Question about Curtis Lifestyle DVD System
Dvd player New DVD player used once worked great. Now when you turn it on the picture keeps moving from top to bottom,like an old TV with vertical out of adjustment. Audio ok.
  • 1 more comment
  • tkretro Apr 17, 2008
    All cables and connections ok, even connected to a different TV.
  • tkretro Apr 24, 2008
    DVD2047
  • Anonymous Mar 27, 2014
    Picture moves vertical
  • 13,433 Answers
If the problem persits in all tvs then its clearly a hardware side problem in the dvd player. Service required.
Also unplug the player for a while from all wires, then set it up again. If that doesnt solve it then I beleave that its a hardware side fault.
Warranty? contact your dealer. or a local service center.
Posted on Apr 23, 2008
  • Ekse Apr 23, 2008
    oh a synch issue, Don't follow my advice yet, lets see what magic ib can perform for us :-)
    Genius:
  • 3,587 Answers
That's a synch issue...do you have the latest firmware option for that curtis unit?
  • Patrick Michaels
    Patrick Michaels Apr 23, 2008
    what's the model number..we'll get some information for that unit
  • Patrick Michaels
    still need the model number amigo
    nods to Ekse
    this is a synch issue..between the output of the dvd and the input of the unit
    President:
  • 1,944 Answers
Did you check all the cables and connections?
Posted on Apr 15, 2008
I have a tv that has line going side to side
The line is horizontal but means no vertical deflection (set deflects picture from middle to top and bottom.
Either bad solder connections at vertical output chip or a bad part somewhere in that circuit.
Jun 16, 2012 | Toshiba 26 inch HD monitor TV, DVD and VCR...
5 year old panasonic viera LCD works great until tonight, screen turned into vertical and horizontal rainbows, can see vague picture behind all the lines like looking through thin black horizontal venetian...
make sure your speaker to your sheron sound isnt to close to it .also if dvd player is the source then move away from tv will demagnatize the tv theres a magnet in them
Jul 05, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
I recently purchased a KDL-40W5100 LCD Digital Color TV. I gives a great picture, but when I turn on my Panasonic DVD connected to it I get a blue snowy picture (it worked fine on the old TV)Can you help?
This may be due to a setting on the dvd player itself. What kind of tv did you have previously? Also what kind of connection are you using to hook up the dvd player to the tv? Lastly, if you have the model number for the dvd player it will help if/when you need further assistance.
Thank you,
Lee
Dec 11, 2009 | Televison & Video
DVD not showing a clear picture
test test test 17:05
danke bitte
do not answer test test
sorry
Jul 04, 2009 | Televison & Video
I can't get any sound from it.. just great visual...what can I do?
Yellow plugs and jacks are the Video and that works. Red and White are the RCA sound wires from the DVD to TV.
OR
Your sound goes from the DVD to TV via a Fiber Optic or Fire Wire.
OR
You use Ch 3 on the TV and watch the DVD through a TV Tuner and use the TV Antenna Cable between the DVD and TV.
If that didn't help, let me know for more things to check like Audio settings on the TV.
AL
Apr 26, 2009 | Televison & Video
DVD picture rolls vertically
Somehow the TV setting on the DVD player was set to PALS so we changed it to the proper setting.
Dec 15, 2008 | Digix HT1056A DVD
Green line on TV with DVD playing
The aspect ratio is fine, I just fixed mine you have to use the TV remote, and press the left or right directional button depending on where the green line. Philips TV offsets the picture when using HDMI, but its easily fixable using this remedy. Time to take the tape off haha!
Mar 07, 2008 | Philips HTS-6500/37 System
DVD PLAYS GREAT, TV AND VCR PLAY IN BLK-WHT W/NO SOUND
You have your DVD connected to your VCR, which is then connected to your TV, right? The problem is Macrovision. It's designed to prevent you from connecting your DVD player to your VCR, so that you can't make duplicates of copyrighted movies. It's a real pain in the neck. Try turning the DVD player off - or better yet, unplugging its power cord (as some DVD players are always in a standby mode, even when turned off). If that fixes the problem, then you need to reconnect your DVD player directly to the TV, not wired through the VCR. If your DVD player isn't wired through the VCR, are you using some kind of wire splitter (one cable branches into two) to connect both the DVD player and VCR? That can also cause this kind of interference, if both have power at the same time. There are video switches you can get to work around that. Here's one such switch (first I found for a decent price with a google search): http://www.pickeasy.com/20070827-video-selector-switch-video-game-p-555.html Hope that helps.
Aug 30, 2007 | RCA 27F500TDV 27 in. TV/VCR/DVD Combo
The picture on the VCR keeps rolling. How do I remedy this? I have a Sylvania cca-132a2 model.
i know this may seem old-school, but try turning the vertical hold knob. it used to solve all vcr problems with rolling picture.
Jul 07, 2007 | Sylvania (SRDD495) DVD Player/VCR
Picture rolling when I play DVDs
I used to have that same problem with my system. Fortunately for me, I still had the instruction booklets at the time so that helped me to figure it out. step 1: make sure there is no dvd in the dvd player before you start fixing the problem. Step 2: Press the "setup" button on the remote. Step 3: Once you have removed the dvd from the dvd player it should allow you to go to "preferences" in the setup menu. So do that. Step 4: Go to "TV TYPE" and make sure it's on NTSC. And then exit setup by pressing the setup button once again. And it should work. That's how it worked with my system at least. It seemed to switch the tv type by itself from NTSC to PAL which must be a flaw in the system. I thought I was the only one with that problem. Well, I hope that helped you at all. Have a good day.
Jan 12, 2007 | Koss KS3161 System
Curtis Lifestyle DVD System Logo
79 people viewed this question
Top Curtis Audio Players & Recorders Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
240cpa
Are you a Curtis Audio Player and Recorder Expert? Answer questions, earn points and help others
