Question about Acer Aspire 3050-1733 Notebook
I dont have an installation disc
When i turn the computer on i get a message saying windows could not complete the installation. To install windows on this computer, restart the installation
  • 655 Answers
Dee,
It means you did not finish your last Windows Setup, or your Windows Operating system has get currepte.
So you must have to Re-install the setup.
  • Or if you have system recovery disk you can make recovery of your windows. But in that case your some programs and data might be lost which you have installed or saved after first boot.
Anayways you can try one thing if it will work then your luck, but am not sure, its depends on the data stored on the system bye your previous OS.
  1. Start you computer after beep, satart pressing F8 till windows boot option menu appears.
  2. Select 'Command Prompt only' from the options, press enter key
  3. If you get the command prompt like C:\> or C:\Windows> or what soever. Type SCANREG and press enter.
  4. Follow the on screen instructions. It will make backup then there will be a list of previous dates on which your system was started successfully, select on of the old date.
  5. Then it will try to boot from that settings.
Please post your feed-back
Thanks
Iqbal
Posted on Apr 15, 2008
When I turn on the computer it says boot mgr is missing. I guess I totally messed up when I tried to do a full system recovery. The discs I have are from geek squad there is tow of them.
An operating system would have been nice ?
How to Create a Windows 7 System Repair Disc:
http://www.sevenforums.com/tutorials/2083-system-repair-disc-create.html
"This will show you how to create a Windows 7 system repair disc to use to boot to the system recovery options if you don't have a Windows installation disc, can't find your
Windows installation disc, or can't access the recovery options provided by your computer manufacturer."
or
If you do not have access to either disc: Windows 7 - Repair Disc download
http://neosmart.net/blog/2009/windows-7-system-repair-discs/
a) Insert the Windows 7 System Repair DVD or Installation DVD and reboot.
b) Select the correct keyboard input method and click 'Next'.
Note: If you are using the Windows7 Install DVD then at the 'Install Now' prompt (Do not pick the Install
Now option) instead choose the 'Repair your computer' option located in the lower left of the dispay.
c) The System Repair tool will search for a valid operating system and will report that "Windows found problems with your computer's startup options. Do you want to apply repairs and restart your computer?"
d) Click 'Repair and restart' and reboot again to the Windows 7 System Repair environment.
e) Click 'Next' at the keyboard selection prompt and when the 'System Recovery Options' screen appears verify that the "Use recovery tools that can help fix problems starting Windows" is selected.
Note that on your Dual Boot system there now should be only one operating system listed. Click the 'Next' button.
f) Now from the menu list select the 'Command Prompt' option.
g) At the DOS prompt type the following three commands:
bootrec.exe /fixmbr
bootrec.exe /fixboot (may return an 'Eliment not found' message)
bootrec.exe /RebuildBcd
h) Close the command prompt window and click the 'Startup Repair' option.
i) The repair process may take some time, so wait until the process completes at which point you will see two messages "Windows cannot repair this computer automatically" and "Startup Repair cannot repair this computer automatically".
These messages are the result of the radical changes made by removing the other drive. Ignore the Send/Don't send options.
J) Close this message window by clicking on the X in the upper right corner of the Send/Don't send window. Next click on the 'View advanced options for system recovery and support' option and from the main menu once again click 'Startup Repair'.
This time the repair process may only that a few seconds and when prompted "Startup Repair could not detect a problem", click 'Finish' and run the 'Startup Repair' option one more time, click 'Finish', and then remove the System Repair DVD and click 'Restart'. Reboot the computer.
hope this helps
Nov 24, 2012 | eMachines ET1810-01 PC Desktop
How do I make a recovery disk?
Which operating system ?
there are some you can download
If you computer crashes and your hard drive fails, you can lose a lot of data and spend a great deal of time trying to find all your discs and re installing all of your information.
It can be very difficult to find and re-install your operating system if you do not have the original CDs that came with your computer.
But if you create a recovery CD for your computer, the restore process can be much faster and quite easy.
Put the blank CD in your CD writer.
Click on the Windows Start button.
Click on the Control Panel option.
Click on Backup Your Computer from under the System Maintenance section option.
Click on the Backup Your Computer button on the Backup and Restore menu.
Select your CD drive from the drop-down list and press the Next button.
Click the Start Backup button to begin the backup process.
you might need to use dvd rw depending on the size of the backup
This will show you how to create a Windows 7 system repair disc to use to boot to the system recovery options if you dont have a Windows installation disc, cant find your Windows installation disc, or cant access the recovery options provided by your computer manufacturer.
or
b) Select the correct keyboard input method and click Next.
Note If you are using the Windows7 Install DVD then at the Install Now prompt (Do not pick the Install Now option) instead choose the Repair your computer option located in the lower left of the dispay.
c) The System Repair tool will search for a valid operating system and will report that Windows found problems with your computers startup options.
Do you want to apply repairs and restart your computer ?
d) Click Repair and restart and reboot again to the Windows 7 System Repair environment.
e) Click Next at the keyboard selection prompt and when the System Recovery Options screen appears verify that the Use recovery tools that can help fix problems starting Windows is selected.
Click the Next button.
f) Now from the menu list select the Command Prompt option.
bootrec.exe /fixmbr
bootrec.exe /fixboot (may return an Eliment not found message)
h) Close the command prompt window and click the Startup Repair option.
i) The repair process may take some time, so wait until the process completes at which point you will see two messages Windows cannot repair this computer automatically and Startup
Repair cannot repair this computer automatically.
Ignore the Send/Dont send options.
J) Close this message window by clicking on the X in the upper right corner of the Send/Dont send window.
Next click on the View advanced options for system recovery and support option and from the main menu once again click Startup Repair.
This time the repair process may only that a few seconds and when prompted Startup Repair could not detect a problem, click Finish and run the Startup Repair option one more time, click Finish, and then remove the System Repair DVD and click Restart.
http://neosmart.net/blog/2008/download-windows-vista-x64-recovery-disc/
vista recovery disk
not longer free
hope this helps
Oct 22, 2012 | Compaq Presario CQ70 Laptop AC Power...
My kid has a Satellite L305-S5918 computer .She tells me when you turn it on ,it goes to a blue screen and says to insert a driver recovery disc . Her and her fiance have been on Limewire downloading...
If there still need the data on there computer then you will need to try and recover it.
I would say just install a new copy of windows and start fresh.
Feb 28, 2011 | Computers & Internet
When i turn the computer on it says windows root 32 is corrupt or missing please reinstall but i cant get it to reinstall it the install menu does not pop up
You need to re-install it using your disc not when your on Windows enable for it to install. Here are the steps to install Windows back in your system.
  1. Start your computer from the Windows XP CD. To do this, insert the Windows XP CD into your CD drive or DVD drive, and then restart your computer.
    Note To boot from your Windows XP CD, the BIOS settings on your computer must be configured to do this.
  2. When you see the "Press any key to boot from CD" message, press any key to start the computer from the Windows XP CD.
  3. At the Welcome to Setup screen, press ENTER to start Windows XP Setup.
  4. Read the Microsoft Software License Terms, and then press F8.
  5. Follow the instructions on the screen to select and format a partition where you want to install Windows .
  6. Follow the instructions on the screen to complete the Windows Setup.
Sep 12, 2010 | E-Machines eMachines Desktop PC
I did recovery manager. When it restart den it says ((The computer restarted unexpectedly or encountered an unexpected error. Windows installation cannot proceed. To install Windows, click ''OK'' to...
The previous windows installation is either damaged, or did not complete, it is asking you to put your windows disc in so that in can proceed with the installation.
The recovery manager must have damaged your windows installation
Sep 05, 2010 | HP Pavilion dv6000z Notebook
Whem i turn my computer on its says no operating system found.
Unfortunately that means either your windows installation is corrupt and needs to be reinstalled or the hard drive has failed and needs to be replaced. If you do not have a windows xp disc you will need a technician to do this as you will not be able to without the disc. If you do have a disc however follow these steps.
First insert the windows XP disc into the drive
Then when the machine says press any key to boot from CD press enter
Wait for the windows setup to load completely
Then highlight the windows XP partition it should be labeled windows XP
Then hit R on the keyboard
This will start a repair installation of windows
If it does not show the windows xp partition try installing to unpartitioned space
If the windows disc cannot find the hard drive or the repair does not completely unfortunately it means that the hard drive has failed and needs to be replaced.
Feb 26, 2010 | Compaq Presario 5000 PC Desktop
Sims 2 bon voyage need help to install
put disk 1 it should say type in a serial number wait for disk 1 to install then it should say insert disk 2 wait for that to be install after a message should pop up saying insert disk 1
Sep 30, 2009 | Electronic Arts The Sims 2: Bon Voyage
I get a error message when i instal its around when expansion 7 is installing witch is disc 2 and it happens everytime i install help me plz Jacob
Jacob,
Is the disc clean???
Make sure there is nothing on it. You can wash it in hot water and any liquid soap.
Only wash the disc in **ONE** direction and never in circles. Just straight across._______________
Rinse and dry same way.
Mastersage......................................
Aug 16, 2008 | EA - Electronic Arts Sims: Complete...
Acer 3050 1554 No instalation disc
nope..where did you get the acer from? Go there, and get a system recovery disk.
Apr 23, 2008 | Computers & Internet
Lexmark x1270 all in one printer will not install
windows xp home edition has problems running a lexmark, the xp pro dont its a windows problem do you have xp if so when it says needs install dont use the disk let the set up wizard take you to a site to down load the drivers i had to do the same with my X1150 all in one.
Dec 20, 2007 | Lexmark X1270 All-In-One InkJet Printer
Acer Aspire 3050-1733 Notebook Logo
79 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
