Question about Vacuums
The dial regulating suction does not seam to work the vacuum works constantly on the full power and the light indicating overheating stays on.
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 310 Answers
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
This would depend on the brand and model number you have – without knowing the model or brand of vacuum you have it would be hard to give an accurate answer – the over heating light could indicate some type of clog or blockage and may have nothing to do with the dial to regulate the suction – that merely is a height adjustment …. As this does happen to most vacuums that the overheating light comes on – if there is no problem have it looked at from your local vacuum dealer or repair shop would be the best advice that I could give you.
Posted on Apr 15, 2008
I have a miele S712 (2 yrs old worked fine yesterday) - I had been doing some diy work inside and had the vac on just to reduce some of the dust in the air - after a while the vacuum fizzled out. I...
you have got dust in the micro switch and it is not latching on, if you look at this and clean it, that will solve your problem, however blowing the motir has probably wrecked the motor bearings.
Jun 02, 2011 | Miele Vacuums
Electrolux 2100 vac dies when you attach hose even with new bag.
If the bag full light keeps coming on, you can first try adjusting the dial on top of the vacuum cleaner. If that does not work, then you need to change the control valve. This is an internal component of the canister and is directly below the dial. You will need to follow the instructions on a previous post to open the Electrolux plastic canister vacuum, and remove the bage cage. Once you remove the bage cage you can change the control valve, and this will solve your problem with the bag full indicator.
Mar 31, 2010 | Electrolux UltraLux 2000 Bagged Canister...
Electrolux Epic 6500 Vacuum - Suction stops when hose is attached
You can ship the vacuum to http://evacuumstore.com/ and they can reapir it for you.
Mar 28, 2010 | Electrolux Epic 6500 Vacuum
My epic 6500SR is not working. The power comes on
This is usually caused by your full bag indicator shutoff switch.
The control valve has gone bad. This is the dial on the top of the vacuum that has numbers on it.
You cannot bypass this problem from outside the machine.
The part can be bought at the local outlet. Go to www.aerusonline.com and find A local dealer. It is not too expensive to fix, and is a common problem on later model electroux vacuums.
Mar 15, 2010 | Electrolux Epic 6500 Vacuum
I have the Miele cat & dog S5000 vacuum. I have had it about 1 year and lately the suction doesn't seem as strong and the full bag indicater is always full. I have followed instructions in manual but...
Greetings,
I would say that you have a slight clog in the hose or in the power nozzle somewhere. The full bag indicator is just a guage that will indicate full when it feels like it's lost suction. Example: If you were to take the hose and cover it with your hand, you'll notice that bag full indicator will show full.
To check and see where the clog in the vacuum is, remove the wands and floor attachment so you just have the hose on the vacuum cleaner. With just the hose attached, turn the vacuum cleaner on. Does it still show a full bag? If yes, then remove the hose completely from the vacuum cleaner so it's just the canister part by itself and turn on the vacuum again. If the bag full indicator is now showing an empty bag, this means that you have a clog in your hose.
If the bag full indicator displayed an empty bag when you had the hose on the vacuum, but shows a full bag when you have the wands and floor tool attached, this means that you have a clog in the vacuum either in the wands, or the floor attachment.
For removing clogs from the hose, the quickest way is to just purchase a plumbers snake at your local hardware store, and run the snake through the hose until you find the clog. You may also take a high pressure hose and spray it down the hose until the clog is cleared, but if you use a water hose, MAKE SURE the hose is 100% dry before you use it again.
Also that bag full indicator can be adjusted if you are getting a lot of suction power and it still shows full.
I hope that these suggestions helped you diagnosis your Miele canister to figure out why the indicator showed full. If this helped you please rate my repair helpful.
Feel free to contact me if you need further assitance, I'm always happy to help.
Chris J.
Mar 13, 2010 | Vacuums
The light on the top of the vaccum stays light and
You have a Electrolux, not a Guardian though, right? The light you are talking about is the bag full indicator. I know your bag is not full, so, try this. The knob on the top of the cleaner is a fine adjustment designed to let the bag fill up in different conditions, (dirt types) . So...turn the dial down to setting 2. Try it again. Did it work? If so, this is your adjustment . No need to ever adjust it agin. It is NOT the suction control. If this did not fix ya (haha) then, your adjustment diaphragm is bad and you will have to break down and bring it to Aerus(Electrolux) for a repair. I hope this info was helpful, if so, please leave feedback, it helps my rating, Thanks, Rene(The Vacuum Doctor)
Nov 07, 2009 | Electrolux Guardian Bagged Canister Vacuum
Full bag system works properly, but doesn't reset easily
Either there is something wrong with your switch. Which it doesnt sound like it. Take it to your dealer or call another one it sounds like the control valve needs to be replaced. I am a dealer 1-866-966-9350.
Jun 19, 2008 | Electrolux Lux 7000 Bagged Canister Vacuum
Miele Solarus Canister Vacuum stopped working
I am an amateur and novice.
Tracked My Miele problem to a bad connection at the outlet plug.
i think the constant slapping of the plug against the housing during rewind prob disconnected the wires inside the plug? Replaced plug
Apr 14, 2008 | Miele CatAndDog700 Bagged Canister Vacuum
Red light on top is on
If you have something like a metal ball, drop it down one end of the hose to see if it comes out the other side. The hose, wands or the inlet in the power head, if any of these have a clog, that red light comes on and suction is low.
Oct 24, 2007 | Kenmore 25512/ 25513 Progressive Canister...
Vacuums Logo
107 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
