Question about HP OfficeJet 6110 All-In-One InkJet Printer
HP Office Jet 6110 All in One faxing
Please help me. I need to use the fax and every time I attempt to fax something it sounds like it is dialing and going to connect, but it does not. I am so frustrated, I have tried everything that I can think of.
  • Anonymous Apr 26, 2008
    I have a tried my beast to fallow your instruction but still have a same problem.Faxes unable to send and receiving, have you another solution?
  • Anonymous Jan 15, 2009
    I have a All-In-One HP 6100.... When I first set it up I had it using a dedacated line. In the fall of last year (2008) I got a router and now all should work on this line. The fax Lof still has the old phone number and I want to change to the other phone number. How do I do it. OH! I am using Visa!!!!!
  • 28 Answers
Fiend your solution direct from hp. Here is your solution...
http://www.hp.com/printer/prob676ijt65/solution
803
Posted on Feb 28, 2009
    Genius:
  • 1,027 Answers
This document covers the basic fax functions of the HP Officejet 6100 series. The HP Officejet 6100 series can perform the following functions:
  • Send and receive paper faxes.
  • Send and receive color faxes. Color faxes can be sent only to color fax capable machines. If a color fax is sent to a black-and-white only fax machine, the HP Officejet sends the fax in black and white.
See Figure 1 below to identify the buttons in the Fax area of the front panel. Figure 1: Identifying the fax area of the front panel HP Office Jet 6110 All in One faxing - c00259777.gif 1- Turns Auto Answer on or off 2- Scrolls through speed-dial entries 3- Redials the most recently dialed number 4- Dials fax numbers, enters text, and specifies menu items. 5- Starts a fax 6- Changes the fax resolution 7- Dials one-touch speed-dial numbers Fax settings Most fax settings are configured during installation through the Fax Setup Wizard. These settings, and some additional options, can be accessed through the front panel menu (see Figure 2). Figure 2: Changing fax settings from the front panel menu
1. Menu: enters the menu system.
2. Right and left arrows: navigate the submenus and options.
3. Enter: selects a submenu or option.
4. Cancel: exits from the menu. c00259778.gif Sending a fax To ensure the best quality when sending faxes in color, use a color original instead of a color copy. Follow these steps to send a fax:
  1. Load the original. Load originals directly on the glass or in ADF. For multi-page faxes, you must use the automatic document feeder (ADF). Loading original on the glass Place the original, print-side down, on the front-right corner of the glass. Loading original on the glass HP Office Jet 6110 All in One faxing - c00259779.gif c00259779.gif Loading original in the ADF Place the original, print-side up, in the ADF. Adjust the paper-width guide to fit the original. Loading original in the HP Office Jet 6110 All in One faxing - c00259780.gif c00259780.gif
  2. Enter the fax number using the keypad. Dial the number just as you would from a telephone (dialing 1 before an area code, etc.)
  3. Press Start Fax Black or Color.
  4. If there is no original in the ADF, the display will read, "Send from Glass? Press 1 for Yes or 2 for No"
    • Press 1 to scan the document from the glass.
    • Press 2 to load the document in the ADF. The display will read, Load original, then press Enter .
Posted on Apr 21, 2008
I would like to send a fax from my PC. I have a MS Word document and a HP 6110 xi connected as a printer to my PC. Can I send the fax directly to the other person or do I have to print it and send it via...
You can send the Word document as Fax from Your PC to Printer
Open the document and Click File menu and Click Print option
Choose the HP Officejet 6110 series Fax ( not the regular printer icon )
Click Print Button
You will find a cover page to enter the fax details
Enter the details and click SEND FAX button - the Printer will start dialing the # to send Fax ( word document )
Regards,
Shawn
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
Jan 19, 2011 | HP OfficeJet 6110 All-In-One InkJet...
Can no longer send/receive faxes since switching to digital phone
hi
fax does not work on digital line it only works on analog line........if u want our technician expert then contact us athttp://tinyurl.com/ldnuy2
Jun 21, 2009 | HP Officejet 6310 All-In-One InkJet...
HP6110 All in one
When the HP Office jet series all-in-one front panel screen displays Memory Full, the HP Office jet all-in-one is not able to send, receive or forward faxes. Copying will also not work. WORKAROUND: Though the memory buffer should clear itself automatically after proceeding with the next task, like receiving a fax or starting a copy job, these suggestions below may help you clearing the memory buffer by:
  • Add paper to the HP Officejet series paper tray
  • Clear a possible print jam and proceed printing the fax.
  • Reduce the copying or faxing resolution via the front panel's menu.
  • Use the HP Manager to send a (group) fax or making a copy. More memory is available this way, as the HP Manager utilizes the PC memory. When sending a group fax, the HP Officejet all-in-one's memory is filled to capacity. To copy in color is only possible from the HP Officejet Manager.
  • Press START to clear the message. If this message persists, unplug the power cord, and after at least 15 seconds plug the power cord in.
CAUSE: The HP Officejet series memory may be full due to: Copying on Photo quality or sending a group dial, which will use an extensive part of the internal memory's capacity. No paper in the paper supply tray, while receiving a fax. This may result that the data remains in the buffer. Print jam while receiving a fax or copying. The data is still stored in the buffer. System error displayed on the HP Officejet display window. SUMMARY: The HP Officejet series will not fax or copy without sufficient memory to store the data of the page in the buffer before printing the receiving fax or the copy.
May 22, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Cannot send faxes on my all in one hp office jet 5610
If the recipient side is ringing, then the problem is on their end. It sounds like the receiving fax is not set for auto-answering a fax call. A receiving fax machine should pick up and start to attempt the reception even if the fax number is dialed from a normal voice-only telephone; the receiving machine has no idea if the caller is a fax or a regular phone. It should pick up regardless and start to negiotiate the fax (that's the high-pitched whistling sound at the beginning of the call).
May 15, 2009 | HP Officejet 5610 All-In-One InkJet...
Fax set up
You can download this for free directly from HP with no hassles or signups required:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&product=79477&lang=en&
Mar 18, 2009 | HP OfficeJet 6110 All-In-One InkJet...
My hp office jet 6110 all in one will not allow my hp pavilion dv 5000 to initiate a scan from the "director". I have reinstalled the drivers that came with the printer several times and of course...
Hi greggcowley, having two HP's connected or bouncing between either you need to change the default printer before using either. Open printer and faxes. You'll see only one device has a check mark on it. So before you go to use the 6110 left click on it once, than click File & set to default printer. Same for the DV 5000. Each time you'll need to open printer & faxes & change the default printer/scanner.
Enjoy greggcowley!
Thank you for using fixya.
Merry Xmass!
Mike
Dec 17, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Cannot fax
Is thi sin an office?
Are you using a direct outside line or is it an office extension?
Your office extension may have restrictions on it and you would need to remove those.
I would confrim the numbers are fax numbers and that that line is ok by:
  • Dialing those fax numbers from a working phone line other than the fax machine
  • Unplug the fax and plug in a regular phone in the same line and see if you can dial out and then try those fax numbers again.
If the numbers work from a normal phone but not the fax line, then I would check that line for restrictions.
Dec 12, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Printer error
error message 345
The remote machine has failed to respond to a fax command from the local machine due to the connection being interrupted. These errors can occur if the phone lines in the area to be faxed are old or there is noise (static on the phone line). Other reasons can include power outages and other power related problems.
OR
The call waiting service can cause this error. The click, heard for an incoming call, is actually a momentary disconnect of the line.
OR
The remote user has pressed the Stop key while the reception was in progress.
OR
Under rare conditions incompatibility between the two machines may cause the remote machine to simply abandon the call.
*Re-attempt the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
*Disable ECM. Errors may still occur, and may result in a degraded image quality on the received page. However, the ability to transmit the entire document will be improved.
*Try sending at a lower transmission speed.
Dec 05, 2007 | HP OfficeJet 6110 All-In-One InkJet...
HP 6110 not able to send or receive fax
I tried to find information on replacing the modem to no avail. Unfortunately most products of this nature do not allow for replacing the individual components.
However I did find the following info on HP's site for troubleshooting problems with faxing. http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu02151&cc=us&lc=en&dlc=en&product=79477&dlc=en&lang=en#Not_working Hope this helps!
Nov 29, 2007 | HP OfficeJet 6110 All-In-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
448 people viewed this question
Seeker5211
Seeker5211
