Back to:
Tags:
Gateway FPD2485W Television
posted by MTHADDOCK on Apr 15, 2008
Hi Jerry, I have bought three of them on ebay. One of them has all the right working parts to fix the other two, but I am having trouble getting into it. I have removed the three visible screws at the bottom. There are two what appear to be power buttons next to where the other screws are. They may not even be power buttons, ? they may just cover 2 more screws and it will easily open. But they don't wont to pop out and if I use any more force it will brake it. I guess I will know then, but after years of taking computers and laptops apart I know it is probably a clip or hidden screw or someone saying don't worry just pop those buttons out of there and get on with it. So if you have any ideas ? Thanks in advance. Mike
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Apr 21, 2008
Helpful (85)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
after removing the 3 screws you mentioned you are on track to open the case.. Next remove the 4 screws that hold the bracket for the mounting stand..Now look closely at the bottom of bezel notice the a large slots on each corner. Carefully using a screw driver with a big blade to match the slot.. pry the case open. I use 2 screw drivers to work hand over hand. it takes quite a bit of tugging to remove. If you decide to lift out the chassis from the front bezel be very careful because there is a small ribbon connector connected that is fragile. This should work!
Rating Locked! (?) MTHADDOCK has rated this solution as Helpful
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Gateway FPD2485W Television:
I don't want to Accept this solution
Solution #2
posted on Apr 16, 2008
Not Rated (0)
jerryg50
Rank:Wiz Wiz
Rating: 84%, 581 votes
I have not worked on this model of set. I was thinking along the same lines as you are. I do remember some monitors having hidden tabs under the edge of the cabinet. I had to use a very thin blade to reach the tabs. It was something like a remote control where you have to find the tabs to open it.
Jerry G.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Can you Help with these Flat Panel Televisions problems?
The sound is on but picture wont appear. Have had this...
Hi I have a Gateway fpd2485w that powers on shows gateway...
What parts are left over from fixing the other two...
When I attached Samsung DVD-R155 (with built in tv tuner)...
Loading problems.
Repair Service
Find Flat Panel TV Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
