rear corner of the room, and the camera is aimed downward and to one side to project the image on the center of the opposite wall, or a screen located there, the image will be distorted. It will be larger on one edge [fartherist from the lens] and smaller on the opposite [nearest] edge.
If it is non-perpendicular in only one axis, then two opposite edges will be different lengths, and if out of perpendicular in two axis then no edges will be the same length.
The solution to this problem is that the center axis of the lens must be perpendicular to the surface projected on, in both vertical and horizontal axis.
Feb 14, 2009 | Sharp BQC-XGE630U/1 Projector Lamp for...
NEC MultiSync MT830 Multimedia Projector Logo
318 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
