Question about Kenmore 62602 Electric Dryer
Won't work clip that holds door shut
    Genius:
  • 1,073 Answers
The part number is 279570 for the kit
Posted on Apr 15, 2008
Little soap dispenser door won't click shut
Chances are the spring that operates the clip that holds the detergent door has become disengaged. When you push on this clip is there any resistance?
Mar 25, 2014 | Dishwashers
Back door won,t open on my 02 avalanche
door handle broke depends on what door handle it is.if door cant be open on out side out side door handle broke.if cant open door on inside inside door handle broke.door handle clip that connects to latch rod broken.when you try open door handle not engage to latch rod.door not going open.have to replace door handle with new clip holds latch rod in place.
Jan 09, 2013 | 2002 Chevrolet Avalanche
How to remove sliding door inside panel of Mazda MPV
1. Work with slider in open position. It helps if you are on a slight incline so that door stays in fully-open position and won't slam shut on your fingers.
2. Remove inner handles and door panel:
a) Inner handle. Remove the inner handle first. You can't see it too easily but a wire clip about the same thickness as a large paper clip holds the handle to its shaft. It's shaped like an upside down "U" so it needs to be pushed straight up. Press the panel outward around the handle and you can just see the clip. Use a small thin screwdriver to locate the bottom tips of the clip and push it up. You may have to alternate from side to side but it will pop off. Grab it with a pair of needlenose pliers if you have to. The door handle willl now slide off - just pull it towards you.
b) Power window switch. Remove power window button by squeezing hidden tabs along the sides of the button. Again, you may have to push the panel outward a little and pry the switch to see the tabs. Wiggle it a little and the button will release. Pull it out and unplug the wiring harness.
c) Door panel. There are several plastic buttons which hold the panel on at the bottom and up the sides. Use a plastic putty knife to get behind panel and pop it out of the holes.
3. Once all trim fasteners are released, grab the door panel at the bottom and pull straight up to release it at the top. You may have to give it a quick upward tug to get it to release. Push the power window button wires through the mounting hole. Look at the panel buttons to make sure that all of them came off with the panel. If not, remove the remaining ones from the door and put them in their respective slots on the door panel. (Trying to re-attach the panel without the buttons installed on the panel will be frustrating.)
4. Outer handle removal.
a) Unclip the handle lock button / bar by turning the small tab and pulling the bar out of its slot. Hard to describe here but you'll figure it out once you see it.
b) Remove three bolts which hold the handle on the door. Note that one bolt is accessible from the outside of the door along the front jamb.
Replace handle and reverse the steps above.
Notes: Check the locking mechanism and make sure the door opens and closes before you reassemble the panel. Remember to orient the inner handle the right way before you re-attach its spring clip. (I've attached it upside down and it won't work!!!) . Also, be sure to feed the power window wiring harness back through the mounting hole before putting the panel back on.
Nov 06, 2012 | 2000 Mazda MPV
Sharp r520kst door won't stay shut
If the door will not stay closed it is the spring inside door, or the small plastic piece that holds the spring which is attached to the $80.00 piece called outer door.
To fix it, it is EASY and you do not have to even take the inside cover all the way off. Just remove the three sides of cover by gently slipping a plastic putty knife around rim to release the clips. Then attach the spring to the small hole below where the plastic piece used to be, which is located in the metal on the glass frame piece, use tweezers, hold the other end of spring as you place spring onto plastic door latch and set into place!
Snap the inside cover back on and YAY! FINI!
Aug 20, 2012 | Sharp Microwave Ovens
My drivers side door won't open with a key anymore, passenger side works fine. Janette
It sounds like the door lock rod has become detached from the lock rod actuator. The plastic retainer clip that holds it in place can become dislodged causing them to separate. Fixing this problem is not that difficult but, it does require removal of the inner door panel.
May 14, 2011 | Ford Explorer Sport Cars & Trucks
My driver side door will not unlock, I got it to unlock once and then took the door panel off then locked and shut the door. I now cant open the door at all. When i pull on the little bars that are meant...
There is a door lock actuator mounted on the inside of the door jam, usually one or two screws hold it in there on the outside of the jam. Check to see if it is working. Sometimes the plastic clips that hold the rod breaks. You can get the clips and the actuator at the parts store.
Nov 24, 2010 | Daewoo Nubira Cars & Trucks
Y reg 307 passenger door wont open sounds like all locks are working ane handels seem to be still ok inside and out but door just wont open
typical french car,it has a plastic clip that if someone slams the door it breaks and you need to remove the interior door panel/inner skin(plastic)to get to it (the clips on the door will break off.)the clip runs between the door handle and the operating mechanism.
Jul 27, 2010 | 2005 Peugeot 405
When I shut the door the clip won't hold. I have
goto sears partsdirect and see the image of the part and with the model# you can order parts to be shipped to you.
Mar 02, 2010 | Dishwashers
Dryer door clip won't hold door shut. Spring in door appears to be loose
Hi, Get me the model # and I can get you the part # so you can replace the door latch. What brand dryer is this?
Vic
May 16, 2009 | Dryers
Gray plastic piece that holds the black clips that holds the door shut is cracked
you tape the door shut just make sure tape does not cover and vents. check web sites for parts?
May 12, 2009 | Minolta Di3510f Bizhub Copier
Kenmore 62602 Electric Dryer Logo
29 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
