Distorted sound output on speaker. No problem with speakers, as i have tried several.
  • AshleyS Apr 15, 2008
    It's a Technics EH770. It's the sort of midi seperates that technics started doin when they gave up making good sperates!
    Master:
  • 555 Answers
What is the maker and model of your receiver?
Posted on Apr 15, 2008
  • Matt Jurach
    Matt Jurach Apr 15, 2008
    Unfortunately, this model is unsupported by Panasonic, Technics new parent company. Even manuals for it are unavailable, except for a fee. My guess would be a failing amp circuit.
    Do you also get the same distortion when you bypass the amp and use the headphone jack?
Sound very distorted, new motherboard and speakers fitted.
If the sound is distorted on all sources over both speakers then the speaker amp on motherboard is suspect. To eliminate bad laptop speaker possibility, try hooking up another audio source to the audio output of the laptop and hear what happens. If they also sound bad then the mo bo is definitely the culprit.
Jun 12, 2015 | Computers & Internet
It sounds distorted when the music gets louder
Time to start upgrading! Think power delivery, then amps, then speakers, then enclosures.
If you need more voltage, add batteries, capactors etc, if you're exceedingg the amp output range, you'll blow speakers (no matter what the speakers are rated for), if you have good power and the amp(s) are fine, your speakers may not be up to the task
Feb 08, 2014 | Kicker Car Audio & Video
Marshall MB4410, with low volume gives no real volume,
Guitar amps have preamp sections (think unpowered audio mixer) and power amp sections (Crown rack-mount amp). An excellent way to isolate audio problems if amp is still producing audio is to check the preamp out (line out). Preamp output distorted = preamp failure. Connect MP3 player to "Power Amp In"...sound distorted = power amp failure. In your case the latter is the case as your "line out" is clean. Also test each speaker for clear sound as speaker cone damage from being overpowered is fairly common. At 300w. I'll assume the failure was not from cranking the volume to loud but a shorted speaker or speaker wiring could zap the power amp in an instant.
Jan 06, 2014 | Marshall MB4410 Bass Combo Amplifier
Crosley CR6001A: Left speaker barely audible
Hi Eric,
I understand how frustrating this problem can be. The problem can be the result of several different things. Two of them are 1) blown speaker and, 2) blown left amplifier output.
Try listening with stereo headphones. If you can hear both channels clearly, the amplifier is most likely functioning correctly. This is desirable as amp repairs would probably be more costly than a driver (speaker) replacement. Make sure you vary the balance controls while checking for output on both L and R speakers. If the sound is intermittent, the volume or balance control may have dirt built up and may return to working properly by liberally spraying electrical contact cleaner around the stem (knob removed) with the unit unplugged. Use the extension tube to pinpoint the output along the stem. Be careful to keep from over-spraying as it may damage plastic and wood cabinetry. After spraying, rotate the knob fully back and forth several times and then plug back in and try for sound again.
If you can't restore the volume to the left speaker, you may have a blown speaker. This usually happens as a result of excessive volume which leads to distorted sound. If played this way long enough, damage to the speaker is unavoidable.
The speaker can not be fixed - but may be replaced. Replacing the speaker is something most people with conventional hand tools can do - with the unit unplugged. Finding the information on the speaker may prove to require some digging however. You'll need to know the size, wattage rating, impedance value in ohms, and frequency response. It would be best to obtain the exact replacement part if possible.
Other than this, you'll probably need to have it serviced professionally. Good luck!
Dec 06, 2012 | Crosley Cr6001a Turntable
Peavey speakers making no sound
Try connecting them to another amplifier...you can use the speaker output of a guitar amp as a quick test. If the amp (and mixer) check OK, it sounds like you are about to become good friends with your local speaker reconing shop.
Remember...Distorted Audio Can Kill Speakers even at low volumes. It happens because sine waves become square waves. Google it for additional information.
Oct 24, 2012 | Peavey PR15 400w PA Speakers
Distorted sound from headphone jack
If possible try with another pair of headphones. If speaker outputs are ok, probably indicates a faulty output of headphone amp, if is seperate circuitry from speaker output.
May 04, 2011 | Audio Players & Recorders
Phonic Helix Board sound problems
You don't specify which model Phonic mixer in question.
Is it a powered mixer ? And are you plugging your speakers into the speaker outputs ? If it's not a powered mixer and you're plugging speakers into the Line Outputs, you're not using a power amplifier between the line outputs and your speakers - this won't work.
If it is a powered mixer and you are plugging speakers into the speaker output connectors and still getting little or no sound, check your speaker cables and the speakers themselves by plugging them into known good amps.
Jul 03, 2009 | Phonic Helix18fw 18 Channel Mixer with...
Mp3 connect yamaha rx-v995 ---> muddy sound
Try getting into the configuration menu of the MP3 player and adjust the output controls for external devices....it sounds to me like it might be too high and/or the wrong output decoding.
May 09, 2009 | Yamaha RX-V995 Receiver
Inspiron 530 sound distortion
What kind of integrated sound card do you have?? I am going to assume its realtek. Go to control panel, then open up RealTek HD Sound effect manager and make sure the drop down menu for Environment is on "none". The try your speakers.
Mar 25, 2009 | Dell Inspiron 530 Desktop Computer
Very low volume
check the mode button and make sure you are in the right mode, sounds like you have it in the wrong mode.
Sep 16, 2008 | Icom IC-R10 Handheld Scanner
 Grubhead
Grubhead
