Question about Precor 935 Premium Series Treadmill
What is an Error 22, 23,and 26 on a precor 9.35?
    President:
  • Precor Master
  • 832 Answers
Error 22 indicates that the drive motor (running belt) has been instructed to start, by either manual or program control, and the monitoring system has not received any response from the speed sensing system indicating that the drive motor has started.
Error 23 indicates that the speed sensor signal was lost while the treadmill was in operation
Error 26 this error monitors the speed sensor signal and verifies the the speed sensor signal is appropriate for the requested speed. If the speed sensor signal is incorrect or erratic an Error 26 will be displayed.
Unplug unit and remove motor shroud and try these procedures:
The treadmill utilizes an optical (infrared) speed sensor and the line of sight between the speed sensor and the speed sensor target is obstructed. The speed sensor position relative to the speed sensor target is incorrect. The speed sensor potentiometer adjustment is incorrect (when equipped). The speed sensor target is damaged
Carefully, vacuum out the drive motor compartment with a static safe vacuum cleaner. Pay special attention to the area between the speed sensor and speed sensor target. Adjust the speed sensor position so that the space between the speed sensor and the speed sensor target is 3/16 inch and so that the speed sensor photo eye is aimed at the larger portion of the targets wedge shaped section. On hall effect speed sensors (magnetic sensor) the space between the end of the speed sensor and the flywheel tooth should be 3/16 inch. If the treadmill utilizes a speed sensor potentiometer, locate the speed sensor potentiometer on the lower PCA. Set the speed sensor potentiometer at mid-range. Start the treadmill and increase the speed to 6 mile per hour. Carefully adjust the speed sensor potentiometer to the point where the treadmill is operating the smoothest. Increase the treadmills speed to full speed at repeat the previous adjustment. These two adjustments are typically small and are usually only a matter of fine tuning. . Most speed sensor targets consist of a circular arrangement of alternate black and silver sections. If the speed sensor target is torn or badly scratched the speed sensor may receive an incorrect reading. Replace the speed sensor target.
Posted on Jun 27, 2010
SOURCE:
Precor error 3
Precor Error 03, Memory, RAM, EEPROM Test Error Probable Cause This error message almost always indicates an upper PCA problem when it is consistently displayed. Failures causing this error message to be displayed are rare.
Corrective Action If the error message is consistently displayed when the unit is powered up, the upper PCA should be replaced. It is possible to see this message displayed intermittently due to external causes. If the units A.C. input significantly dips during the power up test sequence the test could fail resulting in this message being displayed. Treadmills operating on non-dedicated A.C. circuits may see this message displayed on an intermittent basis. Precor Error Code 03 E03 EEPROM Test Error
Feb 22, 2014 | Precor Exercise & Fitness
Error41
Precor Error 41, Lift has not Responded in Acceptable Time Probable Cause Error 41 was present in early software versions and is no longer being used.
Corrective Action If you encounter a unit that has software with an error 41, diagnose the same way you would if getting an error 40.
Precor Error 41
Jan 29, 2014 | Precor 9.21 Treadmill
Error codes for 9.17
This link will take you to some common error codes found on most Precor exercise machines:
Error Code List for Precor Fitness Equipment
Dec 12, 2013 | Precor Exercise & Fitness
Precor treadmill code e3 is on
Oct 18, 2013 | Precor C954 Remanufactured Treadmill
Precor error code 1
Precor Error 01, Memory, RAM, EEPROM Test Error Probable Cause This error message almost always indicate an upper PCA problem when they are consistently displayed. Failures causing this error message to be displayed are rare.
Corrective Action If the error message is consistently displayed when the unit is powered up, the upper PCA should be replaced. It is possible to see this message displayed intermittently due to external causes. If the units A.C. input significantly dips during the power up test sequence the test could fail resulting in this message being displayed. Treadmills operating on non-dedicated A.C. circuits may see this message displayed on Precor Error Code 01
Aug 18, 2013 | Precor 9.21 Treadmill
Error code 1 and 3 on my Precor 9.21s treadmill?
Corrective Action If the error message is consistently displayed when the unit is powered up, the upper PCA should be replaced. It is possible to see this message displayed intermittently due to external causes. If the units A.C. input significantly dips during the power up test sequence the test could fail resulting in this message being displayed. Treadmills operating on non-dedicated A.C. circuits may see this message displayed on an intermittent basis. Precor Error Code 01
Mar 27, 2013 | Precor 9.21s Treadmill Display Console...
What is error 50 on the precor efx546
Error 50, Too Much Brake (Magnet) Current
The problem maybe lower board related or improper signal is being translated Call Precor @ 800-347-4404
May 11, 2010 | Precor EFX 546i Elliptical Version 4
Precor uses the same error codes for all of their units. Error code 50 is for excessive brake (eddy current magnet) current.
Mar 19, 2010 | Precor EFX 546i Elliptical Version 4
Error 45 on Precor EFX 546 Elliptical
Precor Error 45, Lift Moving in Wrong Direction Probable Cause 1. Lift motor hysteresis.
2. Lower PCA is bad.
Corrective Action 1. The error would usually occur when the lift was already in motion (usually downward) when a lift command in the opposite direction (upward) was made. Some lift motors used in production exhibited a very long turnaround time and the lift motor would still be moving in the original commanded direction while the control system was trying to move the lift in the opposite commanded direction. If the error continues to re-occur, replace the lift motor.
2. It is a rare condition, however if the lift moves in the opposite direction commanded, replace the lower PCA.
Precor Error Code 45
Jul 19, 2009 | Precor EFX 546i Elliptical Version 4
Precor 935 Premium Series Treadmill Logo
3,416 people viewed this question
Top Precor Exercise & Fitness Experts
Jose Pino
Ross Metcalfe
Ross Metcalfe
Tom Chichester
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
