Question about Canon CLC 4000 Copier
CLC 4000 FUSER ERROR?
I have the CLC4000 manual service but it does not appear the specific code E000-0320, I would like to know what "0320" means, thanks for your help. All lamps and thermal fuses work.
  • Canon Expert
  • 1,326 Answers
The problem is that the lower fusing roller has shorted out and it may have shorted out the DC- Controler. Did you resently replace the lower fixing lamp. If yes it is wise to replace the dc- controler at the same time. A suggestion from a Canon tech pub... Good Luck....
Posted on Apr 16, 2008
Clc color copier error code E061-0321
Disable potential control by going into service mode Copier > Option > Tempo > F-POT-SW. Now copies can be run.
1) A solid black copy means laser is defective.
2) A white copy means you should check the Primary corona and HVT.
3) A good copy means you should check the Potential sensor PCB.
Dec 01, 2012 | Canon CLC 4000 Copier
Canon CLC 4000 won't Power Up
hi first of all cheq the required power for clc 4000 is tis 110V AC or 220V AC, secondly verify the outle of power from wall plug may yor machine 220v and you are putting on 110V
thanks
May 11, 2010 | Canon CLC 4000 Copier
in the back of the copier there is a circut breaker switch put it into (!)
Mar 19, 2010 | Canon CLC 4000 Copier
Canon clc 4000 error code e194-0101
0101
When the pressure main thermistor fails to reach 80 deg C within the prescribed period of time after reaching 50 deg C during warm-up
you need your fuser rebuilt by a technician
Dec 29, 2009 | Canon CLC 4000 Copier
Canon CLC 4000 Error code E013-0002
DESCRIPTION:
THE WASTE TONER LOCK DETECTION
SWITCH (SW4) HAS BEEN PRESSED FOR O.1 SECONDS OR MORE.
Solution: the waste toner is FULL.you have to get rid of that TONER.
Nov 04, 2009 | Canon CLC 4000 Copier
I am looking for the Canon CLC 4000 service manual that I can download.
You might try www.justmanuals.com.It is a pay site but they seem to have everything.Good Luck
Apr 30, 2009 | Canon CLC 4000 Copier
ERROR CODE E020-02D0 on Canon CLC4000
you need a full developer change . do you know how to do that
May 15, 2008 | Canon CLC 4000 Copier
CLC5000 fuser oil into clc4000
Chance are almost zero. I dont believe there is any differenece.
Apr 16, 2008 | Canon CLC 4000 Copier
ERROR CODE E000-0320
A E000-0320 code is a fixing unit error code. It is either not warming up or it is getting to hot. It is a thermister is shortting out or a thermal fuse or one of the heating lamps are blown.
Apr 14, 2008 | Canon CLC 4000 Copier
139 people viewed this question
old marine
old marine
