I have a lexmk z 82 printer, over the last 2 months the print quality of the color printing seemed to be fading i at first thought it was the staples color ink cartridge i bought but i replaced it with a new lexmk one but the bright colors i used to get r not there, i cleaned the nozzles but to no help
  • 655 Answers
I think its not printer or ink problem. Your monitor might be brighter so pics will look more bright on monitor and less on printer. If this is the case with you then:
  • Try to reduce brightness of your monitor, then make bright your picture using software which one you are using, means in this case you are going to save more bright value in the image file. Then print it.
Post your feed back please.
Thanks
Iqbal
Posted on Apr 15, 2008
Why is my printer not printing the right color? its very faded
Is your printer set to Economode in the printer settings? It may be and so its printing at low quality.
Jul 16, 2014 | Xerox Phaser 7400DN Laser Printer
CANON PIXMA COLORS ARE LIGHT
I would manually clean out the printhead, I believe for your model it is a separate unit form the ink cartridge. Please follow these steps bellow.
First you will need to remove the cartridges, then remove the printhead assembly then mix some water and isopropyl alcohol in a 50/50 mixture. You can either use a cotton swab to rub the water and alcohol on the printhead or you can soak the inkjet printhead for around 2 to 5 minutes. This should loosen the dried ink. It may take a few attempts and requires patience. Dry it on a folded paper towel and reinstall it. Print a test page to check quality. If the documents are still printing with poor quality, repeat and soak the printheads for longer.
Let me know if that helped. I had the same issue and this resolved it for me.
Thanks
Bloomfield Connecticut Computers (BCC)
Jan 13, 2014 | Canon PIXMA MX700 All-In-One InkJet...
I have wep printronix p7500 line printer. I haven't uses the printer since last 24-30 month. when i print a text file using edit.exe. it print quality is very fade. I brought a new ribbon for this printer....
I'm guessing the carrier solvent for the ink has evaporated. (Ribbon is old and dried out - even the new one) In the past, i have sprayed WD40 on unspooled ribbons and rewound them to bring ribbons back to life but that can be messy with spotty results. Suggest you buy direct fro Printronix.....
Oct 01, 2017 | Printronix Office Equipment & Supplies
Pixma mx330 printing very faded colors
try selecting higher print quality setting. If it still prints faded on "standard" or "high" quality, try running the "printhead clean" or "deep clean" utility (under "maintenance" in printer properties).
If still no good, refill or replace cartridge(s).
good luck with it
LC1000
www.inkbank.com.au
Dec 10, 2010 | Canon PIXMA MX330 Multifunction InkJet...
I have been told my printhead is malfunctioning. Can I clean it myself?
You can look in thr user guide or printer help for Troubleshooting and Routine Manteinance.Make sure that the Printer Driver or Paper Type setting in the menu matches the
type of paper you are using. (See Printing in the Software User's Guide on the CDROM.Make sure that your ink cartridges are fresh. The following may cause ink to clog The expiration date written on the cartridge package has passed. (Cartridges
stay usable for up to two years if kept in their original packaging.) The ink cartridge was in your machine over six months.The ink cartridge may not have been stored properly before use.
Try using the recommended types of paper.
CLEANING:
Press Ink.
Press a or b to choose Cleaning.
Press OK.
Press a or b to choose Black, Color
or All.
Press OK.
The machine cleans the print head.
When cleaning is finished, the machine
will go back to standby mode
automatically.
Checking the print quality
If faded or streaked colors and text appear on
your output, some of the nozzles may be
clogged. You can check this by printing the
Print Quality Check Sheet and looking at the
nozzle check pattern.
Press Ink.
Press a or b to choose Test Print.
Press OK.
Print Quality.
Press OK.
Press Color Start.
The machine begins printing the Print
Quality Check Sheet.
Check the quality of the four color blocks
on the sheet.
Is Quality OK?
1.Yes 2.No
Do one of the following:
If all lines are clear and visible, press
1 to choose Yes, and go to step j.
If you can see missing short lines as
shown below, press 2 to choose No.
The LCD asks you if the print quality is
OK for black and three colors.
Black OK?
1.Yes 2.No
Press 1 (Yes) or 2 (No).
The LCD asks you if you want to start
cleaning.
Start Cleaning?
1.Yes 2.No
Press 1 (Yes).
The machine starts cleaning the print
head.
After cleaning is finished, press Color
Start.
The machine starts printing the Print
Quality Check Sheet again and then
return to step e.
Press Stop/Exit.
If you repeat this procedure at least five
times and the print quality is still poor,
replace the ink cartridge for the clogged
color.
After replacing the ink cartridge, check
the print quality. If the problem still
exists, repeat the cleaning and test print
procedures at least five times for the
new ink cartridge. If ink is still missing,
call Brother Customer Service
Nov 03, 2010 | Brother Multi-Function Center MFC-240C...
Poor print quality of images on envelopes
clean the print head 3 times,then realign the head .these are done by printer utility software given with the printer.
Even not ok.
Then Replace the New Catridge.(manufactured from within 3 of 4 months).because the ink will be dried with in 6 month.So Buy Carefully with Mfd Date.
Thank you
Feb 13, 2010 | HP LaserJet 4650 Color Printer
MY PRINTER WILL PRINT IN FADED COLOR. I REPLACE BOTH COLOR AND BLACK INK CARTRIDGES. STILL NO PRINT. THE LAST TIME THIS HAPPENED WAS A FEW MONTHS AGO AND I WAS TOLD I NEEDED A NEW PRINT HEAD. THIS WILL BE...
If you are not using the printer that often, the ink may be drying out.. once the ink is dry on the printhead, it could very well be the cause of the problem.
Check out the link below:
http://www.kodak.com/go/itg
For image quality issues, this is the place to go for troubleshooting them and getting a replacement head if needed.
Jul 10, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Color cartridge does not work - color faded. Just replaced AGAIN today - same problem
Remove it,replace it couple of times.
Run a nozzle and printhead cleaner check,
from your printer's properties, maintainance.
align too, just to be sure your setup correctly.
Check your printer settings for quality of the print.
there are various choices there for you.
Should be good then
Regards
Richard.
Apr 21, 2009 | Lexmark Color JetPrinter Z52 InkJet
Distorted color printing
Check on the quality printer settings - Clean your cartridges -
Sep 04, 2008 | Canon I960 InkJet Photo Printer
New Ink cartridges registering as empty ...
Is it an HP printer? We had the same problem at work with print cartridges purchased at Staples. They have a major quality control problem. Your new print cartridge may be empty or dried out (died on the shelf). It's my problem at work, as I have over 80 HP deskjets, and Purchasing still insists on buying the Staples cartridges rather than the HP.
Sometimes if you shake a print cartridge really hard it may correct the problem. However, I would buy or borrow a black HP print cartridge and try it out in your printer. Works almost every time on the job. Good luck.
Apr 17, 2008 | Computers & Internet
73 people viewed this question
k24674
jasbo
jasbo
