Marshall Cab Connections
Will My 1960A Cab Work With My MG250DFX While Still Using The Internal Speakers
  • 1,512 Answers
Hi ciderman... It may well work, but I wouldnt advise it. The amp may have problems driving less than a 4 ohm load, which is what you will have if you connect the 1960 in stereo mode with the combo's speakers. This may cause an expiry in peak moments of a face blistering shred :)
Try just the quaddy with the combo. Dont worry about the internal speakers, the vintage celestions used in the 1960a are gonna rock all over the factory fitters in the combo. AND its gonna be so loud anyways with the quad, you wont need the extra speakers.
Posted on Apr 17, 2008
There is no sound coming out of my Marshall 100 watt tube amp head?
make sure the standby switch is operating correctly.Sounds like the power tube.
Dec 18, 2013 | Marshall Amplification Marshall JCM800...
How do you connect a peavey 6505+ amp to a marshall 1960a cabinet?
On the back of your 6505 there are two jacks that are labeled speaker outputs. For mono function, use either one of those outputs and run a SPEAKER cable from your amp to one of the input jacks of your 1960a cabinet. I assume it is a 4X12 cabinet. Either input will work. Make sure you match the ohm selector on your 6505 (right next to the output jack, 4/8/or 16 ohms) to the ohm rating on your 1960 cabinet. It is likely labeled on the plate that houses the input jacks. You should be good to go. NOTE: Never turn your amp on unless it is hooked up to a speaker cabinet and never use instrument cable to hook your amp to your speaker cabinet. Bad for a nice tube amp like yours.
Rock on and hope it helps.
Dec 02, 2013 | Peavey Music
Amplifer input mg250dfx
No, these pedals work only with the FX range not the DFX range
Aug 29, 2013 | Marshall Amplification Marshall PEDL90008...
I have a marshall jcm 900 slx 100 watt head and 1960a cab, when i went to use my amp i got no signal from my guitar. none of the fuses had blown and there was still a hum coming through the speakers. I...
It sounds like you have a dead guitar cable or the preamp section of the amp is blown. It needs to go to the shop. It's way cheaper in the long run to just take an amp in. If you try poking around without knowing what you're doing you can fry something more expensive or worse yet yourself! There are leathal voltages in a guitar amp!
Aug 17, 2017 | Music
When turning my Marshal MG250 DFX on, there is a terrible buzzing sound. I have tried it on different speakers and the buzzing still occurs. It does not change in volume when i adjust the volume. Whats the...
This is likely a filter capacitor issue. The right tool to troubleshoot is an oscilloscope. This could also be a failed power amp that is driving high DC current with ripple into your speaker. This can permanently damage the speaker. Repair this before using it.
Jan 13, 2011 | Marshall Amplification Marshall MG250DFX...
Cooling fan motor grinds and very noisey would like to replace cooling fan,where ca i obtain oem part for this mg250dfx
The fan will have a manufacturer's part and name on it.
Shop Digikey.com or Mouser.com for identical device.
Note that SOME amps have the fan throttled depending on temp and these fans get noisey when throttled down.
Not sure about your Marshall on. The usual fan failure is bearings get dry and coke the lubricant.
Feb 24, 2010 | Marshall Amplification Marshall MG250DFX...
Left input for loudspeaker is dead? speakers both work out the left but neither on the right. can I fix it myself? marshall mg250dfx thanks
It sounds like the speaker output jack is broken or it has come unsoldered from the circuit board. You can fix this if you have enough electronics experience but you have to be very careful as components in an amp can carry a lethal charge even after being unplugged. You can partially discharge the capacitors by unplugging your amp from the power source with the speaker plugged into the working jack and set at a low volume while turned on ( not on standby ). If you feel at all uncomfortable attempting the repair yourself you are far better off taking it to a repair shop preferably one with experience with Marshalls. The same is true for other brands as well. Please let me know if this helps.
Nov 18, 2009 | Marshall Amplification Marshall MG250DFX...
One of My speakers does not work, When I switched the speaker wires the problem followed. I believe maybe a blown channel. """please help"""
Yes, one of the power amps has probably failed. If the channels are seperate, then another possibility is a bad input connector. These do get broken when cables are tripped over.
Nov 08, 2009 | Marshall Amplification Marshall MG250DFX...
4 x12 slant cab grill is ripped its a '' MARSHALL''
From behind the amp there shouls only be a couple os screws that hold that fron panel on, once removed you can take it off to work on it, you can get the same material from a good music store or even some type of fabric store or craft store.
Mar 29, 2009 | Marshall Mg100dfx 100-Watt Combo Guitar...
Marshall 50w dsl
Put a patch cable from send to return on the effects loop in the back of the amp and see if it goes away. I would check your speaker, connections and speaker cable also. Is this a head or a combo?
Sep 04, 2008 | Marshall 82 WTS LITHIUM BATTERY, 3 LED...
59 people viewed this question
 Grubhead
Grubhead
